HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Samsung » Samsung 7/8/9-series firmware research | |
Samsung 7/8/9-series firmware research+A -A |
JOCKYW2001
#1 erstellt: 18. Jan 2009, 17:32 | |
First of all I aplogize for writing in english, I can read german but don't write it. As I like to reverse engineer various embedded systems (consoles, mobile phones, dvd players etc.) I decided to look at my samsung le40a756 and want to present my current findings. I hope a few of you are interested in this topic, but if you don't feel comfortable with firmware reverse engineering I'm sorry to have bothered you. Of course I have also to issue a warning: by doing something wrong or by selecting a wrong option or making a wrong setting you can nuke your expensive device!!! Finally, by entering the service menu your warranty will no longer be valid (at least in theory, as far as i know Samsung service cannot check it, i.e. if you restore the original settings before) I first entered the Service Menu (SM) by clicking Info-Menu-Mute-Power and then started to take pictures of all menus. To enter the hidden menu options I had to select the advanced menu and type 0000 followed by return. In the Control menu I set "EDID Protect" to 'Off' and in the Adjust menu I set to "UART Select" from 'Wall Mount' to 'STi' after which I set "EDID Protect" back to 'On'. The main controller cpu is a STi, a similar processor can be found in a Kathrein UFS910 sat receiver. It is no surprise that the OS in current Samsung LCD TVs is Linux and from other embedded devices I know it is possible to create a bootlog of the boot, execution and shutdown phase. It is usually even possible to interrupt the boot process and then to boot alternative software via the network. My targets are to enable a telnet daemon and then to compile a movie and dvd player for my TV. So I then took the serial cable of my old Philips Pronto and plugged in the 3.5mm service jack of the TV and the other end in my laptop. Then I started Putty (you can also take Hyperterminal) set serial params to 115200/8/n/1/no and switched on the TV. The bootlog can be found below. By pressing enter I could as expected stop the boot process and enter the STb7109 bootloader. Now I will try to find out how to enable a telnet daemon after which the quest can continue Okay that's it for now. I will post my SM pictures in a further posting. Hopefully one or the other is interested in this project and can contribute. Have fun, JockyW Interesting links: * Samsung Service Menu Research * Block Diagrams of current LCD TVs * Samsung televisions run linux bootlog: =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2009.01.18 14:46:48 =~=~=~=~=~=~=~=~=~=~=~= Enter MBL..[0001] _ShadowOS. Board: STb7109 *** Samsung U-Boot 1.1.2 (FlexOneNand) VER : 0029 - 195MHz (Jul 31 2008 - 12:49:44) - st2.0-14 *** DRAM: 128 MB *** Warning - bad CRC or NAND, using default environment In: serial Out: serial Err: serial Net: Using MAC Address 00:xx:xx:xx:xx:xx STMAC: SMSC LAN8700 found eeprom = 0 Hit any key to stop autoboot: 0 bbm close success ## Booting image at 84100000 ... Image Name: Linux 2.6 Image Type: SH-4 Linux Kernel Image (uncompressed) Data Size: 2864469 Bytes = 2.7 MB Load Address: 84601000 Entry Point: 84602000 OK Starting kernel console=ttyAS0,115200 mem=84M root=/dev/tfsr6 rw rootfstype=squashfs bigphysarea=2000,watchdog:4000,rxsize:512 quiet - 0x00000000 - 0 ... ##### set bit at net_dev_init *** ST LINUX 2.2 KERNEL (FlexOneNand) VER : 0040 , DATE : Jul 27 2008 *** Starting pid 16, console /dev/console: '/etc/init.d/rcS' ##### dev_open Starting pid 24, console /dev/console: '/bin/sh' BusyBox v1.2.1 (2008.02.21-04:09+0000) Built-in shell (ash) Enter 'help' for a list of built-in commands. *** ST RootFS (FlexOneNand) VER : 0024 , DATE : 2008.07.14 *** ***** profile start ... ***** *** ST Boot Partition (FlexOneNand) VER : 0046 , DATE : 2008.07.27 *** boot script rc.local start!!! module fsr is loaded. code address is 0xc0162000 module fsr_stl is loaded. code address is 0xc019d000 module rfs is loaded. code address is 0xc0134000 module KBUILD_MODNAME is loaded. code address is 0xc011e000 --------------- mount start ----------------- Board reset complete! /mtd_rwarea/PartitionSwitch_1_0 is detected... 2nd Partition is selected... sda: assuming drive cache: write through sda: assuming drive cache: write through ----------- Kernel Loading End------------ Application is started.. insmod start.... module lxload is loaded. code address is 0xc0153000 module lxload is loaded. code address is 0xc0153000 module embxshell is loaded. code address is 0xc0153000 module embxloopback is loaded. code address is 0xc0159000 module embxmailbox is loaded. code address is 0xc015c000 module embxshm is loaded. code address is 0xc01e6000 module mme_host is loaded. code address is 0xc01d4000 sda: assuming drive cache: write through FIXED SELP: no partition Media Connected module stapi is loaded. code address is 0xc0586000 Load module stos_core [?]by insmod (pid 113) Load module staudlx_core [241]by insmod (pid 113) Load module stfdma_ioctl [232]by insmod (pid 113) Load module stfdma_core [230]by insmod (pid 113) module sttkdma_core is loaded. code address is 0xc01dc000 Load module sttkdma_core [229] by insmod (pid 150) module sttkdma_ioctl is loaded. code address is 0xc01f2000 Load module sttkdma_ioctl [228] by insmod (pid 151) / insmod finish...... [PROF] [4294672.800] PerfCheck ST Board Init, Build Date Nov 12 2008 12:29:14 St-App Version : 2008091701 St-Ko version : 2008111201 enter1 IIC Initialization done! [Drv_Micom] SerialInit: /dev/ttyAS2 | fd:0xa SetSerialBlockingMode() | fd: 0xa platform_init MIW_Init acquire_adh wait acquire_adh done SetSerialBlockingMode() | fd: 0xa [HAL_InitPanel] OSD Res Type : 2, sizeof(E_OSD_RES):4 [HAL_InitPanel] OSD Res Write: Base:0x2c0b Target:0x2c2c [Drv_Micom] SerialInit: /dev/ttyAS3 | fd:0x13 DRV_GPIO_Init DRV_IIC_Init IIC Initialization already done! OSD order is: MTK | ST 32bit | ST 8bit | ST 32bit for jpeg [HAL_SetCfgModel] OSD_RES : SXGA (1920x1080) [DRV_USB] Set Osd Res : 2 platform_init InitPanel platform_init InitMFI [VDH_FBE_Init] bPanelType = 0 [FBE2] IsPDP = [0] [FBE2] ePanelType = [3] [FBE2] ePanelRes = [2] [FBE2] ePanelSize = [5] [FBE2] eDimmType = [2] Marked index 1 NVH_Init melody_thread InitStanby ----- Ajust Xstop for HDMI output when 1920x1080@50Hz ----- ACCESS 00000002 Open Read/Write TTX_Init In STBoard!!! DENC_DAC6_MULT is set to be 0xa ++++++++++++++++++++++++OUT STBOARDINIT+++++++++++++++++++++++++++++++++++++++ System init OK Core Software Platform (TM) 1.1 Copyright (C) SAMSUNG Electronics Co.,Ltd. TCTvMiddleware::Initialize() start [M_TIME_BOOT/Major] [00000:0000] Louvre Platform Start... [PROF] Create CPerfCheck(DSP Start) [PROF] [4294673440] [0.640] [0.640] Build Start AVH_Open : IN +++++++++++USE LINUX pthread_mutex_lock in AVH++++++++++ AVH_Open : OUT AVH_Open : IN AVH_Open: AVH is already opened! AVH_Open : IN AVH_Open: AVH is already opened! [MMS_CORE ] [bool MSCMgr::Create()] [MovieCore_STi] CMovieCore_STi In [MovieCore_STi] CMovieCore_STi Out [MovieCore_STi] Initialize In [MovieCore_STi] Initialize Out [DEV_CORE ] [bool CompDeviceMgr::Create()] ... [MMS_PHOTO ] [virtual void CPhotoManager::t_Main():167] [PROF] [4294673530] [0.730] [0.090] Build End [PROF] [4294673530] [0.730] [0.000] Platform Start Up wait_standby_init_done wait wait_standby_init_done done SetSerialBlockingMode() | fd: 0xa ================================================== START MicomInput Thread _CEC_APPLY_ ================================================== SsStore has SAME Version... So System doesn't set Nvram to Default value !! [PROF] [4294673650] [0.850] [0.120] CheckChannelTable() Start [I2C][ERROR : _iicWrite():889] STI2C_Write : 1 BUS 02 DEV 54 [I2C][ERROR : DRV_IIC_WriteDriverCh():583] _iicWrite --> Error Read Channel Map Info : 1 [PROF] [4294673660] [0.860] [0.010] CheckChannelTable() End [PROF] [4294673660] [0.860] [0.000] Platform Start Up end [M_TIME_BOOT/Major] [00240:0240] Subsystem Create And Init completed DMH_Open : IN +++++++++++USE LINUX pthread_mutex_lock in DMH++++++++++ DMH_Open : OUT DMH_Open : IN +++++++++++USE LINUX pthread_mutex_lock in DMH++++++++++ DMH_Open : OUT DMH_Open : IN +++++++++++USE LINUX pthread_mutex_lock in DMH++++++++++ DMH_Open : OUT [I2C][ERROR : _iicWrite():889] STI2C_Write : 1 BUS 02 DEV 56 [I2C][ERROR : DRV_IIC_WriteDriverCh():583] _iicWrite --> Error [M_TIME_BOOT/Info] [00410:0170] HAL Initialized melody_thread InitADH [M_TIME_BOOT/Major] [00420:0010] PMS Initialized melody_thread MuteAmp+ melody_thread MuteAmp- [I2C][ERROR : _iicRead():785] STI2C_WriteNoStop: 1 BUS 00 DEV d2 [I2C][ERROR : DRV_IIC_ReadDriverCh():693] _iicRead --> Error [I2C][ERROR : _iicRead():785] STI2C_WriteNoStop: 1 BUS 00 DEV d2 [I2C][ERROR : DRV_IIC_ReadDriverCh():693] _iicRead --> Error [I2C][ERROR : _iicRead():785] STI2C_WriteNoStop: 1 BUS 00 DEV d2 [I2C][ERROR : DRV_IIC_ReadDriverCh():693] _iicRead --> Error Marked index 0 FBE Init. Ok platform_init InitFBE platform_init InitINH ALPS Tuner Not Found SEMCO Tuner :: S5H1432 DRV_S5H1432_Initialize OK platform_init InitFEH VDH_Init Start Wait index 0 880 msecs [DEFAULT/Info] 0 : ####Channel Magic Key ! old = 4 new = 4 !!!#### ~~[Sub System Error] SsPicture.cpp:GetScreenOption():3268 Not Support Screen Option 28 TCTvMiddleware::Initialize() end INITED IN PFM CSP: MTK_Screen8 START [DRV_USB] USB Port is Opened (fd:0x1a) [DRV_USB] Get Osd Res : 2 [DRV_USB] OSD Res : 1920x1080 USB: MTK_USB_Init END [CSP:SpcScreen] Scaler OSD Resolution 1920x1080 SAMSUNG (R) Core SW Platform 2.0 for CSP 1.1 Copyright (C) SAMSUNG Electronics Co.,Ltd. [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 APP_INITIALIZE(); end [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 VDH_Init : Wait FRCM Init..(~1sec) ITPCTv::Power, ######## 1 ######## 456 ControlTTXCommand 2 18 0 ================================================== ------------------- NORMAL MODE ------------------ ================================================== [PROF] [4294675160] [2.360] [1.500] ProcessPowerUp Start [PROF] [4294675190] [2.390] [0.030] SsSound::Play [PROF] [4294675200] [2.400] [0.010] SsSound::Play End [PROF] [4294675200] [2.400] [0.000] pApiSCL->Initialize() [SCL:BEFORE INIT] NVH_ReadNvram: ETC. [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 Read Channel Map Info : 1 [SCL:AFTER INIT] NVH_ReadNvram: ETC. [PROF] [4294675570] [2.770] [0.370] pApiSCL->Initialize() End [PROF] [4294675570] [2.770] [0.000] handleNormalDevInit 0 wait_powerup_init_done wait VDH_Init End platform_init InitVDH acquire_adh wait acquire_adh done flag_powerup_init_done platform_init InitTTX wait_powerup_init_done done [PROF] [4294676010] [3.210] [0.440] handleNormalDevInit 1 Panel Type : [3], SAME [SSPlatform] If this poin died, UartPort Check: 0 Auto Wall Mount NOT Detected!! [FEH][ERROR : FEH_Init():382] already initialized AVH_AudioSetCompressionMode : IN, audio mode=0 AVH_AudioGetAttenuation : IN AVH_AudioGetAttenuation : OUT ================================================== --------------- NORMAL MODE COMPLETE-------------- ================================================== AVH_SetDynamicResolution : Enter on=TRUE AVH_SetDynamicResolution : Out [PROF] [4294676170] [3.370] [0.160] Hal Init End [PROF] [4294676170] [3.370] [0.000] SetPower End [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294676170] [3.370] [0.000] ProcessSystemReady Start [PROF] [4294676190] [3.390] [0.020] handleSystemReady Start [PROF] [4294676200] [3.400] [0.010] SsWindow::Show [PROF] [4294676200] [3.400] [0.000] SsWindow::Show 1...!!! [PROF] [4294676200] [3.400] [0.000] SsWindow::handleShowOn in [PROF] [4294676220] [3.420] [0.020] SsWindow::handleShowOn out [PROF] [4294676220] [3.420] [0.000] SsWindow::Show End [PROF] [4294676220] [3.420] [0.000] SsSound::Play [PROF] [4294676220] [3.420] [0.000] SsSound::Play End [PROF] [4294676220] [3.420] [0.000] SsSound::Play [PROF] [4294676220] [3.420] [0.000] SsSound::Play End [PROF] [4294676250] [3.450] [0.030] SsFrontEnd::Connect [PROF] [4294676260] [3.460] [0.010] SsFrontEnd::Work Start [PROF] [4294676310] [3.510] [0.050] handleSystemReady End [PROF] [4294676310] [3.510] [0.000] handleScreenOn Start [PROF] [4294676310] [3.510] [0.000] [PANEL TIMING] PVCC ON VDH_SetFRCLvdsOutput (1) [PROF] [4294676350] [3.550] [0.040] [PANEL TIMING] LVDS ON [PROF] [4294676360] [3.560] [0.010] handleScreenOn End [PROF] [4294676390] [3.590] [0.030] SsFrontEnd::SetFacItem End AVH_AudioSetAttenuation : IN AVH_AudioSetAttenuation : OUT ~~[Sub System Error] SsMon.cpp:StopMonitor():586 Aleady Stop Handle 12 [PROF] [4294676650] [3.850] [0.260] SsFrontEnd::Connect End [PROF] [4294676660] [3.860] [0.010] SsWindow::Start [PROF] [4294676660] [3.860] [0.000] SsWindow::Start End [PROF] [4294676670] [3.870] [0.010] SsWindow::Show [PROF] [4294676670] [3.870] [0.000] SsWindow::Show 1...!!! [PROF] [4294676670] [3.870] [0.000] SsWindow::handleShowOn in [PROF] [4294676670] [3.870] [0.000] SsWindow::handleShowOn out [PROF] [4294676670] [3.870] [0.000] SsWindow::Show End [PROF] [4294676690] [3.890] [0.020] SsFrontEnd::Connect ~~[Sub System Error] SsMon.cpp:StopMonitor():601 Can't Search Handle 0 [PROF] [4294676690] [3.890] [0.000] SsFrontEnd::Connect End [PROF] [4294676690] [3.890] [0.000] SsWindow::Start [PROF] [4294676690] [3.890] [0.000] SsWindow::Start End [PROF] [4294676690] [3.890] [0.000] SsFrontEnd::SetTune [FEH_Tune] TunerMode Changed(UNKNOWN->A) -> feh_TuneSetDtvPartSleep(TRUE) ~~[Sub System Error] SsMon.cpp:StopMonitor():586 Aleady Stop Handle 3 [PROF] [4294676920] [4.120] [0.230] SsFrontEnd::SendTunedEvent [PROF] [4294676940] [4.140] [0.020] Start [PROF] [4294676950] [4.150] [0.010] ProcessSystemReady End [PROF] [4294677030] [4.230] [0.080] SsFrontEnd::SetTune End FlagTune Called FlagTune Called [PROF] [4294677410] [4.610] [0.380] [PANEL TIMING] Inverter ON [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294678170] [5.370] [0.760] SsFrontEnd::SendLockEvent UNLOCK Timed out, sending resolution event anyway [PROF] [4294678220] [5.420] [0.050] SsWindow::Show [PROF] [4294678220] [5.420] [0.000] SsWindow::Show 1...!!! [PROF] [4294678220] [5.420] [0.000] SsWindow::handleShowNoSignal in [PROF] [4294678220] [5.420] [0.000] SsFrontEnd::SendResolutionEvent [PROF] [4294678250] [5.450] [0.030] SsWindow::handleShowNoSignal out [PROF] [4294678250] [5.450] [0.000] SsWindow::Show End [SCH][WARNING : SCH_ReqSyncLock():2879] Retry 1 ~~[Sub System Error] SsPicture.cpp:CheckScreenOption():3675 Not Support Screen Option 28 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294679250] [6.450] [1.000] SsFrontEnd::SendResolutionEvent [PROF] [4294679290] [6.490] [0.040] SsWindow::Show [PROF] [4294679290] [6.490] [0.000] SsWindow::Show 1...!!! [PROF] [4294679300] [6.500] [0.010] SsWindow::handleShowStop in [PROF] [4294679300] [6.500] [0.000] SsWindow::handleShowStop out [PROF] [4294679300] [6.500] [0.000] SsWindow::Show End [PROF] [4294679300] [6.500] [0.000] SsSound::Play [PROF] [4294679300] [6.500] [0.000] SsSound::Play End [PROF] [4294679300] [6.500] [0.000] SsWindow::Stop [PROF] [4294679300] [6.500] [0.000] SsWindow::Stop End [PROF] [4294679300] [6.500] [0.000] SsWindow::SetInputResolution [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294679370] [6.570] [0.070] handleModeChangeProfile In [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 USB : From now, no more insmod USB : Exit Load USB module uSkinTone = [15], wValue = [4], skinUV = [140], MskinUV = [132] [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294680390] [7.590] [1.020] handleModeChangeProfile End [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294680410] [7.610] [0.020] SsWindow::SetInputResolution End [PROF] [4294680410] [7.610] [0.000] SsWindow::Start [PROF] [4294680410] [7.610] [0.000] SsWindow::Start End [PROF] [4294680440] [7.640] [0.030] SsWindow::Show [PROF] [4294680440] [7.640] [0.000] SsWindow::Show 1...!!! [PROF] [4294680440] [7.640] [0.000] SsWindow::handleShowStart in [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [PROF] [4294680710] [7.910] [0.270] SsWindow::Show Start [PROF] [4294680710] [7.910] [0.000] SsWindow::handleShowStart out [PROF] [4294680710] [7.910] [0.000] SsWindow::Show End [PROF] [4294680710] [7.910] [0.000] SsSound::Play AVH_AudioDescriptionSetAttenuation : IN AVH_AudioDescriptionSetAttenuation : OUT [PROF] [4294680790] [7.990] [0.080] SsSound::Play End [PROF] [4294680790] [7.990] [0.000] SsWindow::Show [PROF] [4294680790] [7.990] [0.000] SsWindow::Show 1...!!! [PROF] [4294680790] [7.990] [0.000] SsWindow::handleShowStart in [PROF] [4294680790] [7.990] [0.000] SsWindow::handleShowStart out [PROF] [4294680790] [7.990] [0.000] SsWindow::Show End [PROF] [4294680790] [7.990] [0.000] SsSound::Play [PROF] [4294680790] [7.990] [0.000] SsSound::Play End [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 DLNAStart() InitUPnPCP after USB Modules are already installed [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 [SsPicture::GetScreenOption] E_OSD_RES_1920x1080 MicomVersion : RBYDEUM1007.0 RiskVersion : 15 78 21 8 [PROF] [4294689940] [17.140] [9.150] Execute [PROF] [4294689940] [17.140] [0.000] handleDeviceInit Start MAC Address is invalid! Trying to another method... SetMacAddress(00:xx:xx:xx:xx:xx) : [371] ================================ == Read Network Information == ================================ SETTING_TYPE = 3 HOST = 0.0.0.0 GATEWAY = 0.0.0.0 NETMASK = 0.0.0.0 DNS = 0.0.0.0 HWAddr = 0##### dev_open 0:xx:xx:xx:xx:xx =========================== ifconfig eth0 0.0.0.0 up : [372] Set Dev=0 state 1 =========================== == Writing Network Info == =========================== SETTING_TYPE = 3 sync : [373] HOST = 0.0.0.0 GATEWAY = 0.0.0.0 NETMASK = 0.0.0.0 DNS = 0.0.0.0 =========================== udhcpc -i eth0 -b : [374] info, udhcpc (v1.2.1) started debug, Sending discover... debug, Sending discover... [PROF] [4294693410] [20.610] [3.470] handleDeviceInit End debug, Sending select for 192.168.1.65... info, Lease of 192.168.1.65 obtained, lease time 864000 deleting routers route: SIOC[ADD|DEL]RT: No such process adding dns 192.168.1.1 DEVICE = eth0 Error Finding serialNumber value in XML Node [PROF] [4294700410] [27.610] [7.000] Send App. Init Ok [PROF] Clear CPerfCheck(Key 0x02) ~~[Sub System Error] SsSound.cpp:SetSpeakerOption():2910 Not Support option... 