McCormack DNA 125
bobbybpl
#1 erstellt: 23. Jan 2009, 09:33
I have 15 months old McCormack DNA 125 power amplifier on sale.
I bought this amp from the Distributor/dealer named Soundsmiths (Bombay) with bill and warranty.I am the first owner of this amp and it is in mint condition, sparingly used, Excellent physical condition without any mark or any itch, it looks like brand new. I have original packing and manual.
It has got 5 stars by 36 users in audioreviews.com
The price for new amplifier is Rs 1,07,000/-( Can check with the AV MAX magazine or dealer).
I am asking Rs 52000/- for this unit.
Here are some expert reviews for this lovely machine
http://www.stereotimes.com/amp080100.shtml
http://www.enjoythemusic.com/magazine/equipment/0800/dna125.htm
http://www.audiorevi..._124852_1583crx.aspx
Contact me on 09826052513
reignofchaos
#2 erstellt: 23. Jan 2009, 11:04
Wish there was a way to run them as monoblocks. I'd have taken your amp then. That aside good luck for the sale and hope you find a buyer.
Please do let us know what you are upgrading to.
square_wave
#3 erstellt: 23. Jan 2009, 11:43
Hi chaos,
You can always do a horizontal bi-amping. You will need lot more cables though.
Or you can invest in an electronic crossover and bypass the usher crossover. Much better results
Bobby, what are you upgrading to ?
bobbybpl
#4 erstellt: 24. Jan 2009, 09:04
Have two options in mind..
6 months used Plinius 9100 integrated..Or Brand New Naim nait 5i version 2.
Seeking expert opinions
Bobby
SNV
#5 erstellt: 24. Jan 2009, 14:45
Hi Bobby,
If you are considering a new Naim Nait 5i, then also consider the Cyrus 8vs2.
Which city are you based in?
Regards
SNV
Manek
#6 erstellt: 24. Jan 2009, 18:10
Bobby
The dna 125 is a fine amp. You are going for an integrated...so you would be giving up your pre too ? Or just use the power sections of the integrated ? What pre do you use ?
Manek
Amp_Nut
#7 erstellt: 25. Jan 2009, 03:51
At the risk of sounding obtuse.... some questions for you to mull on (no reply needed) :
What are you looking for in your new amplification, that you missed in your existing setup ?
What did you particularly like in your old set up, that you would not like to give up in your new set up ?
If your speakers are adequately effficient... have you considered tubes ?
[Beitrag von Amp_Nut am 25. Jan 2009, 05:32 bearbeitet]
Arj
#8 erstellt: 25. Jan 2009, 04:24
bonnybpl, unless you have checked out the speaker synergy part, you may be making a lateral movement rather than an upgrade..is that what is is supposed to be ?
bhagwan69
#9 erstellt: 25. Jan 2009, 05:43
Bobby
Sir,
None of the above......
Naim works best with Naim gear.
Plinius I never liked;
Sorry.
What are the other options ?
Deceide before you sell.
Not that McCormack was a great product, but as rightly mentioned, no side ways movement.....
Think of an upgrade - 20 % to 30 % improvement in sound at least......Else not worhth it.
Savyasaachi
#10 erstellt: 25. Jan 2009, 07:08
Bobby
Sir,
Sorry.
:Y
times 2..
don't know about Naim but agree about the Plinius.
If you are indeed looking for a huge upgrade, then look at the newer Class D based amplifiers with tube input bufers..I heard two such implementations and they were both fantastic..Luminance is another amplifier you should consider, so is pass labs
[Beitrag von Savyasaachi am 25. Jan 2009, 07:09 bearbeitet]
bobbybpl
#11 erstellt: 25. Jan 2009, 09:11
I would consider cyrus 8vs2, I am in bhopal and hopefully in the coming week i'll visit mumbai for auditions, please let me know where to audition cyrus
Just one word...INVOLVEMENT.
Manek
Manek, am using lyrita's pre to drive DNA and i would certainly give up pre too.
Sorry.
:Y
I totally agree with you, naim works best with naim gears and i am planning to go for the naim CDP too.I have listened to the combination at lakozy and was really impressed,How one can imagine listening to naim as it is just 50 watts ..fast and accurate with execellent tonality,can drive any modern floorstander with ease, however, am not sure about the speakers.
ATC would need higher watts to perform its best and again its very flat and neutral so i dont think i will be able to afford to have all the best recordings in stock.
Usher is the second choice,one of my friend here has booked Be 718 so by the end of this month i'll compare it with audiance 72 with my current electronics.
Who deals in Luminance and pass lab.
Savyasaachi
#12 erstellt: 25. Jan 2009, 11:35
Luminance is sold factory direct...cehck out their store at audiogon.com
search for luminance
Pass labs - Singapore looks like the closest
Arj
#13 erstellt: 25. Jan 2009, 16:47
There is an ATC INt Amp for sale in singapore..nothing like this if your speaker is an ATC.
http://www.hifi.com.sg/2ndhand/sview.asp?id=2707
audionote is a very reputed dealer and they can help out in reducing duty as well..
I would not really worry about that ! although that could be true about any Hifi in that range, it all depends on what you look for in a system.
[Beitrag von Arj am 25. Jan 2009, 16:56 bearbeitet]
Manek
#14 erstellt: 25. Jan 2009, 18:29
No involvement....
I have heard the dna125 a few times and once with my tube amp. It was involving to say the least :-)
I own virens amp(6sn7 with ez81 rectifier) and the one thing it is and that it has a nice musical flow and draws you into the music.
Looks like a synergy problem in your electronics chain.
If you do have a pair of headphones of 300ohms impedance or higher, plug them at the back of your cdp output with a headphone to rca adaptor(mx brand will do) and hear how it sounds. Then do the same with virens pre. If you like it upto here then the problem is in the rest.
