HIFI-FORUM » English » Stereo (Engl.) » Need help ordering components for Passive | |
Need help ordering components for Passive+A -A |
zhopudey
08:43
erstellt: 13. Jul 2007, ||||
I'm ordering from rsindia.com Can someone please tell me if what I've choosen is correct? 1) Alps Potentiometer,27mm,horizontal mount,dual unit,50k,log - RS stock no - 236-9604 Does dual mean stereo? Meaning I'll need only one? 2) What is the difference between a " Black inner RCA/phono panel skt,1A 50V" RS Stock no 457-2896, and a " Black ring RCA/phono cable plug,1A 50V" RS Stock no 457-2931. The former is Rs 403/-, and the latter is Rs 125/- They're both made by neutrik, and look the same in the photo. Please answer soon ![]() |
zhopudey
14:30
Somebody please reply. I need to get the passive ready before I get my amp. |
ani
06:02
erstellt: 14. Jul 2007, ||||
1. Dual is stereo pot 2. Black Inner panelmount RCA socket is the female part of the RCA phono system , the one you see at the back of your equipments. Black Ring plug is the male part of RCA ssytem, this is fixed at the end of your cables. |
zhopudey
06:53
Thanks ![]() ![]() ![]() |
zhopudey
04:46
erstellt: 17. Jul 2007, ||||
Eeeks! I can't figire out their site ![]() ![]() ![]() |
ani
05:00
You register at RS site and then follow the menu. Quotation ref is your ref no or name you put eg. "Passive pre components" They are very fast and efficient, never had any problem in procuring from RS. Regards Anil |
zhopudey
05:10
Ohh.....so "quotation ref" is for my reference? Never thought of that ![]() |
zhopudey
05:19
Ok, I've ordered. But they didn't ask me for payment ![]() ![]() |
Savyasaachi
05:31
I paid cash on delivery. THe reference number is only for frequent customers. You will have a reference number after this order and this will be on your invoice. RS is very fast in shipping and excellent packaging. However you pay a hefty price for the components. They are worth sometimes though as i found out. |
zhopudey
06:12
Yes, I got a RS Ref Number. But, I haven't got the shipping cost yet, nor have I paid them. I assume they'll contact me after calculating shipping cost, and then I'll be asked to pay. |
zhopudey
05:08
erstellt: 30. Jul 2007, ||||
Wheeeeeeeeeeee ![]() Now, what wire do I use for soldering? Standard copper wire or something different? My friend suggested getting thick copper wire gold plated and using that. |
zhopudey
14:14
Got them ![]() ![]() ![]() But how do I tell which pin is for what? ![]() Edit: Found a nice explanation here - ![]() ![]() [Beitrag von zhopudey am 30. Jul 2007, 14:20 bearbeitet] |
vjcritic
17:51
Hi Zhopudey, How much shipping did u pay for them? Thanks, Vijay |
zhopudey
18:10
None! ![]() ![]() Hey guys, which wire do I use for this? |
audio_engr
20:48
Hey Zhopudey: Having a look at your choice of passive components, you could have ordered the Luminous Audio Axiom Single-input / Single-output passive using high quality Noble Dual pot with a choice of Holco resistors as Standard or the Caddock as an upgrade and nice RCAs. Not too expensive at USD 160 + shipping for the Caddock resistors which sound much, much better than the Standard Holcos. link: ![]() Well - its too late now. Maybe next time..... |
Savyasaachi
21:27
Go for basic teflon coated copper wire with about 14 to 20 strands for each conductor. basically look for a shielded 2+1 wire. should be thin and flexible. u are pushing very little current through these wires..a fraction of an amp.. so a wire rated at 1 amp is way more than enough. |
Savyasaachi
22:29
Here is a pic of the ALPS in my amplifier. ![]() [Beitrag von Savyasaachi am 30. Jul 2007, 22:30 bearbeitet] |
zhopudey
05:15
erstellt: 31. Jul 2007, ||||
@audio_engr, I'll keep the axiom in mind when I feel the need to upgrade ![]() @saachi, could you please post a bigger pic? ![]() |
Savyasaachi
05:28
Here you go. ![]() Don't know how well you can make it out. You should be able to find the wire in any cable shop. |
Amp_Nut
05:37
I am not sure that the wiring is correct ... |
zhopudey
06:00
He's got me all confused as well ![]() ![]() |
Savyasaachi
06:08
The farthest part is the ground and you can see that the shielding from the two wires are shorted. the middle two are the output for left and right channels and the nearest wires(in the pic) is the input. The wiring is perfect. What makes you think the wiring is not correct amp nut? ![]() [Beitrag von Savyasaachi am 31. Jul 2007, 06:08 bearbeitet] |
Savyasaachi
06:31
looking at the link, it is the same as my wiring. I have no issues whatsoever with my setup. runs flawlessly and even the shielding works like a charm, especially considering that the wires run right next to a 650VA EI core transformer. [Beitrag von Savyasaachi am 31. Jul 2007, 06:33 bearbeitet] |
Amp_Nut
10:16
Savyasaachi said:
It appears that you have 2 separate shielded cables. These are best deployed so that each cable ( each cable consists of a shield + Black + red conductor ) carries the signals ( To & return ) of the same channel. This will avoid Cross Talk ( ie signal of 1 channel intefering with the other channel. ) You have however shared each cable with both channels. Ofcourse will work, but what i have mentioned above would be better practice IMHO. |