6 [PROF] [4294722650] [0.930] [0.930] SsWindow::Show [PROF] [4294722660] [0.940] [0.010] SsWindow::Show 1...!!! [PROF] [4294722660] [0.940] [0.000] SsWindow::handleShowStop in [PROF] [4294722660] [0.940] [0.000] SsWindow::handleShowStop out [PROF] [4294722660] [0.940] [0.000] SsWindow::Show End [PROF] [4294722660] [0.940] [0.000] SsWindow::Stop ~~[Sub System Error] SsWindow.cpp:GetSsSound():9424 Not Matching Window ID - winodwId : 0, eWindowId : 2 [PROF] [4294722660] [0.940] [0.000] SsWindow::Stop End [PROF] [4294722660] [0.940] [0.000] SsFrontEnd::Disconnect ~~[Sub System Error] SsEventList.cpp:SendEvent():210 Not Register Event, whatHal 1, id 2, eventType 3 ~~[Sub System Error] SsWindow.cpp:SendMTSEvent():434 SendMTSEvent...Error [PROF] [4294722700] [0.980] [0.040] SsFrontEnd::Disconnect End [PROF] [4294722700] [0.980] [0.000] SsWindow::Show [PROF] [4294722700] [0.980] [0.000] SsWindow::Show 1...!!! [PROF] [4294722700] [0.980] [0.000] SsWindow::handleShowOff in [PROF] [4294722700] [0.980] [0.000] SsWindow::handleShowOff out [PROF] [4294722700] [0.980] [0.000] SsWindow::Show End [PROF] [4294722700] [0.980] [0.000] SsSound::Play [PROF] [4294722760] [1.040] [0.060] SsSound::Play End [PROF] [4294722760] [1.040] [0.000] SsWindow::Show [PROF] [4294722760] [1.040] [0.000] SsWindow::Show 1...!!! [PROF] [4294722790] [1.070] [0.030] SsWindow::handleShowStop in [PROF] [4294722790] [1.070] [0.000] SsWindow::handleVideoMute Start [PROF] [4294722800] [1.080] [0.010] handleVideoMute End [PROF] [4294722800] [1.080] [0.000] [--------------------SUN]Video Mute on [PROF] [4294722820] [1.100] [0.020] SsWindow::handleShowStop out [PROF] [4294722820] [1.100] [0.000] SsWindow::Show End [PROF] [4294722820] [1.100] [0.000] SsWindow::Stop [PROF] [4294722820] [1.100] [0.000] SsWindow::Stop End [PROF] [4294722820] [1.100] [0.000] SsFrontEnd::Disconnect [PROF] [4294722920] [1.200] [0.100] SsFrontEnd::Disconnect End [PROF] [4294722920] [1.200] [0.000] SsSound::Play [PROF] [4294722920] [1.200] [0.000] SsSound::Play End [PROF] [4294722920] [1.200] [0.000] SsWindow::Show [PROF] [4294722920] [1.200] [0.000] SsWindow::Show 1...!!! [PROF] [4294722920] [1.200] [0.000] SsWindow::handleShowOff in [PROF] [4294722950] [1.230] [0.030] SsWindow::handleShowOff out [PROF] [4294722950] [1.230] [0.000] SsWindow::Show End ITPCTv::Power, ######## 0 ######## [PROF] [4294723110] [1.390] [0.160] SetPower End AVH_VideoOnScreen : IN AVH_VideoOnScreen : Same as currnet Status, just return [PROF] [4294723150] [1.430] [0.040] handleMelody |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| ||| Go to Cool Down..!!! ||| |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| VDH_SetFRCLvdsOutput (0) |
JOCKYW2001
#2 erstellt: 18. Jan 2009, 17:33 | |
** reserved for SM pictures ** |
RalfWer
#3 erstellt: 03. Feb 2009, 23:13 | |
Hallo JOCKYW2001, sehr interessant, auch die Links. Leider bin ich was Linux angeht nicht besonders fit, so dass mir nur die Rolle eines Zuschauers bleibt. Ich hoffe es finden sich ein paar fähigere Mitstreiter, Grüße Ralf PS:: Info-Menu-Mute-Power hat bei mir nicht funktioniert. Müssen die Knöpfe alle gleichzeitig gedrückt werden? |
