NAD D 3020 hat da schon jemand Erfahrungen?
fred.heinz
#1 erstellt: 30. Okt 2013, 15:13
da ich mit dem Stereo-Sound meines Denon AVR-1910 nicht wirklich zufrieden bin habe ich mir überelegt demnächst den neuen NAD D 3020 anzuschaffen. Die Reviews fallen ja recht positiv aus:
http://www.whathifi.com/review/nad-d-3020
http://www.hifi.nl/a...gital-Amplifier.html
Hat jemand im Forum schon Erfahrungen mit dem D 3020 gemacht?
Vor allem der integrierte DAC interessiert micht brennend.
Beste Grüße
Fred
T.C._Sempronius
#2 erstellt: 11. Apr 2014, 18:48
Der kleine NAD ist sehr leistungsfaehig. Die Klangqualitaet ist ausgezeichnet. Der Wandler tut seinen Job. Der D 3020 hat aber kleine Probleme wie dieses hier, das NAD mitgeteilt wurde, das NAD noch nicht kommentiert hat.
"NAD D 3020 problems
The new D 3020 is a cute little amplifier of astonishing performance in view of its minuscule size and very reasonable price. However, if it is called to power a pair of 12" subwoofers at moderate sound levels it gets hot after two hours or so. Hot means too hot to comfortably touch it outside the switching power supply block.
Although it works without a hitch there is a faint but suspicious smell of burning electronics.
I contacted HYPEX, the maker of the amplification modules. They said they knew little about the NAD amp although it uses one of their modules. It is easy to deal with the heat problem in the case of the HYPEX UcD modules. You just glue a heatsink on top.
In the case of the tiny NAD there is no space for a heatsink. Furthermore, the elegant Nextel foam protecting the casing acts as an insulator, keeping the heat inside the amp.
Fortunately, NAD has added a (mono) subwoofer out which supposedly can be used to feed a separate subwoofer or plate amp. But closer scrutiny shows that the subwoofer out is configured in toslink format!
A toslink out for digital or for analog use? Obviously it is intended to provide an analog connection to the plate amp. But plate amps have RCA/cinch inputs, never an input in analog/toslink format! Only remaining option is to take a separate powered toslink/coax converter and hope that it will convert not only digital signals -- for which it is intended -- but also a relatively strong analog signal. Has anyone ever tried this? A rather discouraging prospect. "
Amperlite
#3 erstellt: 14. Apr 2014, 11:44
@T.C._Sempronius:
Bitte gib doch eine Quelle für deine Zitate an.
...da ich mit dem Stereo-Sound meines Denon AVR-1910 nicht wirklich zufrieden bin habe ich mir überelegt demnächst den neuen NAD D 3020 anzuschaffen.
Ich erwarte auch von einem AV-Receiver keine nennenswerte Verfälschung des Klangs. Allerdings sind diese komplexen Geräte heute schwierig einzustellen und man übersieht gerne eine Option. Prüfe doch nochmal alle Einstellungen, bevor du ein anderes Gerät anschaffst.
Hier war der Autor nicht in der Lage, sich die Rückseite mal anzusehen, bzw. in der Bedienungsanleitung anzusehen.
Der 3020 hat einen analogen Klinkeneingang, der über Adapter auch als Toslink-Eingang genutzt werden kann.
Darunter befindet sich der analoge Subwoofer-Ausgang (als in dieser Anwendung selten anzutreffender 3,5mm klinken-Anschluss).
[Beitrag von Amperlite am 14. Apr 2014, 17:30 bearbeitet]
Poetry2me
#4 erstellt: 14. Apr 2014, 17:19
Wenn ich den Text zu dem NAD D3020 Problem richtig interpretiere, dann kommt es zu einem
"leichten aber verdächtigen Geruch von verbrannter Elektronik."
Es wird der Verdacht geäußert, das verbaute Hypex UcD Module würde ohne montierte Kühlung betrieben und hätte sogar eher eine Wärmeisolierung.
Das wäre allerdings wirklich eine Klärung wert, denn eine zu hohe Erwärmung würde auch eine sehr kurze Lebenszeit des VErstärkers NAD D3020 zur Folge haben.
Ein zweiter Punkt wird noch erwähnt (Den Zusammenhang verstehe ich nicht):
Es wird wohl angedeutet, dass ein vorhandener Subwoofer-TOSlink Ausgang die optische Übertragung möglicherweise analog statt digital vornehmen würde.
Das kann ich allerdings nicht ganz glauben.
- Poetry2me
NAD D 3020
Skeip am 28.03.2015  –  Letzte Antwort am 03.04.2015  –  9 Beiträge
NAD 3020 als Vorverstärker
rrrock am 12.02.2005  –  Letzte Antwort am 14.02.2005  –  6 Beiträge
NAD 3020 defekt
lars_ am 25.11.2005  –  Letzte Antwort am 26.11.2005  –  4 Beiträge
240V NAD 3020 an 220V ???
ratracer am 18.02.2006  –  Letzte Antwort am 20.02.2006  –  4 Beiträge
Reparatur NAD 3020
Rockyladen am 15.12.2006  –  Letzte Antwort am 15.12.2006  –  2 Beiträge
Knacken beim NAD 3020
TimG am 14.03.2009  –  Letzte Antwort am 16.03.2009  –  6 Beiträge
NAD 3020-e-i-Unterschied?
Dommes am 23.03.2006  –  Letzte Antwort am 25.08.2006  –  3 Beiträge
NAD 3020 als (Phono-)Preamp
rrrock am 26.08.2006  –  Letzte Antwort am 26.08.2006  –  3 Beiträge
NAD 3020 endstuffe raucht-> bekanntes Problem?
tifreak_m am 11.11.2006  –  Letzte Antwort am 15.11.2006  –  5 Beiträge
NAD 300
hifigunter am 31.01.2010  –  Letzte Antwort am 10.02.2010  –  6 Beiträge
  • Registrierte Mitglieder929.070 ( Heute: 7 )
  • Neuestes MitgliedSatfriends
  • Gesamtzahl an Themen1.559.617
  • Gesamtzahl an Beiträgen21.730.721
