HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Aufarbeitung eines Hitachi HA 8700 | |
Aufarbeitung eines Hitachi HA 8700+A -A |
Coolnotes87
#51 erstellt: 05. Nov 2022, 21:12 | |
Je ne suis pas trop habituer a réparer les amplis vintage , je préfère les amplis des années 1990 avec des nappes déconnectables mais ça reste un excellent ampli cette ampli HITACHI HA-8700 ? j'ai déjà réparer un HITACHI HMA-7500 MKII beaucoup plus facile a réparer :-)
CarlM.
#52 erstellt: 05. Nov 2022, 21:12 | |
2x 22 µF 25V ----> - 22 µF + + 22 µF - |
Coolnotes87
#53 erstellt: 05. Nov 2022, 21:15 | |
Yes I knew it 2 capacitors in series on the + but I wanted to have your opinion anyway thank you for answering me I will keep you informed of the rest at the beginning of this week :-) |
CarlM.
#54 erstellt: 05. Nov 2022, 21:21 | |
C'est mieux si tu attends. Il y a d'autres personnes sur le forum qui peuvent encore mieux t'aider. |
Coolnotes87
#55 erstellt: 05. Nov 2022, 21:23 | |
The PROTON D1200 amp also I already repaired with its leaky diode on the VUMETER control which made the amp go into protection it was not easy to repair it |
Coolnotes87
#56 erstellt: 05. Nov 2022, 21:26 | |
Ok thank you I will wait for other opinions from other people on the site, thank you. |
Poetry2me
#57 erstellt: 07. Nov 2022, 10:02 | |
I think the problem adjusting idle current is most likely in stage 3 (red). Did you replace the 'fuse resistors' in stage 3? R717L/R R720L/R R721L/R They look like normal resistors but are aging fast, especially when under constant heat stress. Value will deviate up or down, both can happen. Value will also vary by temperature and humidity (!). In some cases, they measured correctly when desoldered (still warm and humidity has been driven out) but continued deviating when back in operation. I always replace any fuse resistors I find. After more than 40 years in a very hot MOSFET amplifier, this is a must. These are fuse resistors I replaced in a Hitachi HA-6800 main amp section: - Johannes [Beitrag von Poetry2me am 07. Nov 2022, 10:04 bearbeitet] |
Coolnotes87
#58 erstellt: 07. Nov 2022, 10:39 | |
Hi yes I had to replace the R717L/R fuse resistors which had a very high value, I also changed 2 transmitter resistors which had a high value of 10 ohms instead of 2.7 ohms. the impossibility of setting the quiescent current occurs when I deactivate the main in switch but when I activate it I can set it to 300 mA, I check AND TEST the S701 L/R relay it works very well, the switch too |
Coolnotes87
#59 erstellt: 07. Nov 2022, 10:42 | |
The capacitors that CarlM. told me to check its in the right value |
Poetry2me
#60 erstellt: 28. Dez 2022, 13:16 | |
Beim Hitachi HA-8700 werden Sicherungswiderstände (Fuse Resistors) ausgerechnet in Stufe 3 (rot) verwendet, wo der Ruhestrom eingestellt wird. Art des Defekts: Fuse Resistors sind nicht immer komplett durchgebrannt, sondern verändern über die Jahre ihren Widerstandswert, teilweise nach oben und teilweise nach unten. Sie sehen aus wie normale Widerstände 1/4 Watt. Im Schaltplan erkennt man diese Widerstände daran, dass sie schwarz gezeichnet sind: R720L/R, R721L/R --- 100 Ohm 1/4 Watt --- Arbeitswiderstand 3. Stufe R717L/R, R748L/R --- 100 & 120 Ohm 1/4 Watt --- "Long-Tail" Widerstand 3. Stufe R737 --- 10 Ohm 1/4 Watt --- Trennung Signalmasse und Gehäusemasse - Johannes [Beitrag von Poetry2me am 28. Dez 2022, 16:17 bearbeitet] |
Coolnotes87
#61 erstellt: 28. Dez 2022, 14:05 | |
Hello I have already changed it, but I will check it anyway, when I have time, for the moment I have left it aside, otherwise I think the problem comes from the mosfet transistors 2sk134 and 2j49 its original parts are hard to find, any ideas for an equivalent? |
Poetry2me
#62 erstellt: 28. Dez 2022, 17:35 | |
I would recommend: Do not always trust the measurement value of certain old resistors. To my knowledge, some fuse resistor types used to be implemented with organic material which may have drawn humidity causing deviation of value. But when desoldering and heating up, the resistor may temporarily measure ok, only to draw humidity again. Electrolytic capacitor parameters also are manyfold, there is more than the capacitance and ESR that changes over the year. Leakage current and certain other parameters will cause it to fail or degrade in operation.
