HIFI-FORUM » Suche / Biete / Verschenke » Biete » Verstärker / Receiver » Integra DTA-9.4 - 7-Channel Digital Power Amplifie... | |
Integra DTA-9.4 - 7-Channel Digital Power Amplifier (Onkyo USA)+A -A |
Gardi
#1 erstellt: 30. Jun 2008, 01:43 | |
Preis: 399,- Euro Standort: Region Hannover Zustand: absolut neuwertig, nicht in Betrieb da Sammlerstück Artikelbeschreibung: Integra DTA-9.4 - 7-Channel Digital Power Amplifier Original US-Version, diese Endstufe ist in Europa nie im Handel gewesen. Auf Wunsch im SET mit Integra DTC-9.4 - THX Ultra2 Certified Preamplifier/Processor/Tuner, beide Geräte zusammen 629,- Euro Details wie z.B. Prospekt auf Anfrage. Auszug: Integra has introduced the DTA-9.4 seven-channel home theater amplifier, the company’s first digital and first multichannel home theater power amplifier. The Integra DTA-9.4 “Pure Digital” amplifier provides very high sound quality in part through exclusive digital technology and also by maintaining exceptional power linearity across the full impedance range of modern loudspeakers. It is capable of delivering 120 Watts into seven channels at 8 Ohms, and perfectly doubling that power to 240 Watts per channel into 4 Ohms. Designed specifically for multichannel home theater, the DTA-9.4's unique digital design gives it an operating efficiency of 90%, more than twice that of conventional class AB amplifiers, while at the same time having a smaller “footprint.” The high output current, 400 kHz switching power supply features 156,000 microfarads of capacitance for nearly inexhaustible current reserves, and complete compatibility with low impedance 4-Ohm speaker loads. The DTA-9.4 marks the first implementation of Integra's Vector Linear PWM (Pulse Width Modulation) technology, which combines an advanced digital switching topology with sophisticated shaping circuitry for remarkably detailed and efficient audio amplification. This shaping is performed using Vector Linear technology derived from the company’s high end D/A converters. This “remasters” the incoming analog signal, significantly reducing any potential pulse noise in the signal and improving overall accuracy. Most digital amplifier power supplies are plagued by noise caused by the transient capacitance inherent in switched MOSFET devices. But thanks to an ingenious circuit that monitors this characteristic, the DTA-9.4’s “Zero Switching Power Supply” only switches when this value is zero, resulting in a highly accurate power supply output. For use with compatible equipment, such as the Integra DTC-9.4 preamplifier/processor, the amplifier features gold plated balanced XLR inputs for improved signal transfer. Of course there are also extremely high quality gold-plated unbalanced terminals. Heavy-duty gold plated speaker terminals allow for the use of banana plugs, or spade lugs. Each channel of the DTA-9.4 features a completely independent circuit topology for superior reproduction fidelity. The amplifier benefits from an ultra low internal impedance design, thanks to the extensive use of copper bus bar and heavy gauge wiring, to provide superior response to transients and variations in the speaker load. The high efficiency of the PWM design eliminates the need for a noisy cooling fan. For integration with home theater systems, there is a 12-volt trigger input terminal for remote turn-on and “DimmerLink” to the DTC-9.4. The amplifier also includes a heavy-duty, audiophile-grade oxygen free copper detachable power cord. The Integra DTA-9.4 is currently available at a suggested retail price of $3,000. |
