HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Technics sh 8066 defekt | |
Technics sh 8066 defekt+A -A |
Antonello4923
#1 erstellt: 10. Apr 2020, 15:53 | |
Hello everyone and the first time I post sorry my english my name is antonello and i live in sardinia I have a problem on my technics equalizer sh 8066 after a period that I didn't turn it on last week turned it on there is a problem if I press the keys nothing happens does not switch functions I replaced the power supply capacitors and also those that act as memory I don't know what else to do Do you have any advice on this to help me repair? Antonello |
CarlM.
#2 erstellt: 10. Apr 2020, 17:40 | |
Hi Antonello, welcome to our community! When I was a student I visited Porto Torres. That's long ago. But I remember well. To your problem. A service manual can be downloaded via ... https://www.vintages...6-Service-Manual.pdf On page 18 (numbering by pdf) you'll find the power supply. First ideas ... 1. If nothing happens, the thermal fuse of the transformer should be checked. Between the contacts of the mains plug the resistance must be low. 2. The power supply seems to switch a lot of voltages on the secondary side of the power transformer. You should check it. (resistance between contacts when the mains plug is not connected to 230V AC). 3. Next step would be to check the voltages which you can find in the service manual. Maybe a rectifier or one of the regulators IC 1 to 3 is defective. Quando ero uno studente ho visitato Porto Torres. Questo è tanto tempo fa. Ma ricordo bene. Al tuo problema. Un manuale di servizio può essere scaricato tramite ... https://www.vintages...6-Service-Manual.pdf A pagina 18 (numerazione in pdf) troverai l'alimentatore. Prime idee ... 1. Se non succede nulla, controllare il fusibile termico del trasformatore. Tra i contatti della spina di alimentazione la resistenza deve essere bassa. 2. L'alimentazione sembra commutare molte tensioni sul lato secondario del trasformatore di potenza. Dovresti controllarlo. (resistenza tra i contatti quando la spina di alimentazione non è collegata a 230 V CA). 3. Il prossimo passo sarebbe quello di controllare le tensioni che puoi trovare nel manuale di servizio. Forse un raddrizzatore o uno dei regolatori IC da 1 a 3 è difettoso. |
Antonello4923
#3 erstellt: 10. Apr 2020, 18:18 | |
__________________________ hi Carl I'm glad you visited Porto Torres I live in the province of Sassari, about twenty minutes from Porto Torres then I tell you my tests with the multimeter I checked all the various resistors and transistors and at the test they seem ok the equalizer turns on the signal enters but the buttons do not work there is no switching between the buttons if I disconnect some j9 j16 connectors from inside then some buttons work |
CarlM.
#4 erstellt: 10. Apr 2020, 18:46 | |
Please confirm: If you are disconnecting the power switch some buttons are working? Most important is to check the voltages of the power supply. You have to verify the marked voltages: [Beitrag von CarlM. am 10. Apr 2020, 18:47 bearbeitet] |
Antonello4923
#5 erstellt: 11. Apr 2020, 10:31 | |
Hi Carl, then I took the measurements you suggested they look ok IC1=-22 -15 vcc IC2= 14,9 21,3 vcc IC3 -5,6 -11,8 vcc Q2= base -6,7 Collettore -10,7 Emettitore 6,06 Q4= Base 6,51 Collettore 10,42 Emettitore 5,88
CarlM.
#6 erstellt: 11. Apr 2020, 10:54 | |
Hi Antonello, I read the manual again. On page 8 (= page 5 of PDF) I found the chapter "Convenient functions". Did you check the function "lock button"? C. |
Antonello4923
#7 erstellt: 11. Apr 2020, 12:38 | |
The lock button is used to prevent someone from touching the panel and varies the frequencies and in any case he too does not work
CarlM.
#8 erstellt: 11. Apr 2020, 15:53 | |
Normally now the CPU should be checked. But it is not possible without an oscilloscope. Therefore you can check the wires and connectors and at the end you can only continue checking the voltages: I would start with the Zener-diode D17 and the transitors of the buffer area like Q709 an following ... |
Antonello4923
#9 erstellt: 11. Apr 2020, 16:19 | |
D17 =-27,7/-30,3 Q 709= B -30,6/ C -31,1/ E- 30,5 vcc shortly a video what happens if I disconnect some points _______________________________
Antonello4923
#10 erstellt: 11. Apr 2020, 18:04 | |
https://www.youtube.com/watch?v=4iu37XbCDQU
technics sh-8066 brummt bei Betriebstemperatur ncomr am 28.04.2018 – Letzte Antwort am 03.05.2018 – 9 Beiträge |
Problem Technics SH-GE90 und SH-GE70 Zwula am 14.09.2019 – Letzte Antwort am 15.09.2019 – 10 Beiträge |
technics mini turm defekt techidoof am 29.10.2014 – Letzte Antwort am 13.01.2021 – 26 Beiträge |
Kurzhubtasten an TECHNICS SH 9038 HiFi-Rack am 16.02.2011 – Letzte Antwort am 19.02.2011 – 6 Beiträge |
technics equalizer sh-8045 lautstärkeunterschied alaska36 am 25.05.2022 – Letzte Antwort am 06.10.2022 – 6 Beiträge |
Neuer Trafo für Technics SH-9010 bananjoe am 18.01.2015 – Letzte Antwort am 19.01.2015 – 5 Beiträge |
JRC4558 Ersatz im Technics SH-9010 EQ Keksstein am 28.02.2016 – Letzte Antwort am 12.03.2016 – 23 Beiträge |
Technics SU V4A defekt Muh! am 09.07.2007 – Letzte Antwort am 10.07.2007 – 13 Beiträge |
Technics SU-Z22 - Defekt zickzackbird am 12.12.2009 – Letzte Antwort am 16.12.2009 – 4 Beiträge |
Technics 615 Input defekt? LuxMorgenstern am 06.02.2017 – Letzte Antwort am 08.02.2017 – 5 Beiträge |
2020
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder927.991 ( Heute: 14 )
- Neuestes MitgliedGösn
- Gesamtzahl an Themen1.557.095
- Gesamtzahl an Beiträgen21.672.290
