HIFI-FORUM » Car-Hifi » Car-Hifi: Kaufberatung » Komplette Anlange/ Skoda Octavia Kombi / 700 Euro ... | |
Komplette Anlange/ Skoda Octavia Kombi / 700 Euro max+A -A |
devilblast
#1 erstellt: 14. Nov 2014, 01:01 | |
Moin, was für einen Verstärker, also welche größe muss dieser haben um diese lautsprecher alle zu füttern möchte die zusammen ins auto haben Der sub ist halt schon selbst powered, bin ein bischen überfordert 1. Power Handling: Peak: 500 watts per pair / 250 watts each RMS: 130 watts per pair / 65 watts each Injection Molded Polypropylene (IMPP) Carbon Fiber patterned cone material UV Resistant Foam speaker surround 3/4" Silk Dome tweeter design High-temperature voice coil with Aluminum former Ultra Rigid Stamped Steel Basket with Chrome plating PVC magnet boot cover for protection Push and Insert spring loaded speaker terminals for maximum hold Mounting hardware and speaker grilles included 4 ohms impedance Frequency response: 46-20,000 Hz Top-mount depth: 2-9/16" Sensitivity: 89dB 2. Power Handling: Peak: 340 watts per set / 170 watts each side RMS: 90 watts per set / 45 watts each side Injection Molded Polypropylene (IMPP) Carbon Fiber patterned cone material UV Resistant Foam speaker surround 3/4" Silk Dome tweeter design High-temperature voice coil with Aluminum former Ultra Rigid Stamped Steel Basket with Chrome plating PVC magnet boot cover for protection Separate 12dB/octave passive crossover filter Push and Insert spring loaded speaker terminals for maximum hold Tweeter is Flush and Surface mountable with included adapters Mounting hardware and speaker grilles included 4 ohms impedance Frequency response: 70-20,000 Hz Top-mount depth: 2-1/4" Sensitivity: 78dB 3. Subwoofer Features: Dual 12" 4 ohm Zeus Series Subwoofers Power Handling: Peak: 1200W Total (600W Each Sub) Impedance: 4 ohms Rigid polypropylene cone & dust cap Foam surround UV treated to resist moisture and sun exposure 1.5" high temperature edge wound voice coil on aluminum former Illuminated subwoofer guards Amplifier Features: Built-in class AB amplifier Adjustable input voltage allows for easy installation with source unit Connection via RCA or high level inputs Low Pass Crossover: 40-200 Hz Bass Boost: 0-12dB High temperature extruded heat sink lg devilblast |
st3f0n
Moderator |
#2 erstellt: 14. Nov 2014, 02:10 | |
Der Thementitel ist nicht aussagekräftig genug. Wähle einen Titel, der das Thema kurz und zutreffend umschreibt. Beachte dies bitte auch bei später erstellten Themen.
