HIFI-FORUM » Fernbedienungen, Zubehör, Kabel, HiFi-Möbel » Fernbedienungen » Harmony One - Workaround zum Beleuchtungs-Problem | |
Harmony One - Workaround zum Beleuchtungs-Problem+A -A |
TheWolf
10:31
erstellt: 22. Feb 2008, |
Hi, das hier hab ich im offiziellen Harmony-Forum gefunden: ----------------------------------------------------- There is a known issue where the backlight will not turn off in a couple of scenarios; 1. When you are in an activity and the backlight has turned off, press the off button without activating the tilt sensor by not moving or picking up the remote. This will cause the backlight to turn on while the activity turns off, and the backlight will stay on forever unless you press another button or activate the tilt sensor. 2. When you are not in an activity and the backlight has turned off, touch the LCD to turn the backlight on and press an activity button without activating the tilt sensor by not moving or picking up the remote. Your devices will turn on, but the backlight will never turn off unless you press another button or activate the tilt sensor. Cause: If the Remote Assistant is disabled through the client software, the remote will experience this issue. Workaround: Login to account. Click on "Remote Settings" tab. Click on "Display Settings". Set Remote Assistant option to "On" and click "Save". Update Remote. After the remote has been updated, the Remote Assistant can be disabled by pressing the "Options" button on the LCD and choosing "Turn Remote Assistant Off". Expected Resolution Date: End of March. --------------------------------------------------- Kurz gesagt geht es darum, dass unter bestimmten Umständen die Beleuchtung der Harmony nicht mehr von selber ausgeht. Hier der "Workaround" bis eine endültige Lösung kommen wird (voraussichtlich Ende März): - normal am Account anmelden - Meine Fernbedinungs-Einstellungen - Einstellungen - Fernbedinungsassistent --> EIN - Speichern - Harmony aktualisieren danach dann auf der Harmony - Optionen - Fernbedienungs-Assistent --> AUS |
Stiffler4
20:22
Hi, Erst mal vielen Dank für die INFO !!!! Das könnte gut bei mir zutfreffen; ich habe nämlich den Assistenten bei mir in der Soft deaktiviert. Ist zwar nicht die aller beste Lösung, würde mir aber schon mal weiter helfen. Teste das jetzt mal die nächsten Tage. Gruß Stiffler ..... |
Rico_C
11:26
erstellt: 23. Feb 2008, |
Vielen Dank, das Problem ist mir gestern Nacht aufgefallen. Zudem war gestern morgen die FB-Batterie leer obwohl ich die FB frisch zum 1. Mal aufgeladen hatte, da brannte wohl die ganze Nacht das Backlight ... Problem entsteht wenn man z.B. auf der auf dem Tisch liegende FB die Off-Taste drückt ohne vorher das Display zu aktivieren. Dann geht's durch den Tastendruck an und nicht mehr aus. Die Befehle lauten bei mir: - normal am Account anmelden - Einstellungen - LCD-Einstellungen - Fernbedinungsassistent --> Ein - SPEICHERN - Fernbedienung aktualisieren auf der Harmony: - Optionen - Fernbedienungsassisten deaktivieren drücken im LCD-Feld - Optionen verlassen durch Drücken beisplw. von Activities das Problem scheint nun behoben aber der Assisten nervt, der erscheint nun obwohl er deaktiviert ist ... ![]() edit: ok, jetzt isser weg ![]() |
TheWolf
12:20
@Rico_C: Danke für die exakten Schritte. Ich würde die ja gern in meinen Post übernehmen, aber ... Zugriff verweigert. ![]() Naja, vielleicht kann das irgend ein netter Mod mal tun? ![]() |
Hilfe! Harmony One Problem nicobecker am 12.08.2008 – Letzte Antwort am 14.08.2008 – 4 Beiträge |
Harmony One Problem 740er am 26.11.2011 – Letzte Antwort am 26.11.2011 – 2 Beiträge |
Logitech Harmony One Problem filou33 am 08.12.2012 – Letzte Antwort am 13.12.2012 – 8 Beiträge |
Logitech Harmony One Problem bloodsnake am 11.01.2016 – Letzte Antwort am 12.01.2016 – 3 Beiträge |
Beleuchtungs Umbau Sony FB A.P.M am 08.09.2005 – Letzte Antwort am 27.09.2005 – 9 Beiträge |
Harmony One Fischi73 am 12.02.2011 – Letzte Antwort am 15.02.2011 – 4 Beiträge |
Harmony One, PS3, Speedlink FB wishbone71 am 04.06.2011 – Letzte Antwort am 06.06.2011 – 5 Beiträge |
Harmony one andre06 am 23.07.2008 – Letzte Antwort am 28.07.2008 – 5 Beiträge |
Harmony one gusadu am 09.09.2015 – Letzte Antwort am 09.09.2015 – 3 Beiträge |
Harmony One Ausschaltreihenfolge festlegen meckdream am 06.02.2008 – Letzte Antwort am 08.02.2008 – 4 Beiträge |
Top Produkte in Fernbedienungen
- Registrierte Mitglieder928.816 ( Heute: 3 )
- Neuestes Mitgliedtritratrulalla
- Gesamtzahl an Themen1.559.041
- Gesamtzahl an Beiträgen21.716.225