Manek
bobbybpl
#15 erstellt: 26. Jan 2009, 09:42
Thanks for the suggestions friends,
Arj,
I'll surely look for ATC integrated
Manek,
I'll try to do whatever you have suggested and try to find out the culprit out of chain
Thanks
Krish
#16 erstellt: 29. Jan 2009, 10:11
Mon Ami , you have just been bitten by the Naim Pace, Rhythm , Timing thingie... that's what it is. The Naim Design philosophy, as you well know, is all about that.As opposed to brands that believe in the Accuracy Philosophy. The Fender Strat might sound like a Ibanez, but who cares.Right.
BTW if you know somebody in Dubai or going there soon and will do you a favour; look at the new Naim Super Nait; 80W pc @ 8 ohms, on board DAC etc,etc retailing for AED 13,000 at Dubai Audio.
BTW I'm not sure whether the Ushers will work with them.
I have not heard the Ushers myself but I guessing as much from what I have read.
All the best anyway.
Cheers,
K
Manek
#17 erstellt: 29. Jan 2009, 16:17
On the prat thingie.....krish your roksans are pretty good as well.
Wish someone would sell this brand at a decent price in india.
Manek
bobbybpl
#18 erstellt: 30. Jan 2009, 09:29
Are you talking about Roksan kandy ?
RK III is available at 60k
Manek
#19 erstellt: 30. Jan 2009, 17:53
Yes the kandy's and the caspians. Where would you find the kandy's ?
Manek
Manek
#20 erstellt: 30. Jan 2009, 18:46
Bobby
Just out of curiosity, what cdp/speakers do you use ?
Which tubes do you have in your lyrita pre ?
Manek
Manek
#21 erstellt: 30. Jan 2009, 18:49
.....And bobby what genere's of music do you normally listen to ?
Manek
Arj
#22 erstellt: 31. Jan 2009, 04:32
Krish, I am not really very knowledgable on the PRaT thingie but from what i could read around the Flat Vs Round earth is more of an old debate now. and most of modern equipment (including Naim/LInn) try to get the soundstage, tonality as well as PRaT these days. would you agree with that ?
Krish
#23 erstellt: 31. Jan 2009, 16:23
[/quote]
Krish, I am not really very knowledgable on the PRaT thingie but from what i could read around the Flat Vs Round earth is more of an old debate now. and most of modern equipment (including Naim/LInn) try to get the soundstage, tonality as well as PRaT these days. would you agree with that ?[/quote]
Hey Arj,
It's been years since i heard Naim gear but a few days back I was speaking with a very dear friend o' mine who is a passionate Naim fan(and owner).He keeps auditioning the lastest Naim gear from time to time.
He says that while Naim has certainly improved upon things like sound stage, accuracy etc, the PRaT thingie is where they really excel.Pound for pound, you will certainly find Brands that are tonally more accurate.However when it comes to sheer involment ( again what I'm told and not what I know first hand ) Naim are a hard act to beat.
It fact it's that very word in bobbypl's post leads me to believe that this could be the primary cause for his dis-satisfaction with his current gear.
On paper the individual components in his system look fine, and yet he feels that he is missing something...
K
bobbybpl
#24 erstellt: 01. Feb 2009, 10:18
Manek schrieb:
Bobby
Manek
Manek,Currently i am using Nad 525 bee and audiance 72 speakers which i am planning to change by bookself, yet to decide in the budget of 100k..
I haven't changed the stock tubes, Line stage 5687 and Rectifier EZ 80.
I normally listen to Soft Rock, AR rahman,RD Burman, but i am compelled to take care of my kids choice too who listen to Michal jackson and latest bollywoods
Perhaps this is the reason i haven't took ATC yet and inclined more towards the open and detailed sounding Usher be 718..
God bless me
For Sale: Electrocompaniet AW-250R Power Amplifier
msb1 am 15.05.2009  –  Letzte Antwort am 18.05.2009  –  12 Beiträge
Odyssey Amp and pre for sale
surrealistix am 07.09.2008  –  Letzte Antwort am 08.09.2008  –  6 Beiträge
For Sale: Mint condition ?Cadence Arita ? bookshelves with ?Cadence? stands.
G_S_Madhav am 06.05.2008  –  Letzte Antwort am 15.06.2008  –  4 Beiträge
Lovely Audio Furniture for sale
SWITCH-IT-ON am 12.07.2007  –  Letzte Antwort am 21.07.2007  –  2 Beiträge
Bryston BP 25 & 7B SST for sale
abbasve am 29.01.2009  –  Letzte Antwort am 09.02.2009  –  11 Beiträge
For Sale: Sennheiser HD580 with DIY amp and Kimberkable
zhopudey am 11.01.2006  –  Letzte Antwort am 02.02.2006  –  17 Beiträge
Sugden A21aL for sale
Arj am 16.12.2008  –  Letzte Antwort am 24.08.2009  –  13 Beiträge
Marantz Reference Series Integrated Amplifier PM-17 For Sale
superczar am 01.10.2008  –  Letzte Antwort am 02.10.2008  –  2 Beiträge
Musical Fidelity X Can V3 for Sale
maxcoutinho am 24.01.2008  –  Letzte Antwort am 25.01.2008  –  6 Beiträge
Mcintosh C2200 Preamp Excellent Condition Only 700Euro
berthoaudioshop am 31.10.2007  –  Letzte Antwort am 03.11.2007  –  3 Beiträge
  • Registrierte Mitglieder928.513 ( Heute: 5 )
  • Neuestes Mitgliedkaiserstuhlbruno
  • Gesamtzahl an Themen1.558.354
  • Gesamtzahl an Beiträgen21.700.548