Bitte passe den Threadtitel selbständig an. Danke, Gruß Stefan -Moderation- |
zuckerbaecker
#3 erstellt: 14. Nov 2014, 11:16 | |
Das sind - wenn überhaupt - die einzig relevanten Zahlen. Das ganze Geschwätz von Peak und Power kannst getrost mal vergessen! Sie sagen aus, das Dein Lautsprecher mit ca. 65 Watt belastbar ist und eine Impedanz von 4 Ohm hat Hat aber bei der Wahl der Endstufe auch net viel zu sagen. Du kannst einen Verstärker der 50 Watt RMS an 4 Ohm leistet genauso verwenden, wie einen der 100 Watt RMS an 4 Ohm leistet. Wichtig am Ende ist einzig und alleine die korrekte Einstellung der Endstufe. Um zu helfen sind weitere Informationen notwendig: Was GENAU sind das für Lautsprecher? Welches Fahrzeug ist es? Wo willst die Lautsprecher platzieren? Wieviel willst in eine Endstufe investieren? |
devilblast
#4 erstellt: 16. Nov 2014, 01:12 | |
Das sind lautsprecher von hifonics. http://www.sonicelec...Powered-Sub-Box.html http://www.sonicelectronix.com/item_68150_Hifonics-ATL693.html http://www.sonicelectronix.com/item_68146_Hifonics-ATL4CX.html Das Auto ist ein Skoda Octavia Kombi. 2 lautsprecher in die Vordertüren also in jede einen und hintere türen ebenfalls . und den sub in den kofferraum Für eine endstufe will ich eig nicht mehr als 200 Euro Danke für die antwort ! Lg |
deeepz
#5 erstellt: 16. Nov 2014, 01:47 | |
Okay... hast Du Dich schon JEMALS mit dem Thema Car Hifi beschäftigt? Sag jetzt nicht "Ja!" Wenn Du uns sagst was Du erreichen willst und wie groß Dein Budget ist, können wir Dir eine Empfehlung geben. Und da wird KEINER der von Dir genannten Artikel vorkommen. LG deeepz |
devilblast
#6 erstellt: 16. Nov 2014, 16:40 | |
Nein habe ich nicht ! Ich möchte gerne meinen skoda octavia kombi mit Musik beschallen. Ich möchte gerne so 4.1 lautsprecher . Soll ein Satter klang werden aber sollte nicht mehr als 700 Euro insgesamt werden lg |
st3f0n
Moderator |
#7 erstellt: 16. Nov 2014, 16:41 | |
Zum 2. Mal. Der Thementitel ist nicht aussagekräftig genug. Wähle einen Titel, der das Thema kurz und zutreffend umschreibt. Beachte dies bitte auch bei später erstellten Themen.
zuckerbaecker
#8 erstellt: 16. Nov 2014, 18:43 | |
Musik ist aber Stereo aufgenommen: http://www.park-koer...NatTec47.fol.001.gif Zur Wiedergabe werden zwei Schallquellen VOR den Ohren benötigt. Um den Bassbereich besser abzudecken wird ein Subwoofer verwendet, der unterhalb 80 Hz abgetrennt wird. So ist er nicht ortbar und spielt quasi "vorne" mit. Die absolute Grundlage für JEDEN Lautsprecher ist erstmal der Einbau. Schau Dir als Beispiel mal Home HiFi Lautsprecher an, die werden ja auch net in windigen Obstkistchen eingebaut, sondern in stabile Holzgehäuse. Nix anderes ist das im Auto. Dem Hersteller des Fahrzeuges ist dies aber egal. Für ihn zählt nur wie er die Teile am schnellsten und billigsten befestigen kann. WENN Du guten Klang willst, musst hier nacharbeiten. Je stabiler, desto Klang und desto BASS In aller Regel verwendet man im Auto ein 2-Wege KOMPONENTEN System. Das ist zum einen der Tiefmitteltöner und zum zweiten der Hochtöner. Dieses System wird VORNE eingebaut! Da man beim abhören eine gewisse Bühnenabbildung, sprich die Abbildung der Musiker auf der Breite des Armaturenbrettes ---> http://www.sub-scene.de/klang.html http://www.motor-tal...ichtet-t1053933.html erreichen will, ist es ratsam die Hochtöner weit oben zu verbauen, zB in der A-Säule oder im