HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Sharp » Sharp LC - 42/ 46/ 52 XL 2E Full HD Serie | |
Sharp LC - 42/ 46/ 52 XL 2E Full HD Serie+A -A |
Grumbler
23:56
#351
erstellt: 17. Okt 2007, |||
Nein, wird es natürlich nicht. 24p laufen beim F8 sauber. Wie schon beim M8. Kann man im Forum oder auch hier nachlesen: ![]() Grüße, Grumbler |
Uwe_L.
07:56
#352
erstellt: 18. Okt 2007, |||
Mir geht es eigentlich genauso. Mal liest man beim Sammy was von starkem Grünstich + Flimmern => dann ist man wieder beim Sharp. Dort evtl. weniger leuchtendes Bild + das Clouding scheint auch noch ein kl. Thema zu sein.......... Hier mal aus dem amerik. AVS-Forum ein kl. Bericht von Einem, dem es ähnlich ging (5271 ist der Sammy, 52D82 der Sharp)): "Well... What I'll say will make everyone with a 52D82 happy and will attract a lot of attention from the owners of 5271. I thought I'd be better with a Sammy, so I bought one. Good I didn't yet return my Sharp, you'll see. Brought it home, placed it side by side with the 52D82. Turned it on in HDMI 1080p, same source as the Sharp - all OK, but Sharp a tad better on details (could only see it with stills or hi res photos). Then switched to SD (both of them) - wow! The Sammy was blurry, and Sharp was so... sharp Now it started to bug me, after all lots of people say the 5271 is supposed to be much better. Changed to Component 480p both - Sammy was consistently less sharp, even with the sharpness all to max. So, I decided to run the TVBlink DVD on both (yes, I know, is SD), at various outputs: HDMI 1080p, Component 1080i, Component 480p - in parallel to both TVs. Consistently, the Sharp would perform better except the colors; Sammy would have slightly more accurate SKIN colors, but all to the expense of greenish white (pretty much like Toshibas). Re-calibrating the white would then produce similar skin tint results as the 52D82. BTW - none of the advanced image settings are available in the 5271 unless in film mode. I didn't know this. This is when I understood my Sharp had nothing really wrong. Go take a look in stores, I for one noticed all xx71 seem greenish by comparison with rest. Anyways... many more tests that I've done on both sets in parallel revealed that: - 5271 does not seem to have 120 Hz panel refresh rate, but 52D82 has. If you don't believe it, get a good photo camera with LCD, set it to 1/60 and look through it while half pressing the shutter: Sammy will start flickering, Sharp not. Only after 1/125 will begin to see some minor flicker on Sharp, but by now Sammy will be real bad. My other CRT flickers same as the Sammy 5271 (and that one I know for sure can only do 60 Hz refresh). - The Sammy AMP seem to do exactly what they say: introduced extra frames; no wonder of the "triple ball effect"; I've seen it and captured it on very fast action photos, where the Sharp maintained good edges and no ghosting (see "Fast action.jpg"). I may very well be wrong - but given the above two combined - I doubt there will ever be a fw fix for the 5271 "triple ball". This was on HDMI 1080p, both sets. Lastly, the worst: - When running the fast moving vertical bar test, I saw right away some artifacts on the lower half screen on the Sammy. Took some photos, and sure enough, was bad (see "Fast V bar.JPG"). - In presence of intense blue backgrounds (like commercials or news background), Sammy would start to visibly flicker on blue. - The 5271 screen had a major case of clouds as well as rainbow colors from an angle (see "Clouds.JPG" and "Rainbows.JPG"). Keep in mind both TVs ran in parallel with same signal, same type (HDMI 1080p). I may have got a bad 5271 set, I don't know, but I thought it fair to share my findings so others would know. I can live very well with the very minor Sharp banding (yes, it is present, but I'll challenge you to see it, and only when in service mode dark grey) - versus all the bad issues I discovered on the 5271 while I briefly owned it. As for the skin colors in Sharp, I'll calibrate it. The Sammy went back, 52D82 will stay. No TV out there is perfect, just choose the one YOU think is best and enjoy it!" |
ICH75
08:19
#353
Hat jemand schon ne XBOX 360 oder ne PS3 an einen XL2E angeschlossen? LG ICH75 |
Uwe_L.
