MKV
seven.7en
#1 erstellt: 29. Dez 2021, 00:06
Moin,
Mein Fernseher PUS6501 (@autorun_QM163E_000.1.15.108 - ich weiss ist nicht die neueste Firmware) kann folgende Datei mit dem internen Player nicht wiedergeben, wohl aber mit dem MX Player, woran mag das wohl liegen:
General
Unique ID : 133559733864943450236017752580601970138 (0x647AAB48ECA7470FF7AD4812B9107DDA)
Complete name : Schottland.mkv
Format : Matroska
Format version : Version 4
File size : 2.13 GiB
Duration : 22 min 34 s
Overall bit rate : 13.5 Mb/s
Encoded date : UTC 2020-09-23 10:31:22
Writing application : mkvmerge v44.0.0 ('Domino') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings : CABAC / 8 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 12.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Stream size : 1.89 GiB (88%)
Writing library : x264 core 159 r2991 1771b55
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 124 MiB (6%)
Language : German
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate : 768 kb/s
Bit depth : 24 bits
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 21 min 54 s
Bit rate : 45.8 kb/s
Count of elements : 407
Stream size : 7.18 MiB (0%)
Language : German
Default : No
Forced : No
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Bit rate : 92 b/s
Count of elements : 385
Stream size : 14.8 KiB (0%)
Language : English
Default : No
Forced : No
Ich würde gerne mal klären, woran sich der Fernseher stört. An den Tonspuren liegt es nicht, da ich die Videospur auch schon extrahiert hatte.
[Beitrag von seven.7en am 29. Dez 2021, 00:08 bearbeitet]
seven.7en
#2 erstellt: 29. Dez 2021, 12:24
Nach weiteren Recherchen bin ich der Meinung das es wahrscheinlich daran liegt:
Wenn ich dieser Anleitung folge
tsmuxer import mkv> change 5.0 to 4.1 in level box select demux > remux mkvtoolnix
Dann läuft der Film mit dem internen Player. Selbes Prozedere und ich lasse das Level 5.0 spielt der Film nicht.
Weiterhin bleibt die Frage, warum den MXPlayer L5 nicht stört und ob man den internen Player vielleicht updaten kann.
Toengel
#3 erstellt: 31. Dez 2021, 15:18
Tachchen,
die Firmware ist URALT - nicht mal Oreo - ist das überhaupt schon Nougat? Durch Firmware-Updates könnte der interne Player auch aktualisiert werden ;-)
Könntest auch den VLC installieren.
Toengel@Alex
seven.7en
#4 erstellt: 01. Jan 2022, 12:55
Ich will nur den Player updaten Da muss es doch eine apk für geben Vllt aus einer neueren Firmware extrahieren.
Toengel
#5 erstellt: 01. Jan 2022, 13:03
Tachchen,
der interne Player ist Teil des OS - kannst du nicht extrahieren.
Wenn nimm einen anderen Player aus dem Play Store. (VLC bspw.)
Toengel@Alex
seven.7en
#6 erstellt: 02. Jan 2022, 00:36
Moin mein Lieber,
vielen Dank erstmal dass Du Dir für mich Zeit nimmst.
Ich habe gerade den internen Mediaplayer extrahiert. Das geht wie folgt:
1. ADB Fastboot starten
2. adb connect IP.DES.FERNSEHERS:5555 eingeben
3. adb pull /system/app/contentexplorer/contentexplorer.apk C:\Users\DEINNAME\Desktop
4. adb pull /system/app/dlna/dlna.apk C:\Users\DEINNAME\Desktop
ContentExplorer = Medien (Interner Mediaplayer)
DLNA = File Explorer um auf Medien auf dem PC zu zugreifen.
Den genauen Speicherort habe ich mit AppExplore lokalisiert.
Könntest Du mir diese beiden Files besorgen wenn es Deine Zeit zu lässt, von einer neueren Firmware
[Beitrag von seven.7en am 02. Jan 2022, 13:54 bearbeitet]
Welche Codes werden vom PFL 6158K unterstürzt?
DeCrypter13 am 12.01.2014  –  Letzte Antwort am 12.01.2014  –  3 Beiträge
32PFL7403D/10 Firmware-Upgrade
Muetzel am 13.11.2008  –  Letzte Antwort am 14.11.2008  –  4 Beiträge
Firmware Version
Mave84 am 08.12.2013  –  Letzte Antwort am 08.12.2013  –  5 Beiträge
Firmware 42PFL9603D/10
predator5 am 03.12.2008  –  Letzte Antwort am 05.12.2008  –  4 Beiträge
3D Film Format MKV
klaus000000 am 13.10.2012  –  Letzte Antwort am 14.10.2012  –  3 Beiträge
42PF7641D/10 firmware Version: 0.93.0.0
felixnoha am 11.06.2007  –  Letzte Antwort am 12.06.2007  –  2 Beiträge
22 Volt Spannung auf Panelrückseite
skater789 am 04.03.2008  –  Letzte Antwort am 05.03.2008  –  5 Beiträge
*.mkv in abspielbares Format konvertieren
bl9009 am 16.12.2009  –  Letzte Antwort am 21.08.2010  –  16 Beiträge
42pfl8684 mkv dateien wiedergeben?
--hardy-- am 09.12.2009  –  Letzte Antwort am 09.12.2009  –  2 Beiträge
Welches HD Format für Philips 8404?
mensa am 08.02.2010  –  Letzte Antwort am 09.02.2010  –  3 Beiträge
2021
2022
  • Registrierte Mitglieder928.676 ( Heute: 11 )
  • Neuestes Mitgliedneitmoj
  • Gesamtzahl an Themen1.558.740
  • Gesamtzahl an Beiträgen21.709.434
Top Hersteller in Philips Widget schließen