Spiegeldreieck. http://www.epicenter...r-im-spiegeldreieck/ Der Tiefmitteltöner muss auf einen Holzadapter, Dämmung der Blech- und Verkleidungsteile sowie korrekte Ausrichtung der Hochtöner auf den Fahrerplatz, beeinflussen das Klangergebniss WESENTLICH. Der beste Lautsprecher kann nicht klingen, wenn hier geschludert wird. Hier kannst Dir das mal anhand Beispielen anschauen: http://www.hifi-foru...read=1408&postID=1#1 http://www.hifi-foru...m_id=123&thread=2115 Das Dämmaterial nennt sich Alubutyl, den Adapter kannst auch selbst sägen. http://www.just-soun...auf-der-rolle/a-139/ Für Kabel, Kleinzeug, Sicherungen, Dämmaterial werden ca. 160 EUR benötigt! Die hinteren Lautsprecher sind unnötig, da 99% des Musikmaterials in Stereo aufgenommen wurde. Zur Reproduktion werden zwei Schallquellen VOR den Ohren benötigt: http://home.arcor.de/Frank_CTR/ATB/wsstereo-stereodreieck.jpg http://de.wikipedia.org/wiki/Stereodreieck Du benötigst also: 1 Radio - am besten mit ZWEI!! Paar Vorverstärkerausgängen. 1 2-Wege KOMPONENTEN System 1 Subwoofer 1 4-Kanal Endstufe Das wird so angeschlossen wie in Beispiel Nr.2: http://www.hifi-foru...orum_id=165&thread=3 http://www.etongmbh....02-neuheit/1/pid/43/ http://www.etongmbh....-10-800-br/1/pid/20/ http://www.etongmbh..../sda-1504/1/pid/299/ [Beitrag von zuckerbaecker am 16. Nov 2014, 18:44 bearbeitet] |
Audiklang
#9 erstellt: 16. Nov 2014, 19:55 | |
hallo welchen oktavia hast denn ? ist wichtig ! also den älteren auf golf 4 basis oder den neueren auf golf 5 basis ? Mfg Kai |
devilblast
#10 erstellt: 16. Nov 2014, 21:29 | |
Dankeschön für die vielen Informationen Stefan ! Es ist ein Oktavia 1 also der auf golf 4 basis mfg joshua |
Audiklang
#11 erstellt: 16. Nov 2014, 23:11 | |
hallo okay oktavia 1 kann man normales zweiwegesystem vorn verbauen Mfg Kai |
zuckerbaecker
#12 erstellt: 17. Nov 2014, 00:35 | |
http://www.marvinrab...mbauanleitungLSP.pdf http://www.hifi-foru...d=52080&postID=22#22 http://www.hifi-foru...m_id=123&thread=1942 http://www.hifi-foru...=533&back=&sort=&z=1 http://static.pagens...4_tmt_aufnahme_1.jpg http://fortissimo-sh...aram=cid=2&aid=1006& http://www.pimpmysou...3cfee8e76d8637318dea |
Bass im Skoda Octavia Kombi -breaker87- am 20.11.2006 – Letzte Antwort am 21.11.2006 – 9 Beiträge |
Skoda Octavia RS Kombi aufrüsten? sillybird am 21.02.2008 – Letzte Antwort am 25.02.2008 – 35 Beiträge |
Anlage im Skoda Octavia Ermoe am 18.08.2006 – Letzte Antwort am 18.08.2006 – 2 Beiträge |
Boxen für meinen Skoda Octavia Kombi rudi_runkel am 23.12.2005 – Letzte Antwort am 27.12.2005 – 6 Beiträge |
Frontsystem Skoda Octavia Angebot Luckgummi am 25.10.2012 – Letzte Antwort am 25.10.2012 – 2 Beiträge |
Skoda Octavia Kombi - Frontsystem und Endstufe viper_g3 am 26.10.2006 – Letzte Antwort am 27.10.2006 – 11 Beiträge |
Woofer für Skoda Octavia Kombi (2001) Johnny_N am 26.08.2010 – Letzte Antwort am 27.08.2010 – 4 Beiträge |
Subwoofer für Skoda Octavia 1U5 Kombi olo-1 am 11.08.2017 – Letzte Antwort am 17.08.2017 – 3 Beiträge |
Skoda Octavia III Kombi Seitenfach Subwoofer muenabua am 25.09.2019 – Letzte Antwort am 25.09.2019 – 6 Beiträge |
Komplette Anlange fürs erste Auto Mathiasbbbb am 03.08.2009 – Letzte Antwort am 03.08.2009 – 5 Beiträge |
2014
- Caraudio24.de
- eton oder ground zero?
- Caraudio24.de
- Registrierte Mitglieder927.168 ( Heute: 11 )
- Neuestes MitgliedKlaus_1961
- Gesamtzahl an Themen1.554.969
- Gesamtzahl an Beiträgen21.625.753
