pioneer sa-8800 daten wer...
harald64646
#1 erstellt: 27. Sep 2004, 14:26
hallo,
wer kann mir die tech. daten des pioneer sa-8800 benennen?
es geht mir hauptsächlich um wattzahlen sinus, musik, 4-8 ohm.
vielen dank
op111
Moderator
#2 erstellt: 27. Sep 2004, 15:04
Hallo harald,
ich habe so einen Oldtimer noch funktionsfähig in meiner Sammlung, wenn du bis morgen warten kannst ...?
Franz
Michael-Otto
#3 erstellt: 27. Sep 2004, 15:12
Hallo Harald,
hier die Daten zu deinem SA-8800
Quelle: Pioneer Prospekt.
Continuous Power output
10Hz to 20,OOOHz: (T.H.D. 0.005%, 8 ohms or 4 ohms) 80W + 80W
10Hz to 50,OOOHz: (T.H.D. 0.01 %, 8 ohms) 80W + 80W
100W + 100W (T.H.D. 0.02%, 4 ohms)
1,OOOHz: 80W + 80 W(T.H.D. 0.002%, 8 ohms)
Total Harmonic Distortion: (10 to 20,OOOHz)
No more than 0.005% (continuous rated power output)
No more than 0.004%(40 watts per channel power output, 8 ohms)
No more than 0.004% (1 watt per channel power output, 8 ohms)
Intermodulation Distortion: (50Hz:7,000Hz = 4:1)
No more than 0.002% (continuous rated power output)
No more than 0.002%(40 watts per channel power output, 8 ohms)
No more than 0.002%(1 watt per channel power output, 8 ohms)
Frequency Response: 5 to 200,OOOHz +OdB, -2.OdB
Input Sensitivity/Impedance: 1V/50k ohms
Output Speaker: A, B, A + B
Headphones: Low impedance
Damping Factor: 55 (20 to 20,OOOHz, 8 ohms)
Hum and Noise: 118 dB (short-circuited A network)
PREAMPLIFIER SECTION
PHONO 1: and PHONO 2: 2.5mV/50k ohms
CARTRIDGE LOAD: Both Phono 1 and 2 100, 10k, 25k, 50k, 100k ohms 100, 200, 300, 400, 500pF
TUNER, AUX,TAPE PLAY 1, TAPE PLAY 2, FTAPE PLAY 2 (DIN connector): 150mV150k ohms
PHONO Overload Level both PHONO (T.H.D. 0.002%, 1kHz) 250mV
Output Level/Impedance TAPE REC 1: TAPE REC 2: 150mV
TAPE REC 2 (DIN connector): 30m/V80k ohms PRE OUT: 1V 600 ohms 3V 600 ohms (MAX)
Total Harmonic Distortion: No more than 0.006% (10 to 50,OOOHz, 1V output)
Frequency Response PHONO (RIAA Equalization): 20 to 20,000 + -0.2dB
TUNER, AUX, TAPE PLAY; 5 to 100,OOOHz +OdB, -1O dB
Tone Control BASS: ±10dB (100-Hz) TREBLE: + -10dB (10kHzFilter
SUBSONIC: 15Hz (6dB/oct.) HIGH: 8 kHz (6dB7oct.)
Hum and Noise (Short-circuited A network, rated power)
PHONO: 90dB,TUNER, AUX, TAPE PLAY: 110dB
Hum and Noise ((DIN: continuous rated power output/50mW) PHONO: 72dB/63dB
TUNER, AUX, TAPE PLAY: 88dB/63d8
Muting:-20dB.
Power Consumption: 700 watts (MAX)
Michael-Otto
harald64646
#4 erstellt: 27. Sep 2004, 15:48
hallo,
vielen dank dafür.
gruß
harald64646
Pioneer SA 8800
analogmusik am 02.08.2009  –  Letzte Antwort am 03.08.2009  –  15 Beiträge
Pioneer SA-8800
Ondollo am 06.01.2005  –  Letzte Antwort am 08.01.2005  –  5 Beiträge
Pioneer SA 8800 Display
MikeDee am 17.07.2006  –  Letzte Antwort am 10.12.2009  –  115 Beiträge
Pioneer SA-8800
Stimpson am 03.01.2010  –  Letzte Antwort am 03.01.2010  –  2 Beiträge
Pioneer SA 8800 wert?
Alokin am 01.07.2010  –  Letzte Antwort am 02.07.2010  –  4 Beiträge
Technische Daten zu Pioneer Sa-508 und Sa-8800
nofredete am 19.06.2006  –  Letzte Antwort am 19.06.2006  –  3 Beiträge
Pioneer SA-8800, Schaltbild gesucht
hf500 am 23.09.2004  –  Letzte Antwort am 26.09.2004  –  9 Beiträge
Pioneer SA-8800 Schaltbild bitte
kantona am 04.12.2004  –  Letzte Antwort am 10.12.2004  –  9 Beiträge
Pioneer SA 8800 - heute gekommen
dirk67 am 12.08.2006  –  Letzte Antwort am 25.08.2006  –  14 Beiträge
SA 8800 Laustärke Regler
tbleim am 29.06.2006  –  Letzte Antwort am 27.07.2006  –  4 Beiträge
2004
  • Registrierte Mitglieder928.955 ( Heute: 6 )
  • Neuestes MitgliedAsdemna
  • Gesamtzahl an Themen1.559.375
  • Gesamtzahl an Beiträgen21.724.853
