INFO ON PROAC STUDIO 130 & 140.
Prithvi
#1 erstellt: 03. Mrz 2005, 19:04
Hi! Guys,
Some info on the new ProAc Studio 130 & 140 models for you ProAc fans out there.
The Studio 130 replaces the award winning Studio 125 and has taken two years to bring to market. This period was spent re-designing the slimmer and stiffer cabinet, changing the port routing from the rear to the base of the cabinet/plinth and investigating and testing many different combinations of drive unit construction and crossover component improvements.
The Cabinet
This has been redesigned with slimmer and shallower proportions to aid dispersion and is also more rigid. The floor porting now loads the reworked bass driver which features a new chassis and motor assembly, this design combination giving a faster, cleaner bass.
The new 1" dome tweeter which replaces the previous 3/4" dome is similar to those used in their higher-end models and the two units are seamlessly mated via a new crossover network which is split for optional bi-amping and bi-wiring. Every aspect of the Studio 125 has been improved upon with the new Studio 130 and the sound is now nimbler, faster and more open with greater efficiency and detail whilst retaining the trademark ProAc natural sound. The reduced cabinet proportions make it easier to blend in with both traditional and modern décor with a range of four veneer options.
Specifications Studio 130
Dimensions
Height on plinth with coned feet 965mm
Depth 240mm
Width 190mm
Bass Driver
New 165mm ProAc unit with coated cone, raised spider assembly for greater linearity and large shielded magnet assembly
Tweeter
ProAc 25mm coated silk dome with special coating and inner damping
Crossover
HQ network using the finest components with option for bi-amping/bi-wiring and utilising oxygen free cable
Finishes
Black Ash-Mahogany-Cherry-Maple
Mode
Floor standing with spikes
Recommended Amplifiers 15-150 watts
Frequency Response 25 Hz - 30 KHz
Sensitivity Nominal Impedance 88.5 db linear for 1 watt at 1 metre
8 Ohms
Weight 16 Kgs each with spikes and plinths
Grille Acoustically transparent crimplene
The ProAc Studio 140
Developed from the Studio 130, the 140 has slightly larger cabinet dimensions, an additional bass driver and a reworked crossover network. The sensitivity is high at 91db with a nominal impedance of 4 Ohms. These enhancements produce a significant increase in weight, scale, soundstage and bass power handling making this model an ideal choice for both two channel and home theatre systems where more volume and or sensitivity are required. All these benefits are housed in a package which admirably demonstrates the high build quality that has become synonymous with the ProAc brand.
Specifications Studio 140
Dimensions
Height on plinth with coned feet 1040mm
Depth 280mm
Width 190mm
Bass Driver (Two) New 165mm ProAc unit with coated cone, raised spider assembly for greater linearity and large shielded magnet assembly
Tweeter ProAc 25mm coated silk dome with special coating and inner damping
Crossover HQ network using the finest components with option for bi-amping/bi-wiring and utilising oxygen free cable
Finishes Black Ash-Mahogany-Cherry-Maple
Mode
Recommended Amplifiers 15-250 watts
91db linear for 1watt at 1 metre 4 Ohms
Weight 20 kgs each with spikes and plinths
Rgds
Prithvi
Geschützter Hinweis (zum Lesen markieren):
[Beitrag von Prithvi am 03. Mrz 2005, 19:12 bearbeitet]
Arj
#2 erstellt: 04. Mrz 2005, 09:35
Hi Prithvi
are these priced above the 125 or in the same range ?
rgds
Prithvi
#3 erstellt: 04. Mrz 2005, 17:53
way above man
NO MORE DEMOS OF PROAC STUDIO 125
Prithvi am 02.03.2005  –  Letzte Antwort am 02.03.2005  –  3 Beiträge
Tough Comparison Linn Ninka vs ProAC Studio 130
vpriyan am 20.12.2006  –  Letzte Antwort am 21.12.2006  –  9 Beiträge
PROAC D15s finally on demo at ABSOLUTE PHASE.
Prithvi am 25.02.2005  –  Letzte Antwort am 01.03.2005  –  15 Beiträge
ProAc D100
Prithvi am 28.01.2005  –  Letzte Antwort am 30.01.2005  –  3 Beiträge
Proac tweeters
thebrightonian am 24.05.2005  –  Letzte Antwort am 26.05.2005  –  7 Beiträge
Urgent...any info on Klipsch RF3
abhi.pani am 21.03.2005  –  Letzte Antwort am 21.03.2005  –  6 Beiträge
Help on Info needed : Stereo amplifier fuse
Ronnie22 am 17.09.2006  –  Letzte Antwort am 18.09.2006  –  11 Beiträge
Request Adive & Info On Upsampling DVD Players
Amp_Nut am 26.06.2007  –  Letzte Antwort am 21.07.2007  –  22 Beiträge
Really sad too day.
Prithvi am 03.03.2005  –  Letzte Antwort am 04.03.2005  –  3 Beiträge
ProAc Responce D2 with Leben
Prithvi am 08.04.2008  –  Letzte Antwort am 08.04.2008  –  4 Beiträge
2005
  • Registrierte Mitglieder928.520 ( Heute: )
  • Neuestes Mitgliedtusahivasat
  • Gesamtzahl an Themen1.558.364
  • Gesamtzahl an Beiträgen21.700.829
