HIFI-FORUM » Car-Hifi » Car-Hifi: Endstufen » STEG 4.01 AMP +PHD FB 6.1 KIT PRO - WIE SOLL ICH D... | |
STEG 4.01 AMP +PHD FB 6.1 KIT PRO - WIE SOLL ICH DIE STEG AM BESTEN EINSTELLEN? (schreibt Deutsch)+A -A |
adeo
23:43
erstellt: 16. Jul 2012, |
Hi all! STEG K 4.01 einstellungen mit diesen PHD babies: ![]() PRO FIRENZE 6,5" Triple Layer Fiberglass Cone/Bass Driver; 1" Fiberglass/Silk Dome Neodymium Tweeter; 12dB Two Way Passive Crossover; Power Handling RMS/MAX: 150/300 Watts Sensitivity (SPL@1W): 92dB Frequency Response: 40Hz - 20Khz I have a question, I have installed my new PHD FB 6.1 KIT PRO with the STEG 4.01 AMP as you see on the attached link. I would like to SET up the STEG as perfectly as it gets but still I am not sure about some things I have read in the manual! Manual p.27-29... ![]() Questions - the filtereffect on the STEG - there are 2 possibilities - AQXM2, for the four way connection with the frequnce modules (since I do not have them and use crossovers from the PHD speaker Kit - I regard them as unnecessary) or SW4FQ - there are the 60,80,100,120, what should I turn on to get the best frequency divided sound? Then there is the filter on/off button - turn off? And the modes: mode LP - low pass/ HP - high pass? THANK YOU IN ADVANCE FRIENDS!! [Beitrag von adeo am 17. Jul 2012, 09:23 bearbeitet] |
Bajs
00:09
erstellt: 17. Jul 2012, |
Ok, i'm confused, but here goes: Wenn du das FQ-Modul nicht hast bleibt dir nur die Option SW4FQ. Das fungiert dann quasi als High-Pass-Filter, der sollte bei 60-80Hz liegen, am besten mal ausprobieren. Again, to make sure: Unless you own the frequency-module, you will have to use the "SW4FQ"-setting. This puts the amp in some sort of "manual"-mode, which enables you to either set high- or low-pass-filters, well...manually. Since you want to use your front speakers, you need to set a high-pass somehwere between 60-80Hz, depending on which setting u like best. Falls ich hier Blödsinn geredet habe - kenne die Stufe nicht wirklich, hab mich nur durch die BDA gekämpft - bitte korrigieren. |
adeo
08:37
Ja genau, die Module habe ich nicht also denke ich das die SW4FQ Option die Losung ist. Ich habe das System in Quadro - also 2x PHD FB KIT vorne und 2x PHD FB KIT hinten. Also alle 4 Kanale sind angeschlossen. Der STEG ist super, die Power unglaublich. Das heisst dann also, das der Filter AN sein soll oder AUS? Mode: Hp oder Lp ? Die Filter habe ich bei 60Hz liegen, kann es aber andern. Is ja logisch das ich den besten sound raushohlen will. Eigentlich will nur die Grundeinstellung hier richtig haben, denn es ist aus dem Manual auch nicht klar wenn was on / off ist ![]() NOCH IDEEN? M [Beitrag von adeo am 18. Jul 2012, 10:14 bearbeitet] |
Steg 4.01 schaltet ab? Black-Devil am 02.07.2008 – Letzte Antwort am 29.08.2008 – 2 Beiträge |
Steg K 4.01 & Steg K 2.02 grün leuchtet, rot blinkt marc226 am 01.10.2012 – Letzte Antwort am 01.01.2013 – 10 Beiträge |
Probleme beim Einpegeln (Steg K 4.01) raffiSSL am 21.08.2010 – Letzte Antwort am 25.08.2010 – 6 Beiträge |
PHD 4075 The-BuTcHeR am 24.06.2010 – Letzte Antwort am 24.06.2010 – 2 Beiträge |
Brückenbetrieb Steg? tonci am 26.05.2007 – Letzte Antwort am 26.05.2007 – 3 Beiträge |
FS-Amp Steg K4.01 gegen Steg K4.02 tauschen ? Abgetz am 27.04.2013 – Letzte Antwort am 27.04.2013 – 4 Beiträge |
Brauche Rat, wie Steg K verkabeln Darkkosmo am 09.08.2016 – Letzte Antwort am 10.08.2016 – 15 Beiträge |
Steg AQ reparieren! Pizzaro am 09.06.2010 – Letzte Antwort am 09.06.2010 – 3 Beiträge |
Welche Frequenzmofule ? Steg K Abgetz am 22.05.2013 – Letzte Antwort am 22.05.2013 – 2 Beiträge |
Steg K2.02 Massefehler 3510maniac am 27.02.2008 – Letzte Antwort am 20.04.2012 – 52 Beiträge |
2012
Top Produkte in Car-Hifi: Endstufen
- Protect Lampe leuchtet !
- Registrierte Mitglieder928.761 ( Heute: 3 )
- Neuestes MitgliedHardy64
- Gesamtzahl an Themen1.558.925
- Gesamtzahl an Beiträgen21.713.874
