HIFI-FORUM » English » Stereo (Engl.) » Would a Mini-compo be a good source? | |
Would a Mini-compo be a good source?+A -A |
Neutral
09:08
erstellt: 15. Jun 2005, |
My brother has a Sony DVD based mini-compo purchased for Rs 19,500 a few months ago. He is planning to migrate and may be willing to sell it to me. Would it make sense for me to buy this mini-compo and use it as a source for my power amp and bookshelf speakers. (Sony DVD players have a good reputation in the consumer market.) Will the mini-compo's volume control on remote and other features work when I am using an external power amp? Anyone who has tried something like this please let me know your experiences. |
pramod
18:06
definetly not simply because the analog output is not variable ones which u find on denon and marantz cd players where u can connect them directly to power amps. u definetly need a pre amp in between ur minicompo and ur power amp and yes this minicompo will make a good source though. |
Arj
15:36
erstellt: 16. Jun 2005, |
if the Compo has a pre amp out (I doubt it) then yes you could do it. else you cannot as you would be feeding the ouput of the power amp of the Compo to your Poweramp..Not Good ! quality wise you will be better off either buying a philips DVD player with a passive pre amp Or connecting your bookshjelves directly to the Mini Compo.. |
Sonic_Master
04:22
erstellt: 17. Jun 2005, |
from sony no way just get some good cdp and then go for some good bookshelf.. well tell me what speakers do u have..? |
abhi.pani
05:11
What is the difference between "Line Out" and "pre-amp out" ? ![]() |
benkenobi
05:29
as i understand it ..both are the same.. |
abhi.pani
05:36
I use my Sonodyne Ampli deck as pre for my sonodyne Integrated amp. But when I connect my Sonodyne Ampli deck to my sonodyne Integrated Amp through the line out, I dont get volume control facility at the deck level (I mean the volume knob of the ampli deck becomes ineffective), it is only through the volume control of the int amp that helps me to control the volume. |
abhi.pani
05:37
I use my Sonodyne Ampli deck as pre for my sonodyne Integrated amp. But when I connect my Sonodyne Ampli deck to my sonodyne Integrated Amp through the line out, I dont get volume control facility at the deck level (I mean the volume knob of the ampli deck becomes ineffective), it is only through the volume control of the int amp that helps me to control the volume. ![]() ![]() ![]() If both Line-out and pre-out are same then I should be able to control the volume from my ampli-deck right ??? ![]() |
benkenobi
06:10
Yes..u should be able to control the volume(exactly like how u control the volume from the pre in a pre_power setup. |
abhi.pani
06:29
but it doesnt happen that way atleast in my system. The volume control does not work in my ampli-deck if it is connected to an external amp through line-out. Does that mean that the line-out is not the same as pre-amp out ????? ![]() |
Sonic_Master
06:36
the diff between line out and the preamp out is that line out`s output signal will be having more amplitide than the preamp out. If you connect the preamp out the quality will be very good but if you use line out the quality will not be as good as preamp out. But if you are having multiple amplifiers connected to a pre source then in order to feed to multiple amplifiers you need more power to drive them so many use lineout only for that purpose. The reason why lineout will not give the best performance because there will be another amp stage which is driven by ics( most of them ) so the quality will not be good. ![]() |
pramod
08:16
i think sony will make a good source.the aspect which will make or break a system is the loud speaker.assuming that u have a good speaker and a power amp simply go for a good preamp for the time being then later try upgrading ur source(minicompo)if u dont like it.we r talking about a technology which is nearly 20 yrs old so the differece between different source is marginal there was an thread in HeadFi where a guy could hardly tell a difference between his sony DVD player(basic model) creek and conrad johson cd transport and dac!!!! i know i know (no flame wars please)sony do make a good digital players i am not trying to prove that all cd or dvd players r the same.what i fell is going for a another player wont change the quality of the sound so much to make ur jaws drop. final line decide whats best for u and for ur wallet. |
abhi.pani
08:29
Neutral, Are you interested in the mini compo only because of its DVD player ?? If so then I dont think it makes sense to spend 19.5k for it because you will anyway get much better DVD players for that price.... If you are thinking in terms of multiple benefits from the mini-compo then it makes sense.... ![]() |
Neutral
09:18
Hi Folks, Thanks for the torrent of replies. I would like to clarify a few points. My objective in considering a mini-compos is that I will obtain the following: 1. DVD player 2. Tape deck 3. Radio 4. Remote control My idea was to take the output of the headphone out from the mini-compo. Can you please tell me the following: 1. Do I get the benefit of volume control on remote? 2. Will I be able to use the speakers of both the mini-compo and my amp-bookshelf combo simultaneously (for greater sound output or multi-room capability)? 3. Will the sound quality be acceptable? Is the headphone out a preamp out? Is there also a line out facility and for what is that used? Well Abhi, if I don't get a discount on the player, I certainly won't take it. But otherwise, I guess it is worth considering for its flexibility. |
pramod
09:39
oops! sorry my mistake i thought it was a free give away from ur brother ![]() |
ravi
07:35
erstellt: 19. Jun 2005, |
If you use the headphone out, you have lost all that there is to lose in terms of sound quality already. There are simply too many stages in the path inside a minicompo before it comes out on headphones - including DSP processing and analog amplification. Definitely not a hi-fi setup. If you need the sources provided by minicompo, you need to take the line-out and have external pre-amp for volume control etc. Note that even line-out would not be of very a good quality - the source selection switches and buffers do contribute to a lot of distortion and noise in commercial systems. |