10:00
#354
Hier ist mal ein thread auch aus dem amerik. AVS-Forum über die besten settings. Ist allerdings für ein älteres Modell, aber vielleicht hilft es trotzdem weiter.... ![]() Edit: Und hier nochmal eine Variante: "As for the settings and tweaking, I yet to find a decent one for SD. As for HD, I like to tune down the backlight. I have the following settings on the Movie and User AV: DNR: Off Color temp: Middle Black enhancer; On Fine motion: Off OPC: Off BL: -6 Contrast: =30 Brightness: -4 Color: -4 Tint: 0 Sharpness: 0 (some people like to set this to -8 to -10)" [Beitrag von Uwe_L. am 18. Okt 2007, 10:41 bearbeitet] |
smudo84
10:31
#355
hat den noch keiner die richtige einstellung vom bild? bite um hilfe... brauch die beste einstellung für digital sat. |
geestyle
11:45
#356
hast du bereits einen XL2? Falls ja, wie ist die Bildqualität und wie hast du das Gerät angeschlossen? Scart, YUV, HDMI? |
smudo84
12:26
#357
hab seit gestern denn LC-42 XL 2 zum testen mit heimbekommen. bild finde ich super meiner freundin gefählt es nicht.. kommischQQ also ist über einen Digital-Sat Receiver Kathrein UFS 732 über ein sehr gutes SCART Kabel angeschloßen.. |
vayacontioz01
12:31
#358
Hallo, würde gern mal von nem XL 2 Besitzer wissen, wie das Bild von Premiere Fußball mit und ohne 100 Hertz ausschaut??!! Sieht man denn ein Unterschied?? (vielleicht kann jemand ja mal Bilder posten) [Beitrag von vayacontioz01 am 18. Okt 2007, 12:34 bearbeitet] |
geestyle
12:36
#359
Frauen... Hast du Vergleichsmöglihckeiten zu anderen Geräten? |
smudo84
12:53
#360
also hab jetzt die einstellungen vor genommen aber finde das bild ist nun unscharf und nicht so toll sehr dunkel!! Ne ist für mich nicht das richtige... also hatte mal denn TH-42 PV 74 glaub der hieß so daheim.. und fand das der Sharp besser mit dem PAL bild umgeht.. als der Panasonic. Habe auch in der ARbeit denn Sharp mit dem TH-42 PZ 70 über PS3 verglichen klar der Pana. ist von denn Farben shcon noch besser aber der Sharp kommt sehr gut an denn PLasma hin. vorteil bei BlueRay Filmen ist bei dem Sharp 24P 100Hz also kein ruckeln und geht super damit um... aber wie gesagt das war alles Werkseinstellungen bei beiden geräten. jetzt daheim finde ich noch nicht die richtige einstellung man findet ja auch noch keine test über denn Sharp schade... |
smudo84
12:55
#361
hatte gestern das fußball spiel Deutschland angesehen naja schlechtes Spiel :-) o.k. spaß also das konnte man super ansehen aber war alles auf Dynamisch also Werkseinstellung eingestellt habe zwar bischen was eingestellt aber bild war super das einzige er hat probleme gehabt wenn im Hintergrund die Fans kammen dann hatte er probleme das alles scharf zu stellen.. aber sonst echt klasse besser als der Panasonic TH-42 PV 74 finde ich.... |
NewYork
12:56
#362
der pana macht also ein besseres HD-Bild?? hat der sharp dem pana gegenüber einen vorteil (schärfe etc.)?? |
smudo84
13:00
#363
