HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Maranz ein kanal defekt | |
Maranz ein kanal defekt+A -A |
audiomann3000
22:00
erstellt: 24. Nov 2009, |
hallo, ich habe ein problem mit meinem maranz modell 1090 (aus den 70gern)es funktionirt nur noch ein kanal der andere brummt was könnte das sein und was würde eine reparatur vermutlich kosten? |
tri-comp
22:47
Hi, In one channel the output-transistors are most likely shorted. Don't turn-on the amplifier until it is repaired; you may do more damage to your amplifier and your speakers. The cause of this problem can be many. Here are a few: 1) In old amplifiers are old electrolytic capacitors. They dry out and loose their capacity making the amplifier-circuit un-stable. Self-oscillation may occur and the output-transistors are damaged. 2) There is a BIAS-circuit in most amplifiers. Bias is adjusted to a value that will make the amplifier run safely and produce the least distortion. Unfortunately in this amplifier, this circuit is constructed in a bad way. When the potentiometer, used for adjusting the Bias, becomes corroded/dirty and looses contact, the Bias is increases beyond this safety-setting and the amplifier runs hot and may easily be destroyed. 3) You have a defective speaker. A shorted/burned tweeter-unit may be seen from the amplifier as a short when you turn-up the volume. The current in the output-transistors may exceed the safety-value and they are destroyed. Of course it doesn't have to be inside the speaker you may have a short. The speaker-cable may also be shorted in either end. These are the 3 most common causes of defective amplifiers in my opinion. Not that it will make your amplifier run again, but it may explain what went wrong. A repair is for the professionel and what he will charge you is upon him and what is really defective inside your amplifier. After all you can't call the garage and expect the mechanic to say what a repairs will cost when you only tell him the car wont start ![]() mfg, /tri-comp PS, when you find the pro that will repair your amp., I may be able to help with schematics/manuals. [Beitrag von tri-comp am 24. Nov 2009, 22:51 bearbeitet] |
Jeremy
22:51
Ruf' mal bei Forumsmitglied 'ruesselschorf' (Helmut Thomas)an - der repariert/überholt solche Klassiker - gerade alte Marantz. Tel.: 09776/7632 BG Bernhard |
Maranz CD11 winda am 18.03.2017 – Letzte Antwort am 22.03.2017 – 12 Beiträge |
Maranz PM-64 MK 2 Duc_67 am 15.09.2008 – Letzte Antwort am 16.09.2008 – 9 Beiträge |
Maranz 2285B Woodcase digitalo am 25.06.2008 – Letzte Antwort am 29.06.2008 – 4 Beiträge |
Fisher MCE4040 Kanal defekt biniman am 11.11.2008 – Letzte Antwort am 14.11.2008 – 2 Beiträge |
Kurzschluss Lautsprecherausgang - Kanal defekt Simon_M am 04.03.2009 – Letzte Antwort am 04.03.2009 – 4 Beiträge |
Denon PMA500v Kanal Defekt Celebrations am 26.03.2009 – Letzte Antwort am 03.05.2009 – 98 Beiträge |
Grundig V2000 ein Kanal defekt Adzukibohne am 28.11.2006 – Letzte Antwort am 04.12.2006 – 17 Beiträge |
Nordmende RE1200 ein Kanal defekt dllwurst am 21.10.2008 – Letzte Antwort am 23.10.2008 – 6 Beiträge |
Marantz 2265B ein Kanal defekt herr_bieber am 08.09.2009 – Letzte Antwort am 09.09.2009 – 3 Beiträge |
Nakamichi BX125E - ein Kanal defekt zastafari am 12.07.2012 – Letzte Antwort am 15.07.2012 – 3 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder928.934 ( Heute: 9 )
- Neuestes Mitgliednico8848
- Gesamtzahl an Themen1.559.337
- Gesamtzahl an Beiträgen21.723.920