Gelscht
Gelöscht |
#2 erstellt: 30. Jun 2008, 11:12 | |
ist wohl 110 Volt, was? |
ND
#3 erstellt: 30. Jun 2008, 11:23 | |
Hab mir heute mal kurz die Mühe gemacht und die Bedienungsanleitung im "www" rausgesucht. Nach dieser benötigt der Onkyo Integra DAT-9.4: Power Supply AC 120 V, 60 Hz Power Consumption 5.3 A Power Consumption in standby mode 3.8 W ... sofern nicht irgendwelche Umbauten oder Änderungen am Amp vorgenommen wurden. Hier der Link: Manual Onkyo Integra DTA-9.4 Man sieht sich! ND [Beitrag von ND am 30. Jun 2008, 12:35 bearbeitet] |
Granuba
#4 erstellt: 30. Jun 2008, 12:26 | |
Hi, das interessiert mich auch! Harry |
Gardi
#5 erstellt: 30. Jun 2008, 16:25 | |
Hallo, hier noch das original Prospekt mit sämtlichen Detailangaben. INTEGRA DTA-9.4 - Brochure - 2-seitig - PDF 120 Volt / 60 Hz 5,3 A ... ist korrekt Das Gerät befindet sich im Originalzustand, es kann bei uns nur mit einem Wandler betrieben werden. Wie oben angedeutet steht der INTEGRA DTC-9.4 PreAmp ebenfalls zur Verfügung. z.B. als "Setangebot" Auch hier die Detailangaben: INTEGRA DTC-9.4 - Brochure - 2-seitig - PDF Fragen auch gerne per Telefon 01 77 / 45 68 300 (heute u. morgen ganztägig bis 0:00 Uhr) Rest jeweils ab 21:00 Uhr. Beste Grüße Dirk [Beitrag von Gardi am 30. Jun 2008, 18:41 bearbeitet] |
Granuba
#6 erstellt: 30. Jun 2008, 16:45 | |
Hi, mit Wandler liegt man dann leider locker 200 Euro drüber. Ein Umbau ist nicht möglich? Harry |
Gardi
#7 erstellt: 30. Jun 2008, 16:51 | |
Hallo Harry, ein Umbau ist sicher möglich. Bin kein Techniker, daher kann ich zu dieser Thematik nichts schreiben. Für einen evtl. Trafo tausch liegt das Service Manual vor. Grüße Dirk |
BBS13126
#8 erstellt: 30. Jun 2008, 18:54 | |
Hast du denn noch nen Spannungswandler, den du evtl dazugeben würdest? Gruß Christian |
Gardi
#9 erstellt: 30. Jun 2008, 18:55 | |
oh, das ging aber schnell Der optional im Set angebotene Integra DTC-9.4 - THX Ultra2 Certified Preamplifier/Processor/Tuner ist verkauft. D.h. die o.g. 7-Kanal Endstufe ist noch verfügbar. für 399,- € Weitere Original-USA-Schnäppchen aus meiner Sammlung: 1) Onkyo DV-M301 - Integra DPT-1 - 301-fach DVD/CD-Wechsler für 199,- € 2) Integra DTR-6.3 - 6.1 Channel A-BUS Ready Home Theater Receiver für 149,- € 3) Integra DPS-5.3 - DVD Multi Player für 99,- € Gruß, Dirk [Beitrag von Gardi am 30. Jun 2008, 18:58 bearbeitet] |
Gardi
#10 erstellt: 30. Jun 2008, 18:57 | |
Hallo Christian, leider nicht |
BBS13126
#11 erstellt: 30. Jun 2008, 19:44 | |
Ist nun eh nicht mehr schlimm wenn dann hätt ich Vor- und Endstufe im Set genommen. Du findest aber bestimmt noch einen Käufer für die Sachen. Viel Glück beim Verkauf |
blackmask_1981
#12 erstellt: 02. Jul 2008, 00:35 | |
Ist ein Wandler wirklich so teuer? um die 200 Eur.? |
BBS13126
#13 erstellt: 02. Jul 2008, 10:14 | |
Hatte auch mal nach geschaut...also er wird auf jeden Fall recht teuer für eine Endstufe, weil du halt da auf die Leistungsaufnahme gucken musst. Endstufen fressen ja recht viel Leistung, wodurch der Wandler teurer wird. Für einen DVD Player oder so mit ner max Leistungsaufnahme von 30 Watt oder so bekommste ganz billig welche. |