der pana ist von denn Farben besser klar ist ein Plasma ist ja bekannt. habe dann denn Sharp von denn Farben fast bis zum ende aufgedreht dann war der Sharp gleich auf von denn Farben. Der Sharp ist der bessere bei BlueRay filme. sprich das 24p bringt es, er ist reuger als der Panasonic. das 100Hz bringt auch bischen aber da muss mann genau hinsehen wie ja bekannt arbeiten die anderen geräte ja mit 75hz und auf 100hz ist es nur ein geringer schritt aber ich persönlich finde der Shapr ist besser als der Pana. wenn mann nur noch die richtige einstellung rausbekommt is der Shapr die bessere lösung. Aber ist nur meine Meinung... muss jeder für sich entscheiden... |
NewYork
13:04
#364
Danke für die schnelle Antwort, Sieht man noch schlieren beim sharp bei BluRay oder fußball? |
smudo84
13:08
#365
also wie gesagt bei fußball hatte ich nur WSE und nicht die besten einstellungen also bei genauem hinsehen ganz leicht aber meine freundin hat das nicht gesehen das panel hat ja 4ms und dank dem 100hz kaum was zu sehen.. bin der richtigen einstellungen bekommt man das bestimmt weg. Aber bei BlueRay nichts zu erkennen hatte ICE AGE2, Nur noch 60 sek, In The Blue, aber da merkt mann schnell unterschiede zwischen denn filmen am schlechtesten war In The Blue |
Uwe_L.
16:37
#366
Können die neuen XL2-Besitzer mal was über die Sound-Eigenschaften schreiben. Bei den Vorgänger-Modellen kam das ja nicht so gut... |
smudo84
17:08
#367
also klar hatte vorher einen Loewe Röhre aber finde das der Sharp XL 2 echt gut ist was denn Sound an geht... klar kommt an ein 5.1 Soundsystem nicht hin aber klingt nicht schlecht find es ausreichend zum tv sehen. hat schon jemand die besten Bild Einstellungen?? |
Uwe_L.
17:19
#368
@ smudo84 Kannst Du was vom "Banding" auf einfarbigen Flächen und/oder Kameraschwenks erkennen...? |
blackbor
18:33
#369
Also habe gerade einen Topfield TF7700HSCi an meinen XL2E angeschlossen über HDMI und ich muß sagen das PAL Bild ist Wahnsinn und das HD ja sowiso. Man kann hier viel über einzelne Details diskutieren. Fakt ist ich sitze hier vor dem Teil und finde es einfach nur geil was ich da an genialen Bildern sehe. Ich gebe mir mühe irgendwelche Fehler zu finden bzw. irgendwas was mich beim TV gucken stören könnte - finde aber nix. Ich kann nur zum Kauf empfehlen. |
smudo84
18:41
#370
hey was für Einstellungen hast du beim bild? vom Werk oder selber was eingestellt?? |
Uwe_L.
18:59
#371
Ich hab ihn bestellt und Du bist Schuld ![]() |
smudo84
20:28
#372
hey jetzt brauch ich nochmal hilfe, und zwar habe meinen Sat-Receiver auf 16:9 gestellt aber wenn ich jetzt z.b. gerade Sat1 an sehe glaub der film bzw. serie wie VOX heute Tom Raider der ist ja 16:9!! Habe ich oben und unten Balcken, warum? wenn ich es mit der hand umstelle dann passt das Menü vom Receiver oder andere programme nicht mehr... kann der TV das nicht alleine immer das beste bild einstellen das ich keine balcken habe egal was ich ansehe??? bitte um hilfe |
netzer79
20:30
#373
Hat der XL2 eigentlich diesen erweiterten Farbraum? Und ist schon 100% geklärt das die 24p in 48Hertz ausgegeben werden? Was glaubt ihr, wie ist der Schwarzwert und Blickwinkel gegenüber dem neuen Z3030 von Toshiba? |
Uwe_L.
