HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Bayreuth Concerto htd 9166 | |
Bayreuth Concerto htd 9166+A -A |
PPindian
#1 erstellt: 05. Okt 2021, 12:24 | |
Hello everyone, I have a deck of Bayreuth Concerto HTD 9166 (also sold as Frey 9304, MACLAIR CK-7700 or Eagle C 7800). After replacing the rubber band, the engine stopped spinning. I ruled out a mechanical problem. I need a schematic, the fault is probably in the motor controller. Does anyone have it? thank you very much |
shabbel
#2 erstellt: 06. Okt 2021, 07:47 | |
Some of the Bayreuth stuff is identical with HHScott. You should look for an identical tapedeck made by HHScott. |
Ingor
#3 erstellt: 07. Okt 2021, 15:34 | |
I believe that you ripped off a cable or make a short while you changed the belts. The motor needs 12 V so it should be easy to follow the way to the power supply. |
PPindian
#4 erstellt: 15. Okt 2021, 11:28 | |
Hi, thank you for direction. Mistake found, disintegrated isolation at spring switch inside cassete mechanism. It is repaired, deck beatiful played :-) https://www.youtube.com/watch?v=SvmklHYdM4w |
Bayreuth Concerto htd 9166 Tapedeck Reparatur awr13 am 04.03.2013 – Letzte Antwort am 20.08.2013 – 7 Beiträge |
Tapedeck Bayreuth Concerto-Music Hall-Frey Riemen? d-robser am 29.04.2012 – Letzte Antwort am 20.11.2013 – 8 Beiträge |
Schaltplan für Bayreuth Concerto Hifi HSV 9165 DaPickniker am 28.11.2005 – Letzte Antwort am 09.09.2011 – 4 Beiträge |
KEF Concerto- Weichen defekt murbola am 28.02.2012 – Letzte Antwort am 29.02.2012 – 16 Beiträge |
Telefunken Concerto hifi 404 Grundrauschen Linus112 am 30.12.2011 – Letzte Antwort am 12.04.2021 – 21 Beiträge |
Bilder-Story: Restauration des Telefunken Concerto 2500 CyberSeb am 22.05.2010 – Letzte Antwort am 12.05.2016 – 31 Beiträge |
Verstärker Bayreut Concerto HSV 9165 DEFEKT awr13 am 03.03.2013 – Letzte Antwort am 10.03.2013 – 3 Beiträge |
Telefunken Concerto hifi 404 ohne UKW Christian_Aßmann am 21.05.2022 – Letzte Antwort am 02.06.2022 – 11 Beiträge |
Telefunken Salzburg mit Opus 2550/2554 rauscht telefunken-high-end am 16.11.2013 – Letzte Antwort am 07.12.2013 – 26 Beiträge |
Tape Deck Riemen nach länge Bestellen highfreek am 27.06.2024 – Letzte Antwort am 28.06.2024 – 7 Beiträge |
2021
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder927.030 ( Heute: 5 )
- Neuestes Mitgliedvoice1991
- Gesamtzahl an Themen1.554.592
- Gesamtzahl an Beiträgen21.617.456
