HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Accuphase P600 problema digital display | |
Accuphase P600 problema digital display+A -A |
yena60
23:10
erstellt: 13. Nov 2021, |
I brought ACC. P600 from my trusted technician, with a problem with the digital display. The display lights up but shows 666 or 000, reading updates arrive but do not come Two logic boards are used for this reading, the first has on board two microcontrollers (with proprietary firmware), A / D conversion and power supplies. The second mounts CMOS logic that should drive the displays. The only thing it has detected on this is the power supply voltage of about 4.4V against the 5V required. It could be one of these bad chips. It is not possible to take a test due to difficult accessibility of the board when mounted and the absence of any type of scheme. All integrated on logic board replaced, same result, display all 666 Replaced another 4 on another display board, the same. If someone has suggestions and can help me or has the manual available (even for a fee) I would be grateful. Thanks ![]() |
CarlM.
18:11
erstellt: 14. Nov 2021, |
I'm not very familiar with Accuphase. Therefore I waited to answer you. I searched the internet and found the model A60. The display looks very similar. A service manual is available for download: ![]() Maybe it helps to understand and analyze the problem. Good luck! Carl |
yena60
20:03
Thanks for the reply, I pass this manual to my technician hoping it will be useful |
monkeybonn
12:46
erstellt: 19. Mrz 2024, |
Hello, did you got it repaired? |
Ersatz Trafo Accuphase P600 yamahamx1000 am 30.09.2019 – Letzte Antwort am 20.07.2023 – 136 Beiträge |
Accuphase 500L auf 240 Volt umstellen yamahamx1000 am 18.08.2024 – Letzte Antwort am 19.08.2024 – 7 Beiträge |
Accuphase P300 marc.aurel am 27.02.2011 – Letzte Antwort am 27.02.2011 – 3 Beiträge |
Accuphase P300 stefan2408 am 18.03.2012 – Letzte Antwort am 27.04.2012 – 8 Beiträge |
Accuphase P 300 Defekt 2Boxen-2Ohren am 18.12.2008 – Letzte Antwort am 18.12.2008 – 2 Beiträge |
Accuphase e 204 kaputt.Hilfe! lavapost am 20.12.2008 – Letzte Antwort am 28.12.2008 – 3 Beiträge |
accuphase 202 defekt? Niranjana am 25.01.2009 – Letzte Antwort am 25.01.2009 – 4 Beiträge |
Accuphase E-302 boomer_xl am 28.06.2009 – Letzte Antwort am 29.06.2009 – 2 Beiträge |
Accuphase E203 defekt - Hannover BertiIrmo am 26.01.2010 – Letzte Antwort am 27.01.2010 – 2 Beiträge |
Accuphase DP-70 hpdeussen am 09.03.2010 – Letzte Antwort am 19.03.2010 – 5 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder929.016 ( Heute: 14 )
- Neuestes Mitgliedevian1893
- Gesamtzahl an Themen1.559.507
- Gesamtzahl an Beiträgen21.728.125