21:31
#374
Den erweiterten Farbraum von 10 bit hat der Xl2. Ob er die 24p mit 48 Hz ausgibt ist wohl noch nirgends 100%ig geklärt worden. Hier im Thread hat ja einer behauptet, dass er es direkt von einem Sharp-Mitarbeiter erfahren hat..... |
blackbor
22:16
#375
Ich habe das Standardprofil genommen und noch etwas modifiziert. Hab jetzt meinen HD Receiver wieder einpacken müssen und hab meinen Billigreceiver wieder angeschlossen, das Bild ist demzufolge nicht mehr ganz so gut. Ich hoffe der Technisat HD S2 wird bald zu kaufen sein, dann wird Bild wieder perfekt ![]() |
AKA-Mythos
22:18
#376
Ich finde die Slimline Optik ja sehr gelungen. Kann man eigentlich den unteren Lautsprecher abbauen, so dass die Slimline Optik auch unten vervollständigt wird oder ist das eine richtige Einlassung, die auch von der Rück- oder Seitenwand ausgespart ist? |
blackbor
22:19
#377
Ich habe den Receiver auf 4:3 gestellt und hab am XL2E den automatischen Breitbildmodus aktiviert. Dieser funktioniert aber nur wenn ein entsprechendes Signal vom TV-Sender kommt. Ab und zu funktioniert das mal, falls nicht stell ich immer manuell nach. |
blackbor
22:24
#378
Die Lautsprecherleiste ist in die Rückwand eingelassen, geht also nicht abzunehmen. Ich finde das Teil nicht störend, eher im Gegenteil das lockert etwas auf sonst wäre der LCD wirklich nur nen rechteckiger Kasten. |
Gitta
08:37
#379
erstellt: 19. Okt 2007, |||
Hallo, wollte mal fragen, ob jemand schon den LC-52XL2E hat oder weiß, ob der überhaupt schon ausgeliefert wird. Gruß, Gitta |
luemmelchris
11:57
#380
Der xl 2 macht definitiv 24p mit 48 hz. Bitte mal weiter oben lesen. Sharp deutschland hat diese woche 52 er bekommen und ich hoffe jeden tag auf den anruf der spedition. Bei händlern gehe ich mal von verfügbarkeiT nächste woche aus. |
Schwarzwaldelch
11:57
#381
würde mich auch interessieren.... |
Schwarzwaldelch
12:00
#382
zu spät... alles klar! |
smudo84
12:20
#383
also in Donauwörth gibt es denn Sharp LC-52 XL 2 schon.. ist gestern gekommen... hab ich gesehen... soweit sind sie also ausgeliefert... wie sieht es aus wer hat nun die besten bildeinstellungen für seinen lc-42 xl 2 ?? |
Gitta
12:44
#384
Hallo, meine Frage von heute früh hat sich erledigt. Mein LC-52XL2E ist da, aber nicht hier. Mein Händler hat gemailt, dass das Gerät heute in Frankfurt eingetroffen ist und mitte nächster Woche bei mir eintrudelt. Jetzt kann ich nur noch in Geduld warten. Gruß, Gitta |
NewYork
12:58
#385
Kann irgeneiner der Xl2E bestätigen, dass der black Crush vom XL2E wirklich so übel ist? |
netzer79
13:29
#386
Wieso hat der XL2 gegenüber dem XL1 nicht mehr dieses truD Bildverbesserungsfeature? |
Uwe_L.
13:39
#387
Diese Info habe ich von meinem Internet-Händler auch bekommen für den 46"XL2E..... |
Klaus-Johannes
14:40
#388
.... Mein LC-52XL2E ist da, aber nicht hier. Mein Händler hat gemailt, dass das Gerät heute in Frankfurt eingetroffen ist und mitte nächster Woche bei mir eintrudelt. Hi Gitta, kannst Du denn mal kurz über Deinen neuen 52er Berichten.... Möchte mir zum Monatsende auch einen 52 XL 2E bestellen. Gruß KJ [Beitrag von Klaus-Johannes am 19. Okt 2007, 14:42 bearbeitet] |
Berni_W.
