Old amplifier & impedance diffrences.
muhmaku
#1 erstellt: 04. Sep 2006, 11:03
My question concerns using old 8-16 ohm amp (HK A 402) with modern 6ohm speakers (ALR Jordan Entry 5M).
Is it safe? and how it would affect sound quality?
regards,
Domino
mhenze
#2 erstellt: 04. Sep 2006, 19:15
Using lower impedance speakers puts a higher load on the amp *if* the speakers have the same efficiency (if you use very efficient 4 ohm speakers vs very inefficient 8 ohm speakers you can get more volume at less load with the 4 ohm speakers).
The speaker impedance given by the manufacturer can be a bit misleading though since there are different norms iirc, some 8 ohm speakers can go down to 2 ohm at certain frequencies and other 4 ohm speakers are all the way stable.
You should check the temp of the amp if it stays low to moderate at your listening volume you're fine.
There should be audible distortions in the sound at higher volume if the speakers have too low impedancy values.
mh
good old amps.
muhmaku am 04.09.2006  –  Letzte Antwort am 06.09.2006  –  18 Beiträge
Old and new.
Feathead am 27.03.2009  –  Letzte Antwort am 29.03.2009  –  6 Beiträge
German old receivers
babadockia am 15.12.2018  –  Letzte Antwort am 16.12.2018  –  12 Beiträge
Good Old Hifi
michi665 am 15.06.2020  –  Letzte Antwort am 15.06.2020  –  2 Beiträge
Kenwood amplifier
vfbvfb am 27.05.2008  –  Letzte Antwort am 29.05.2008  –  6 Beiträge
Hi fi forum old fidelity
herbert1949 am 09.02.2016  –  Letzte Antwort am 09.02.2016  –  4 Beiträge
Pioneer Amplifier A-441
Bassmonster am 16.05.2004  –  Letzte Antwort am 17.05.2004  –  5 Beiträge
Nakamichi amplifier 2 HILFE
hede am 18.12.2004  –  Letzte Antwort am 19.12.2004  –  2 Beiträge
Pioneer Stereo Amplifier
popp am 06.03.2005  –  Letzte Antwort am 06.03.2005  –  47 Beiträge
Scott A 417 Amplifier
ratfink am 26.11.2006  –  Letzte Antwort am 27.11.2006  –  4 Beiträge
2006
  • Registrierte Mitglieder928.983 ( Heute: 1 )
  • Neuestes MitgliedAnna234
  • Gesamtzahl an Themen1.559.416
  • Gesamtzahl an Beiträgen21.726.137