JOCKYW2001
#4 erstellt: 04. Feb 2009, 00:28 | |
Hi Ralf, put TV in standby and then press Info-Menu-Mute-Power sequentially (not simultaneously). Once you have entered the service menu be careful. On the remote control the navigation keys are arrow up and arrow down. "Select" and "Enter" is the arrow right key and "go back" is the key marked Return. To exit the service menu you must power down. Be careful with the arrow right as it can easily happen you change something unintentionally. |
JOCKYW2001
#5 erstellt: 08. Feb 2009, 16:07 | |
I discovered there is wlan stick support in the 1010.0 firmware for 7/8/9-series for wlan sticks with a Ralink RT73STA chipset. These sticks are available on the market for example here: http://www.tuxhardware.de/product1270/product_info.html (Conceptronics C54RU) http://www.amazon.de...id=1234098205&sr=8-2 (BIGtec) http://catalog.belki...ss?Product_Id=179211 Belkin Wireless G USB key (i have that one) Unfortunately the kernel module "rt73.ko" isn't loaded during boot. It is commented out in the loader script /boot/modules/st/load.sh You can easily verify by unpacking the firmware and then mount it in you favorite linux distro with loop devices and squashfs support. The command is: mount -o loop -t squashfs rootfs.img local-mount-dir I meanwhile know how I can add a telnet daemon so it will be possible to load the stick later. Maybe it doesn't work so well and that may be the reason Samsung took it out in their firmware. |
dynamic1969
#6 erstellt: 18. Jul 2009, 01:31 | |
Hi JOCKYW2001, I have today soldered a serial cable for my UE46B7000 and was also able to see and capture the bootlog. Unfortunately there seems to be no getty that would allow to use it as a console. I am therefore really looking forward to see as to how you are going to enable a telnetd on your device ( does the busybox include a telnetd ? ) btw. the UE46B7000 already comes with USB WLAN Stick support, why I think that it is promising that WLAN support should also be possible on the other devices. Regards dynamic1969 |
Flippo24
#7 erstellt: 27. Jul 2009, 11:57 | |
Great work! I am interessted in an alternative Firmware for the UE46Bxxxx to. Maybe this will help... http://www.samsung.com/global/opensource/ first parts and last part from this post... http://www.linux-com...mages-entschluesseln |
KAUF TIP 46" 7 ? 8 ? 9 ? ) owo am 20.01.2009 – Letzte Antwort am 23.01.2009 – 9 Beiträge |
Samsung Series 5 - Firmware Version anzeigen? Marsh am 09.07.2009 – Letzte Antwort am 12.07.2009 – 7 Beiträge |
Samsung UE40ES5700 Firmware von F Series? focus_msd am 11.01.2014 – Letzte Antwort am 11.01.2014 – 6 Beiträge |
Neue FW 7, 8, 9 serie! White-Ghost am 27.05.2009 – Letzte Antwort am 28.05.2009 – 3 Beiträge |
neue Firmware,Samsung 7-Serie ? mamfred am 19.10.2015 – Letzte Antwort am 22.10.2015 – 4 Beiträge |
Samsung LE-46M86BD Firmware x-perience1 am 08.08.2007 – Letzte Antwort am 08.08.2007 – 3 Beiträge |
Samsung A656 - Firmware yoh am 24.03.2009 – Letzte Antwort am 25.03.2009 – 2 Beiträge |
Neue Firmware für LE**C6, 7, 8 Series (2010 Modelle): T-VALDEUC-2002.0 __Tom__ am 17.05.2010 – Letzte Antwort am 03.12.2010 – 187 Beiträge |
Samsung LE-A557 Series sK1n am 13.01.2009 – Letzte Antwort am 13.01.2009 – 4 Beiträge |
Samsung C-Series PIP gczueri am 10.01.2011 – Letzte Antwort am 10.01.2011 – 2 Beiträge |
- Registrierte Mitglieder927.115 ( Heute: 9 )
- Neuestes Mitgliedlonacosta729
- Gesamtzahl an Themen1.554.831
- Gesamtzahl an Beiträgen21.622.907
