HIFI-FORUM » English » Stereo (Engl.) » How do i use my stereo as PC speakers | |
How do i use my stereo as PC speakers+A -A |
morgasm_69er
02:32
erstellt: 18. Feb 2004, |
hey guys... i would just like to ask a question how would i go about putting music from my computer directly onto a cassette tape (audio) i need to do this so i can listen to music in my car. i have tried (unsuccessfully) to hook my stereo up to my computer using a cord that connects the speakers hole in my PC to the headphones hole in my stereo. ive done this before but i had to first put the music onto a CD, which is a waste because then the CD is useless because i barely listen to CDs I know this is possible because my friend used to use his cassette player as speakers...and i assume that if you could get your cassette player to play your computer sounds you could also record them also Please help me on this issue...thanks ![]() |
Arj
02:55
Does your stereo have a "recorder Hole" ? ;D The headphone jack is an output and you definitely cannot record that way as sound is supposed to Come out from it ..not go in. If your stereo as and "Aux in" then all you need to do is connect you pc to this and record the same wsa as you record from a CD If you do not have that option , Usually the Microphone in (mic in) would be the point for sound to go in and connecting that to the headphone out of your PC soundcard should be good enough. BTW CDRW's may not be a bad Idea as you can keep erasing them that way and reuse the cd..but then your stereo must recognize that format.. |
morgasm_69er
03:06
thanks for the reply Arj... it turns out my stero system is not as good as it looks the piece of crap doesnt have mic compatibility or a aux in plug... (that i could see) i doubt it would be able to recognize cdrws either... ill try it on my girlfriends stereo system though... thanks again Arj |
Manek
06:59
what you can also do is get a wire with the EP pin(headphone) at one end and RCA at the other. Shove the RCA part into the line in of the tape deck and start to record. another way to record is to put the RCA cable from the PC into the aux in RCA at the back of the amp. Take another cable from the aux out of the amp and put it into the line in of the tape deck this way you will be able to hear what is being recorded. Either way is OK. manek. |
how do i? inititis2 am 05.06.2005 – Letzte Antwort am 14.06.2005 – 8 Beiträge |
how to wire my speakers into my amp? pumpanani am 14.12.2004 – Letzte Antwort am 15.12.2004 – 2 Beiträge |
how do i ludlow859 am 16.05.2004 – Letzte Antwort am 17.05.2004 – 2 Beiträge |
How do I repair my tube amp? hydrovac am 17.07.2013 – Letzte Antwort am 19.07.2013 – 2 Beiträge |
How Do I Improve Image Height Amp_Nut am 25.07.2006 – Letzte Antwort am 19.09.2006 – 36 Beiträge |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
What Cables to use ?? abhi.pani am 19.01.2005 – Letzte Antwort am 19.01.2005 – 6 Beiträge |
How do you listen to Music ! Arj am 02.11.2005 – Letzte Antwort am 23.11.2005 – 51 Beiträge |
Stereo and Computer Speakers Alexb123 am 12.01.2004 – Letzte Antwort am 12.01.2004 – 6 Beiträge |
How much atmospheric humidity with my musik equipment? IZMINE am 10.09.2003 – Letzte Antwort am 22.09.2003 – 6 Beiträge |
2004
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.513 ( Heute: 5 )
- Neuestes Mitgliedkaiserstuhlbruno
- Gesamtzahl an Themen1.558.354
- Gesamtzahl an Beiträgen21.700.540
