HIFI-FORUM » English » Stereo (Engl.) » Hifi kit rack | |
Hifi kit rack+A -A |
Krish
13:04
erstellt: 15. Feb 2005, |
Guys, I'm contemplating on getting a good quality,vibration isolated HiFi rack made. Manek,Arj,Bigears,Joyinhifi,Prithvi Please share your thoughts. Do any of you have designs or know sites/sources on the net that I get dope from? Krishnan |
Manek
13:14
I'm using a lovan rack....I bought mine from mahendra dave,oceanic, pune. Manek. |
big-ears
13:32
Am currently using a heavy duty custom made ply rack with plenty of bracing all around to take care of the vibrations. Not as glamorous as the audiophile racks available, but quite effective. |
Nagaraj
15:38
Hi Krish, TNT-Audio on the web has a good section on DIY stands. Here's the link: ![]() Regards, - Nagaraj |
Prithvi
16:09
Hi! Krish & Nagaraj, Pls dont try the TNT rack, Murthy & I tried it and its horrible and wobbly. Waste of time and money. Rgds Prithvi |
Manek
16:20
Prithvi, I would not call it waste of time and money. The good part is that you built it and found out it did not work for you and these are learnings. Did you find out why it was so wobbly ? any mods you would recommend to make it less wobbly and more effective ? Manek. |
Prithvi
18:12
Yes Manek it was learnings, the designs is at fault itself, we actually built three racks and not one. We also strengthend the poles too, but that did not make a difference. We also made it of thicker platforms, same story. Actually we used much better materials without any success. If any one wants to buy these from us pls let us know, we can send them in CKD form. Rgds Prithvi PS: What type of music u listen to? Curious. |
Manek
05:44
erstellt: 16. Feb 2005, |
I listen to jazz of the 50'60 and early 70's. Western classical(syphonic and concerto's mostly) and a little bit of opera. Sinatra, tonny bennet and music from broadway. Thats my poison. Manek. |
Arj
06:20
Prithvi, Have you tried hollow Brass Pipes filled with Sand along with Granite shelves ? upto 2 shelves it is pretty good ! (as the no of shelves increases this does get a bit unsteady). better option is to use Thick pipes with not so thick platforms and use teak wood slabs with a cork base on top of the platforms.. Anyways you seem to have experimented with this quite a lot In india we do have the option of having a Pagoda type of rack made using Teak/Honne or mahogany with good brass Bracing, which does a very good job as well. I personally use Granite slabs on the floor with DH Cones/squares for the CDP and Brass cones for the Amp..not the best, but gets the job done BTW, pardon my ignorance, but could you give an introduction to Mr Murthy ? have heard his name in this forum but am not sure as to who he is !
Manek
06:31
I can definately vouch for the granite slabs and cork combo as I use it for my CDP and amp on the rack and it does the job extremely well ![]() My speakers are on cadence stands, so thats taken care of them. Manek. |
ani
06:52
I too tried TNT rack and found them to be woobly if assemble as per their plan. The problem was isolated to rubber washers and solution I found is not to provide rubber isolation washers for the top and bottom shelves, they have to be tightened well so that a closed structure is formed and the shelves in beteem them floates freely on foamed EPDM spacers. The top shelf is used by my turntable with its own isolation platform and the bottom is for power plugs and filters. My rack was made from 20mm OD brass threaded rod and 40mm OD Brass nut. The shelf is made out of 20mm MDF with both sides laminated with 3mm beech wood ply and real wood liping finished in matte mealamine. End result is OK but not worth the time and money ! |
ani
06:57
forgot the most important change used 4 legs instead of teh recomended 3. With 3 legs I could never get it stable ![]() |
Arj
07:11
That I will heartily agree..it is meant for Die Hard DIY folks..not for people pressed for time ![]() |
Krish
07:03
erstellt: 18. Feb 2005, |
Any recommendations wrt readymade stands ? Are any of the good ones available locally in Mumbai ? Cheers Krishnan |
Manek
09:10
krish...as I mentioned I bought my lovan rack in pune. It came in kit form and is most easy to assemble. The kit is also quite compact. My dad and i put it up in 15 minutes. Another friend of mine bought a very decent rack from soundsmiths, a year ago. Manek. |
Getting a stereo mini system from USA jeetu_AVFreak am 30.09.2008 – Letzte Antwort am 01.10.2008 – 5 Beiträge |
Any views on the Roksan Kandy MKIII Krish am 11.01.2005 – Letzte Antwort am 12.01.2005 – 6 Beiträge |
Manek and Arj needed cheraz am 22.06.2004 – Letzte Antwort am 27.07.2004 – 47 Beiträge |
Do you know these cables? Webon am 22.10.2003 – Letzte Antwort am 15.12.2003 – 58 Beiträge |
Share your thoughts with me! Shaman am 19.09.2003 – Letzte Antwort am 07.12.2010 – 19 Beiträge |
Taking the plunge : sonodyne speakers - please advise! trivisingh am 26.02.2005 – Letzte Antwort am 01.03.2005 – 13 Beiträge |
panasonic NVVP-30-EC-S ojoi am 08.12.2004 – Letzte Antwort am 09.12.2004 – 3 Beiträge |
Help on Car speakers cheraz am 03.10.2005 – Letzte Antwort am 07.10.2005 – 20 Beiträge |
Harman Kardon v/s NAD benkenobi am 09.02.2005 – Letzte Antwort am 09.02.2005 – 9 Beiträge |
Buying on the Net purnendu am 29.04.2005 – Letzte Antwort am 25.08.2005 – 11 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.520 ( Heute: 3 )
- Neuestes MitgliedElectroGehirn
- Gesamtzahl an Themen1.558.377
- Gesamtzahl an Beiträgen21.700.986