The main in switch could be the "direct coupling" switch? If so, then be aware that it just bypasses a coupling capacitor which means that any DC from previous circuits may come through to the main amp input which has no coupling capacitor to my knowledge (although it has bipolar input transistors which normally require coupling caps). - Johannes [Beitrag von Poetry2me am 28. Dez 2022, 17:36 bearbeitet] |
Coolnotes87
#63 erstellt: 28. Dez 2022, 18:04 | |
Ok thank you for the advice, it is noted I changed 4 or 5 fuse resistors on the MAIN P.W.B 1 board the others were at the right value, I will change them anyway soon, concerning the adjustment of the quiescent current as I see it I said before I could adjust it only when the main in direct switch was on, but when it was turned off, the quiescent current was over 2 volts and the transistors were hot! regardless of whather the switch is in direct coupling or condenser coupling mode, but lately it was working fine then after 15 minutes then it went into protection, I don't know if it's a bad ground or a component that's broken lack. |
Poetry2me
#64 erstellt: 29. Dez 2022, 11:37 | |
With such elusive but reproducible problems, you may have bad solder joints ("kalte Lötstellen") across the PCBs. - Johannes |
Poetry2me
#65 erstellt: 29. Dez 2022, 12:26 | |
Coolnotes87
#66 erstellt: 29. Dez 2022, 18:54 | |
Hi thank you for this detailed diagram I will do it soon and I will keep you posted |
AcidBlue
#67 erstellt: 21. Mai 2023, 01:56 | |
Hallo alle zusammen!, kann mir jemand helfen? Mein Hitachi HA-8700 hat 210 Volt an der Gehäuse drauf!!! Weißt jemand was geht hier ab! LG |
gst
#68 erstellt: 21. Mai 2023, 11:15 | |
Vorbereitung zur Diagnose: alle! Steckverbinder zum Gerät abziehen und dann beschreiben, zwischen welchen Messpunkten du 210Volt feststellst. Kontrolle: Netztstecker einmal anders herum reinstecken und nochmal messen. Änderung? |
AcidBlue
#69 erstellt: 03. Jun 2023, 02:03 | |
Hi ! Dankeschön!, hat sich erledigt! Stecker gedreht und alles wieder in Ordnung! Jetzt geht es ran an die Oxidierte Teile, Elektrolyte, Widerstände! LG |
Poetry2me
#70 erstellt: 03. Jun 2023, 16:40 | |
OK, dann war die Spannung am Gehäuse entstanden durch parasitäre Effekte am Netzteil. Bei Geräten, die keine Schutzerde angeschlossen haben, kann das durchaus mal passieren. Die Spannungen können durchaus hoch sein, aber die fließenden Ströme sind zu gering, als dass man Schaden nehmen kann. |
AcidBlue
#71 erstellt: 25. Jun 2023, 22:57 | |
Hallo Broesel02, ich hoffe dir geht es gut!, ich habe eine Frage, es geht um Austausch von Polyesterkondensatoren von 0.22uF 250V auf 1.5uF 160V, auf der Platine sind 6 Stück Polyester 0.22uF 250V Kondensatoren, welche hast Du von die 6 Stück gemeint? Das würde mich sehr interessieren ! Danke Mit freundlichen Grüßen |
Poetry2me
#72 erstellt: 05. Jul 2023, 21:41 | |
Du beziehst Dich wahrscheinlich auf Post #12. Da ist aber eigentlich alles klar beschrieben. Es geht um die Folienkondensatoren, welche parallel zu den Puffer-Elkos sitzen. |
CarlM.
#73 erstellt: 05. Jul 2023, 22:53 | |
Hallo Johannes, ich denke es geht um #16: http://www.hifi-foru...d=10403&postID=16#16 Dort sieht man in der Mitte zwei WIMA. Laut Service Manual S. 13 (von 30) befinden sich dort C708R und C708L mit je 33µF 16V (bipolare Elkos). Irgendwie passt das also nicht so ganz. Zumindest scheint doch eine präzise Erklärung notwendig zu sein. Carl p.s. Mir fällt gerade auf, dass die WIMA auf der Platine in #12 woanders sitzen .... [Beitrag von CarlM. am 05. Jul 2023, 22:57 bearbeitet] |
Poetry2me
#74 erstellt: 05. Jul 2023, 23:14 | |
Dann sollte AcidBlue doch einfach noch mal deutlicher beschreiben, was er wissen wollte, bzw. welche Bauteile laut Bestückungsplan er gemeint hat. |
Problem mit HA-8700 Verstärker sersch80 am 07.03.2007 – Letzte Antwort am 10.03.2007 – 4 Beiträge |
Hitachi HA 8700 Alps Poti mit 150Kohm nicht erhältlich highfreek am 13.03.2015 – Letzte Antwort am 14.03.2015 – 3 Beiträge |
Hitachi HA-4800 ennas2k am 07.06.2007 – Letzte Antwort am 08.06.2007 – 2 Beiträge |
Hitachi HA 5300 kcjhoppe am 27.10.2015 – Letzte Antwort am 30.10.2015 – 3 Beiträge |
Hitachi HA 270 geht aus :( audiophilieistesotherik am 17.12.2008 – Letzte Antwort am 18.12.2008 – 5 Beiträge |
Hitachi HA-7700 reagiert nicht xwakix am 24.05.2009 – Letzte Antwort am 25.05.2009 – 2 Beiträge |
Schaltplan f. Hitachi HA-270 zabatak am 22.04.2013 – Letzte Antwort am 22.04.2013 – 2 Beiträge |
Hitachi HA-5700 macht Probleme Fiverocker am 06.10.2014 – Letzte Antwort am 09.10.2014 – 7 Beiträge |
Aufarbeitung eines Vollverstärkers von Franz Grigelat Elektronik Rainer4x4 am 06.01.2012 – Letzte Antwort am 12.01.2012 – 7 Beiträge |
Hitachi HA-3500 Endstufe geht dauernd kaputt MichaelF. am 05.10.2008 – Letzte Antwort am 13.01.2009 – 17 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder926.920 ( Heute: 1 )
- Neuestes Mitgliedремонт_бытÐ...
- Gesamtzahl an Themen1.554.306
- Gesamtzahl an Beiträgen21.610.048