15:05
#389
Hallo
Hab vor zwei Stunden beim Experthändler eine E-mail von Sharp lesen dürfen. Darin stand, dass die ersten XL2E für Deutschland ab mitte nächster Woche ausgeliefert werden. ![]() Die hier in Deutschland bereits verkauften Geräte waren demzufolge nicht für Deutschland bestimmt. Für die Ostblockländer wie z.B. Polen wurde nur B-Ware ausgeliefert. Hier handelt es sich um Geräte mit nicht bestandener deutschen Qualitätsprüfung, da sie hier strenger sein soll als in manchen anderen Ländern, z.B. mit billigen Netzteilen, weil in solchen Ländern die Kaufkraft nicht so hoch wie bei uns ist. Wenn das alles stimmt, was mir der seit langem auch privat bekannte Händler erzählt hat, frage ich mich woher Ihr alle Eure XL2Es herhabt. ![]() Gruss, Berni |
margaan
15:46
#390
Dann frag ich mich aber auch, wodurch man beim späteren Kauf eine B-Ware von einer A unterscheiden kann. |
Gitta
16:20
#391
[/quote] Hab vor zwei Stunden beim Experthändler eine E-mail von Sharp lesen dürfen. Darin stand, dass die ersten XL2E für Deutschland ab mitte nächster Woche ausgeliefert werden. ![]() Hi Berni, da hat dich dein Expert-Händler nicht richtig beraten oder bei Sharp weiß die rechte Hand nicht was die linke macht. Fakt ist, dass mein Sharp-Vetragshändler in Frankfurt/Main bereits letzte Woche einen 46-er hatte und heute meinen 52-er bekommen hat. Von wegen B-C- oder D-Ware für Mongolei oder den Kongo. Es ist ein Gerät für Deutschland mit 3 Jahre Garantie und dem Segen von Sharp Hamburg. Gruß, Gitta |
Tomasz33
17:14
#392
Aus Polen! "Der japanische Elektronik-Konzern Sharp (Europa: Sharp Electronics Europe GmbH, Hamburg; ![]() "Mit der Fabrik in Torun wollen wir einerseits die hohe Nachfrage nach LCD-TVs in Westeuropa besser bedienen können und dabei die Time-to-Market verkürzen. Andererseits investieren wir mit der neuen Fabrik bewusst in Osteuropa, denn Länder wie Polen, die Tschechische Republik, Ungarn und die Slowakei zählen zu den stark wachsenden LCD-TV Märkten Europas und werden in Zukunft immer bedeutender." Die Zeiten sind vorbei dass die B-Ware nach Osteuropa Ausgeliefert wird! ![]() |
Uwe_L.
17:23
#393
Dann wäre es ja durchaus möglich, dass man auch hier in Deutschland Geräte "Made in Polska" bekommt. Interessant wären dann vielleicht die Serien-Nummern.... |
blackbor
18:00
#394
auf meinem steht "Made in Japan" |
Uwe_L.
18:05
#395
Könntest Du mal die ersten 4 Ziffern Deiner Serien-Nr. posten. Dann kann man später, wenn wir unsere Geräte erhalten haben, mal vergleichen.... |
blackbor
18:07
#396
Hmm wie kann man Geräte in Deutschland verkaufen die die Qualitätsprüfung für Deutschland nicht bestanden haben? Dann brauche ich doch die Qualität gar nicht erst zu prüfen!?! |
blackbor
18:11
#397
die ersten vier : 7080... |
Uwe_L.
18:21
#398
Scheint im August diesen Jahres gefertigt zu sein. Vielleicht wäre die 5. Zahl auch noch wichtig... ![]() |
Berni_W.
