HIFI-FORUM » Car-Hifi » Car-Hifi: Subwoofer/Gehäuse » TSP Daten für Woofer | |
TSP Daten für Woofer+A -A |
RoadKill406V6
#1 erstellt: 17. Mai 2005, 13:08 | |
Hallo! Ich bräuchte für meine 2 SoloBaric S12L7 die Tsp Daten, zum Gehäuse berechnen! Finde allerdings keine Seite im Net! Und auf kicker.com ist sowas auch nicht zu finden! Hoffe, ihr könnt mir weiterhelfen! mfg |
DoctorSid
#2 erstellt: 17. Mai 2005, 13:22 | |
Ich schließe mich gleich an. Suche die Parameter für einen Crunch DS-10. |
MiaWallace
#3 erstellt: 17. Mai 2005, 13:57 | |
Company: Kicker Model: S12L72 Available = Yes Last update: 03-Jun-2001 Type: Standard one-way driver Comment: Solo-Baric series Shape: Square Piston Type: Planar (flat) Piston: Square cone. Fs = 29,1 Hz Qms = 8,71 Vas = 93,28 liters Mms = 205,6 g Xmax = 12,7 mm Xmax (parallel) = 12,7 mm Xmax (series) = 12,7 mm Sd = 671, sq.cm Qes (parallel) = 0,456 Qes (series) = 0,456 Re = 1,62 ohms Re (parallel) = 0,81 ohm Re (series) = 3,24 ohms Le (series) = 1,29 mH Z = 2, ohms Z (parallel) = 1, ohm Z (series) = 4, ohms BL (series) = 16,34 Tm Pe (series) = 750, watts Qts (parallel) = 0,433 Qts (series) = 0,433 1-W SPL (series) = 89,4 Acoustic data: Not present Kicker Stillwater Designs 5021 North Perkins Rd. P.O. Box 459 Stillwater, OK 74076 U.S.A. Tel: 800-256-5425 405-624-8510 Fax: 405-377-3272 Website: www.kicker.com Company: Kicker Model: S12L74 Available = Yes Last update: 03-Jun-2001 Type: Standard one-way driver Comment: Solo-Baric series Shape: Square Piston Type: Planar (flat) Piston: Square cone. Fs = 31,2 Hz Qms = 8,93 Vas = 89,42 liters Mms = 186,3 g Xmax = 12,7 mm Xmax (parallel) = 12,7 mm Xmax (series) = 12,7 mm Sd = 671, sq.cm Qes (parallel) = 0,582 Qes (series) = 0,582 Re = 3,085 ohms Re (parallel) = 1,543 ohms Re (series) = 6,17 ohms Le (series) = 1,29 mH Z = 4, ohms Z (parallel) = 2, ohms Z (series) = 8, ohms BL (series) = 19,66 Tm Pe (series) = 750, watts Qts (parallel) = 0,547 Qts (series) = 0,547 1-W SPL (series) = 89,4 Acoustic data: Not present Kicker Stillwater Designs 5021 North Perkins Rd. P.O. Box 459 Stillwater, OK 74076 U.S.A. Tel: 800-256-5425 405-624-8510 Fax: 405-377-3272 Website: www.kicker.com --------------------------------------------------------- Company: Crunch Model: DS10 Available = Yes Last update: 20-Feb-1998 Type: Standard one-way driver Shape: Round Piston Type: Cone Fs = 35,3 Hz Qms = 8,228 Vas = 51, liters Cms = 0,311 mm/N Mms = 65,35 g Xmax = 4,496 mm P-Dia = 205,7 mm Sd = 334,2 sq.cm Qes = 0,263 Re = 3,6 ohms Z = 4, ohms BL = 14,1 Tm Pe = 250, watts Qts = 0,255 no = 0,792 % 1-W SPL = 91,19 dB Acoustic data: Not present Crunch Audio Products, Inc. (API) 2510 Commonwealth Ave. North Chicago, IL 60064 USA Tel: 800-635-4380 847-578-0000 Fax: 847-578-0001 Email: techsupport@api-us.com Hoffe geholfen zu haben, mfg |
DoctorSid
#4 erstellt: 17. Mai 2005, 17:21 | |
Sehr sogar! Recht herzlichen Dank! |
RoadKill406V6
#5 erstellt: 17. Mai 2005, 20:20 | |
mir auch! DANKE |
Focal-Woofer, TSP jimichips am 21.01.2009 – Letzte Antwort am 21.01.2009 – 6 Beiträge |
tsp daten? schamsen am 06.06.2005 – Letzte Antwort am 06.06.2005 – 6 Beiträge |
TSP für JL - Woofer CYPRE$$ am 09.06.2005 – Letzte Antwort am 10.06.2005 – 3 Beiträge |
Hilfe bei TSP-Suche für Hertz Woofer LoW_TecH am 27.06.2015 – Letzte Antwort am 28.06.2015 – 4 Beiträge |
TSP Gahli19989 am 17.05.2008 – Letzte Antwort am 17.05.2008 – 2 Beiträge |
TSP Daten vom Xion eXtr3m2003 am 13.06.2005 – Letzte Antwort am 14.06.2005 – 8 Beiträge |
Berechnung / Woofer / Gehäuse / TSP MastaOlli am 20.12.2007 – Letzte Antwort am 27.12.2007 – 9 Beiträge |
Brauche TSP für Kove Zm12 V!RuZ am 24.10.2008 – Letzte Antwort am 25.10.2008 – 3 Beiträge |
TSP Pioneer TS-W3004SPL Woofer? Tony_Montana_VTI am 11.06.2008 – Letzte Antwort am 12.06.2008 – 3 Beiträge |
suche TSP Daten für einen Earthquake DBX10DR b3nn1 am 27.08.2005 – Letzte Antwort am 28.08.2005 – 2 Beiträge |
2005
- AN ALLE! wie richtig dämmen
- Bass richtig einstellen
- Registrierte Mitglieder927.004 ( Heute: 1 )
- Neuestes MitgliedFhiabakuehlschrank
- Gesamtzahl an Themen1.554.527
- Gesamtzahl an Beiträgen21.615.717
