Eonon D1001
fidibus42
#1 erstellt: 09. Feb 2011, 07:45
was ist hier von zu halten - Neu - 109 € bei Amazon
http://www.amazon.de...id=1297233232&sr=8-1
Eonon D1001 - einfach auf das Bild bei dem Link klicken
http://de.eonon.com/...VD-Player/D1001.html
Gerenal:
- Hi-Fi DVD Player
- Hi-Fi DVD Specification:
*S/N Rate: 100 Db (RCA)
*THD+N: 0.01%
*Frequency Response: 20Hz-20KHz
- Control Panel Night Illumination Function
- Built-In 5.1CH Audio Output
- 4×65W Surround Stereo
- EQ Effect: POP ROCK CLASS FLAT
- Auto-Memory Function
- Built-in LCD Clock Display and Adjustable Function
- Remote Control Function
- Built-In Cooling Fan
- Power Supply: DC 12V
- Max Current: 10A
- Install size: 180mm×165 mm×50 mm
- Net weight: 1.5kg
- Gross Weight: 2.2kg
- Built-in amplifier
USB/SD:
- Built-In USB Port/SD Slot
- USB Port:Can support soft drive such as USB flash drive, or MP3 player with maximum 32G compatibility, and Can support portable hard drive(Max 40GB).
- SD Card Port: Can support SDHC Card of maximum 32G compatibility
DVD:
- DVD OSD Language: English /German/Spanish/French/Portuguese/ Italian/Russian
- Audio/ Subtitle Language: English /German/Spanish/French/Portuguese/ Italian/Russian
- Compatible Format:DIVX5.0/AVI/DVD/DVD+R/DVD-R/DVD-RW/VCD/MP3/CD/CD-RW/JPEG
Radio:
- 30 Preset Stations (3*6FM+2*6AM)
- FM Range:87.50-108.00 MHZ, Increment:0.05 MHZ
- AM Range:522-1620 KHZ, Increment:9 KHZ
- Built-In RDS Function
Input&Output:
- One Radio Antenna Input
- One Aux In Port
- RCA Video Output
- RCA Audio FL/FR/RL/RR/Center/Sub woofer Output Total Weight : 3.5kg
Accessories
- 1 x Front Panel
- 1 x Remote control
- 1 x English&Germany Manual
- 1 x Power Cable
- 1 x AV Cable
- Others
[Beitrag von fidibus42 am 09. Feb 2011, 07:46 bearbeitet]
Fred._Freih._v._Furchen...
Gesperrt
#2 erstellt: 09. Feb 2011, 08:03
Elektroschrott
Sun-G
#3 erstellt: 09. Feb 2011, 08:12
Ja was jetzt?
fidibus42
#4 erstellt: 09. Feb 2011, 09:08
Naja,
wenn ich mir dann auch das Eonon D1203 für 199,- anschaue
4.3 Zoll Motorisierter Digital-Wide-Touchscreen Touch-Tasten AVI/DVD/VCD/MP3/CD Player Radio (AM/FM) Tuner USB SD IPOD schwarz
dann weiß ich nicht ob das alles Schrott ist
Zumidest scheint man modern und preislich aggressiv unterwegs zu sein
Gesperrt
#5 erstellt: 09. Feb 2011, 09:17
Das ist kein aggresiver Preis, Schrott kostet nunmal nicht viel. Modern
zuckerbaecker
#6 erstellt: 09. Feb 2011, 15:24
Audiklang
#7 erstellt: 09. Feb 2011, 16:54
hallo
was brauchst denn genau ?
türstopper ,briefbeschwerer was zum weitwurf üben ?
was für ein auto hast du ?
was willst du machen ?
was willst du ausgeben ?
Mfg Kai
[Beitrag von Audiklang am 09. Feb 2011, 16:57 bearbeitet]
SeppSpieler
#8 erstellt: 09. Feb 2011, 17:51
Bei dem kleinen Budged muss ein CD Radio her.
Da kannst davon ausgehen das es in 3 Jahren noch funktioniert, was ich bei solchen billig Teilen stark bezweifle.
mfg
Gesperrt
#9 erstellt: 09. Feb 2011, 18:12
Audiklang schrieb:
hallo
Nur dann wäre das Eonon D1001 paasend
fidibus42
#10 erstellt: 11. Feb 2011, 11:13
Habe mir das Pioneer 5200SD bei Saturn angesehenund dann online bei Amazon bestellt und hoffentlich wird alles gut für den Einstieg
[Beitrag von fidibus42 am 11. Feb 2011, 11:16 bearbeitet]
Gesperrt
#11 erstellt: 11. Feb 2011, 11:40
Und wenn du dann Probleme beim Einbau oder Anschluss hast, rufst du die Hotline von Amazon an
Eonon
Bombe_@ am 16.03.2008  –  Letzte Antwort am 28.07.2009  –  5 Beiträge
EONON Autoradios mit TouchScreen
Neyrox am 15.05.2009  –  Letzte Antwort am 15.05.2009  –  5 Beiträge
Eonon D1301 Erfahrung
DaChrisss am 09.02.2010  –  Letzte Antwort am 09.02.2010  –  3 Beiträge
Eonon E0851 Autoradio, weiss jemand darüber bescheid?
Kingwes am 24.12.2008  –  Letzte Antwort am 28.12.2008  –  13 Beiträge
Brauche eure Erfahrung und Hilfe
Eduu am 22.07.2010  –  Letzte Antwort am 23.07.2010  –  14 Beiträge
Fiat Uno Bj 89 Raido, Lautsprecher, Subwoofer und Verstärke Beratung benötigt
Yumakuru93 am 23.05.2012  –  Letzte Antwort am 23.05.2012  –  7 Beiträge
brauche Hilfe bei einsteigersystem polo/corsa
nik-stuttgart am 14.06.2011  –  Letzte Antwort am 15.06.2011  –  20 Beiträge
Einsteigeranlage - Was meint ihr dazu?
zunder34 am 17.04.2011  –  Letzte Antwort am 17.04.2011  –  3 Beiträge
passt der Verstärker zum Subwoofer!
maf1992 am 23.06.2011  –  Letzte Antwort am 20.08.2011  –  69 Beiträge
eure meinung zu magnat soudsystem
Paul92 am 10.07.2011  –  Letzte Antwort am 11.07.2011  –  6 Beiträge
2011
  • Registrierte Mitglieder928.828 ( Heute: 11 )
  • Neuestes Mitglied*Baramundi*
  • Gesamtzahl an Themen1.559.073
  • Gesamtzahl an Beiträgen21.716.868