Granuba
#14 erstellt: 02. Jul 2008, 10:19 | |
Hi, jo, 1000 Watt sollte der Wandler schon haben, um nicht zu limitieren. Harry |
blackmask_1981
#15 erstellt: 02. Jul 2008, 18:15 | |
Aber für die Vorstufe mit 58 Wat Verbrauch müsste doch ein Wandler mit 100W ausreichen oder? z. B. der hier! http://www.hinkel-elektronik.de/shop/3342.html der oberste für 46,65 Eur. Oder ist der zu billig und die Vorstufe könnte abrauchen? |
Granuba
#16 erstellt: 02. Jul 2008, 18:22 | |
Hi, wenn 58 Watt der Maximalverbrauch, sollte der Wandler mit 100 Watt ausreichend dimensioniert sein. Harry |
blackmask_1981
#17 erstellt: 02. Jul 2008, 18:26 | |
Vielen Dank für die Antworten! |
Caligula
#18 erstellt: 03. Jul 2008, 12:21 | |
Evtl. lohnt es sich ja, so ein Ding aus Übersee zu importieren. Die scheinen da recht passable Preise zu haben. Hier z.B. zw. 110 und 240V umschaltbar und Anschlüsse für bis zu 3 Gerätschaften. http://www.dvdoverse...file=catalog6_0.html |
Duckshark
#19 erstellt: 04. Jul 2008, 00:31 | |
Hmmm schade, wenn das mit der Spannungswandlung nicht wäre, würde ich dieses Spitzenteil sofort nehmen. |
Gardi
#20 erstellt: 06. Jul 2008, 01:15 | |
Versand oder persönliche Abholung bis spätestens Freitag 11.07. danach Urlaub. |
Gelscht
Gelöscht |
#21 erstellt: 06. Jul 2008, 11:34 | |
der vorverstärker war schon weg was? |
Gardi
#22 erstellt: 06. Jul 2008, 11:40 | |
Ja, ist an blackmask_1981 verkauft. Gruß, Dirk |
Onkyo Integra A 8690 joh1373 am 03.10.2007 – Letzte Antwort am 15.10.2007 – 9 Beiträge |
Proton D1200 Power Amplifier AccuphaseP-3000 am 22.09.2007 – Letzte Antwort am 22.09.2007 – 3 Beiträge |
Onkyo integra stereo amplifier Model NO. A-8470 Hardy_k am 02.08.2007 – Letzte Antwort am 08.08.2007 – 2 Beiträge |
Onkyo Integra 8850A Silber mpower2901 am 23.04.2007 – Letzte Antwort am 02.05.2007 – 12 Beiträge |
Onkyo Integra 8015 xlupex am 08.09.2008 – Letzte Antwort am 15.10.2008 – 5 Beiträge |
Onkyo Integra A-8670 Digitalsurfer am 18.03.2009 – Letzte Antwort am 06.04.2009 – 3 Beiträge |
Onkyo Integra Verstärker Stötie am 09.10.2010 – Letzte Antwort am 30.10.2010 – 3 Beiträge |
Onkyo Integra A 8870 CptPuff am 30.07.2013 – Letzte Antwort am 01.10.2013 – 2 Beiträge |
Onkyo Integra 8850 Fuxster am 09.01.2014 – Letzte Antwort am 26.01.2014 – 3 Beiträge |
Integra DTR-6.3 - 6.1 Ch. A-BUS Ready Home Theater Receiver (Onkyo USA) Gardi am 30.06.2008 – Letzte Antwort am 06.07.2008 – 4 Beiträge |
Top 10 Threads in Verstärker / Receiver der letzten 7 Tage
- Stage Line Sta 320 PA/Subwooferendstufe
- Pioneer A 605 R
- PRO-JECT 7 AMP - Der audiophile Purist mit Phono Vorstufe im Traumzustand
- High End Mono Endstufen Blöcke - ICEpower - Jeff Rowland 201 Klone
- Sovereign Director Signature Series, night-shadow, Bestzustand
- ASR Emitter I HD High End Vollverstärker inkl. Phono/Power Suppl
- Lyngdorf TDAI 2170 mit 4K HDMI und USB Board
- Pioneer A-A9-J Verstärker grau
- Yamaha RX-A6A AV-Receiver in der Farbe schwarz
- Röhrenamp Music Angel XD SE - KT88
Top 10 Threads in Verstärker / Receiver der letzten 50 Tage
- Pioneer A 605 R
- Registrierte Mitglieder927.021 ( Heute: 2 )
- Neuestes Mitgliedhoffmannmoritz
- Gesamtzahl an Themen1.554.566
- Gesamtzahl an Beiträgen21.616.829