18:47
#399
Hallo Erst mal danke für den sachlichen Umgang mit meinem Beitrag. Hoffentlich erlaubt Ihr mir Eure Antworten auszudrucken und meinem "Expert"-Händler vorzulegen. Ausserdem fragte ich ihn vorhin nach dem Preis. Er sagte nur er wird den XL2E zum UVP verkaufen, weil so eine grosse Nachfrage besteht. Zu den Preisunterschieden zu anderen Händlern führte er nur oben genannte Gründe (B-Ware) an. Ebenso kann er es sich nicht vorstellen, dass so kleine Händler günstiger einkaufen als so eine Handelskette wie Expert. Irgendwie neigte ich dazu ihm zu glauben. Allein schon Eure Berichte über pfeiffende und piepsende Netzteile und die anderen Bugs verleiteten mich dazu.
Grauimport?! Berni |
netzer79
18:57
#400
Bei Mediaran haben die auch schon den 42 und 52er lieferbar. Die machen auch Werbung mit der Garantieverlängerung bei Regestrierung. Das wäre ja ein schlechter Witz, wenn die Grauware verkaufen würden und auf der HP einen Direktlink zu Sharp hätten. Meines wissens verkaufen die auch nur deutsche Geräte. Grüße, Netzer79 |
Tomasz33
19:17
#401
Für Deutschland werden die mit anderem Serien-Nr produziert ![]() In der Fabrik werden XL2 i X20 produziert,und da bin ich 100% sicher! parr fotos ![]() |
Sharp LC-46 XL 2E ? SkELEt0R am 25.11.2007 – Letzte Antwort am 30.06.2009 – 18 Beiträge |
Sharp LC-42 XL 2E Snake2k am 28.04.2008 – Letzte Antwort am 30.04.2008 – 6 Beiträge |
PS3 + Sharp LC 42 XL 2E karlos_sharp am 02.05.2008 – Letzte Antwort am 24.05.2008 – 14 Beiträge |
Sharp LC-46 XL 2E vs. Sharp LC-46 X20E FreddyGN am 10.03.2008 – Letzte Antwort am 14.03.2008 – 19 Beiträge |
Sharp LC-46 XL 2E wo bestellen? .Neo. am 09.01.2008 – Letzte Antwort am 14.01.2008 – 6 Beiträge |
Sharp LC-46 / 52 D65E bratwurst2001 am 04.12.2008 – Letzte Antwort am 19.08.2010 – 248 Beiträge |
PC-Auflösung beim LC-52 XL 2E DocPepper am 11.02.2008 – Letzte Antwort am 23.02.2008 – 3 Beiträge |
Sharp LC-52 XL 1E Eisenfreund am 26.07.2007 – Letzte Antwort am 04.09.2007 – 31 Beiträge |
suche Codes für Sharp LC 46 XL 2E pil am 16.12.2008 – Letzte Antwort am 16.12.2008 – 2 Beiträge |
SHARP LC 52 xd 1e / SHARP LC 52 xl 1e secret am 02.07.2007 – Letzte Antwort am 09.11.2007 – 7 Beiträge |
Top 10 Threads in Sharp der letzten 7 Tage
- LC 37GA8E schaltet ein und sofort wieder aus
- Aquos LC-TV: Neue Fernbedienung koppeln
- Sharp LC-60LE635E Bildeinstellungen
- Programmweiterschaltung spinnt auf einmal!
- Fehlercode im Display Sharp Aquos TV K LC-B43CF5242EB
- SHARP LC42 XL2E Kein Bild nach einschalten ->Lösung!
- Programmliste ändern ? SHARP LE705E
- Probleme mit Aquos Net+ (Kein Dienst Verfügbar)
- SharpTV: keine Digitalen Programme über Kabel
- Kein Vollbild auf meinem Sharp 42 XD1E bei 16:9 Material
Top 10 Threads in Sharp der letzten 50 Tage
- Registrierte Mitglieder926.403 ( Heute: 3 )
- Neuestes MitgliedRainerZufall#frei
- Gesamtzahl an Themen1.552.831
- Gesamtzahl an Beiträgen21.578.281