zhopudey
10:44
#25
I was thinking of keeping all 8 cables separate. Would that be ok? Ohh and btw, what is the easiest method of testing this preamp, without connecting it to my amp and speakers? Can I use a dmm to test it? [Beitrag von zhopudey am 31. Jul 2007, 10:48 bearbeitet] |
Savyasaachi
14:10
#26
aaah...u mena the ground cable right? hmm..yes..but that innvolved running another cable or rather even a 4 core and the cable thickness would have been too much and unwieldly to route. Like you say, this works pretty well. Ultimately, the two channels would have to share the ground pin on the pot so that nullifies the extra cable run. |
Savyasaachi
17:42
#27
Or do you mean that i should have used one cable(ground+red and black) for one channel. red for input black for output and the ground to one of the ground pins and repeat the same for the other. Hmm..yes, that might work. But then again. at the input side, meaning the RCA, they share the same ground and as well on the crosover board, so how much of a difference that would make is questionable. Saachi |
ani
04:38
#28
erstellt: 01. Aug 2007, ||||
The purpose of twisted pair shielded wire is to reduce cross talk between channels and to reduce the EMI pick up by the wires plus cancellation of any picked up signals. For twisted pair to function the pair should carry the balanced signal ie signal of the same channel, one wire carrries the opposite of the other ![]() By using one wire each from both the cables you have made the life difficult for the twisted pair and cross talk due to induction will be maximum, one may get better result by using unshielded hookup wires. the common ground has no effect on cross talk in this case, provided the connection to ground is not very resistive. Regards Ani [Beitrag von ani am 01. Aug 2007, 04:39 bearbeitet] |
Savyasaachi
04:50
#29
You mean to use the twisted pair for one channel like in red to signal and black to ground? |
Savyasaachi
05:20
#30
Just a thought. To truly avoid crosstalk, shouldn't you have a dual mono(in one chassis) or two monos? |
ani
06:18
#31
Can use the red for the wiper, black for the input and shield for earth or common. In a passive pre the weakest link is th pot where maximum cross talk can occur.. The second culprit can be the cables and sockets. So dual mono or mono might be an overkill. Regards Anil |
Savyasaachi
06:34
#32
Then i would noty be able to use twisted pair in such a config. I would have had to use individual wires..single core. Else the input and output RCAs should be very close to each other. Since my input to the pot is coming from a 2pole 6 way switch there is no way to cooncet it in the fashion that you suggest by using a twisted pair. Will the concept in mind though. Besides, i thought twisted pair were used to isolate crostalk between other twisted pairs. Since we only have one single pair of twisted pair, i still don't get how the signal gets affected. |
ani
06:55
#33
Cross talk between two channels (L & R) is what we are trying to reduce by going in for mono dual mono etc. Input to output you can have leakage which is negligible compared to the direct path you are creating through the pot. |
zhopudey
07:34
#34
Savyasaachi
14:09
#35
If i understood correctly, that kinda wiring is what ani meant. |
ani
17:46
#36
You are right Sachi |
zhopudey
13:48
#37
erstellt: 04. Aug 2007, ||||
Presenting the UBER GHETTO PRE-AMP ![]() ![]() ![]() ![]() ![]() I have to get a proper box (and better wires), and heat-shrink sleeving. This was just for testing purposes ![]() ![]() BTW, for the sockets, the center pin is +ve, and the side pin is -ve, right? |
zhopudey
04:03
#38
erstellt: 05. Aug 2007, ||||
Guys, I'm wondering how I managed to get the connections wrong ![]() ![]() Also, my dmm showed a slight difference in both the channels. Isn't Alps supposed to be a pretty good pot? |
Help! I need some components. benkenobi am 28.06.2005 – Letzte Antwort am 01.07.2005 – 11 Beiträge |
need help ! plasma am 23.04.2004 – Letzte Antwort am 12.06.2004 – 17 Beiträge |
Need help for buying Turntable philipmorris am 02.11.2005 – Letzte Antwort am 13.11.2005 – 12 Beiträge |
Need your help, folks ! sandeep am 23.06.2005 – Letzte Antwort am 24.06.2005 – 13 Beiträge |
Need help with placement zhopudey am 23.01.2007 – Letzte Antwort am 07.02.2007 – 17 Beiträge |
Finalished Speakers, need help deciding Amp. zhopudey am 27.06.2007 – Letzte Antwort am 07.07.2007 – 46 Beiträge |
Help : Mini Compo Systems V/s Seperate Components hemant3003 am 04.01.2005 – Letzte Antwort am 05.01.2005 – 6 Beiträge |
21w8555-01 need help... am 15.03.2004 – Letzte Antwort am 15.03.2004 – 2 Beiträge |
Need help in choosing speakers trivisingh am 25.01.2005 – Letzte Antwort am 11.02.2005 – 25 Beiträge |
Help For enhancing existing system Jai am 09.12.2004 – Letzte Antwort am 27.12.2004 – 3 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 2 )
- Neuestes Mitgliedjuli7994292
- Gesamtzahl an Themen1.558.317
- Gesamtzahl an Beiträgen21.699.604