Neutral
07:39
erstellt: 20. Jun 2005, |
Ravi, If it's not too much trouble, could you tell me the stages that are there in a mini-compo. I don't understand the internal electronics at all. What I get from what you have said, it that a mini-compo won't make a good source. I'll ask Junia if he can get me a Pioneer DV-578-A-S DVD player. |
ravi
13:38
Neutral, the typical audio path in commercial minicompos is - Sources -> buffers -> source switching -> preamp -> AV processor (vol contrl, equalizer, effects) -> power amp -> speaker out or headphone out As you can see a headphone out is not much better than the high level speaker output. The line out is tapped just before preamp or AV processor (and may be routed thru an additional IC stage before giving it out as Sonic_master clarified), hence excludes the volume control. Even if there were a line out (which Sony minicompo would not have), the source buffers and switching could still degrade the quality, if audiophile quality is what we are looking for. After having invested in good quality power amps and bookshelves it is a pity to use a headphone output - my suggestion would be to continue on separates rather than spending a lot on a minicompo that could degrade overall system performance. |
Neutral
14:23
Thanks a ton Ravi for enlightening me ![]() In separates, I have noticed that the headphone jack is on the preamp, not the power amp. BTW, is there a way that I could use both the mini-compo and my speakers simultaneously for sound reinforcement or multi-room capability? |
ravi
11:51
erstellt: 21. Jun 2005, |
Neutral, To answer your question - the headphones do require a few hundred milliwatts, something that cannot be provided by the preamp stage directly. In older minicompos the power output stage is tapped out, stepped down using resistor dividers and given to headphone - crude, but works. In newer ones there would be a separate small "power" amplifier for headphones providing the few hundred mw required. Infact in separates the headphone jack on the preamp would be driven by a small power amplifier that gets its input from the preamp-output. |
Neutral
12:41
Ravi, how do you know so much? Could you point me to a website that explains such useful fundas of electronics. Can I ask you one more thing. Does a dual headphone adaptor degrade sound quality. I am using one with my current computer source - one output to the power amplifier and the other to a Sony headphones. |
ravi
12:59
Neutral, I know a little only cos I studied electronics, its one of my hobbies and I work in a field closely related. However its still not authoritative knowledge, just general awareness of systems. The best place to figure out internals of audio eqpt is their service manuals - these are tough to obtain, but have a wealth of information and sometimes, some surprises in store too! So if you are really interested in internal electronics you could write to the manufacturers for service manuals. Dont know much about dual headphone adaptors, never used them. So cant help you there! |
pramod
13:28
u dont require hundred mw of power per channel to drive headphones unless you are using professional headphones like sennheiser ,akg,beyers etc.these cans do require lot of power so require a headphone amplifier if u intend to use them home.pcdp or for that matter desk top cdp have opamps to drive headphones the pcdp of todays have just 5mw+5mw(damm sony ![]() ![]() I doubt a dual headphone adapter will degrade sound quality unless it is made up of cheap quality connecters BTW get philips headphones they r much better than sony headphones ![]() |
benkenobi
13:34
i agreee that Phillips is on eof the better brands available..have been using one myself for the past 5 years and no problems whatsoever... |
Neutral
15:55
#25
erstellt: 06. Sep 2005, |
Finally got a chance to use a mini-compo as a source ![]() Then I tried out the line out jacks of the Sony. They too worked nicely and theoretically should give the cleaner output. The difficulty here is that I only have a power amp. So I am unable to control the volume. My overall take is that mini-compos suffer more in terms of weak speakers while their signal processing inputs are of acceptable quality. However, dynamics and finer details won't be available using any mini-compo ![]() |
square_wave
09:25
#26
erstellt: 09. Sep 2005, |
The sound will never be clean from a head phone jack. Borrow a cd player from somebody and do a comparison.You will know what you are missing. Even line-outs from mini combos are horrrible to say the least.Mini combos are the most compromised sound systems out there.........Even the selector switch system on a high-end pre amplifier will cost more than the total cost of the entire electronics inside a mini combo.........there is a reason for everything.... |
A poor mans source Magma79 am 06.07.2009 – Letzte Antwort am 26.09.2009 – 59 Beiträge |
Advise to a beginner arun_rookie am 26.09.2004 – Letzte Antwort am 27.09.2004 – 6 Beiträge |
What is a Good Speaker? SDhawan am 04.10.2004 – Letzte Antwort am 06.10.2004 – 3 Beiträge |
A good solid state amp G_S_Madhav am 08.10.2008 – Letzte Antwort am 13.10.2008 – 65 Beiträge |
a good stereo system kishore am 31.07.2004 – Letzte Antwort am 12.08.2004 – 6 Beiträge |
A good power conditioner buzzer am 02.03.2006 – Letzte Antwort am 19.03.2006 – 23 Beiträge |
A Good Stereo? viren am 19.03.2008 – Letzte Antwort am 31.03.2008 – 70 Beiträge |
Help : Mini Compo Systems V/s Seperate Components hemant3003 am 04.01.2005 – Letzte Antwort am 05.01.2005 – 6 Beiträge |
What is a good CD Changer Max3 am 12.11.2003 – Letzte Antwort am 25.11.2003 – 10 Beiträge |
Good cost effective options as a transport square_wave am 20.03.2009 – Letzte Antwort am 02.04.2009 – 50 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 1 )
- Neuestes MitgliedIngerlise_Spoor
- Gesamtzahl an Themen1.558.296
- Gesamtzahl an Beiträgen21.699.183
