B&O VX 5000 wie öffnen
Kampfwurst_Hugo
#1 erstellt: 13. Mrz 2010, 15:11
Hallo
Ich habe einen Alten B&O VX 5000 VHS Recorder geschenkt bekommen. Er ist vieleicht für 10h im Betrieb gewesen. Leider hat das Spuren hinterlassen.
Nun meine Frage:
Wie kann ich das Gehäuse öffnen. Ich finde irgendwie die Schrauben um den Decke abzunehmen nicht.
MFG Christoph
tri-comp
#2 erstellt: 13. Mrz 2010, 18:55
VX-5000 ??
THAT's an old Videorecorder
As far as I remember you need to remove the 2 side plastic-panels.
They slide out backwards when you lift the rear-end out a little (...with a flat screwdriver) and apply some force between the front-panel and the front of the side-panel (...again with a flat screwdriver)
When the panels are removed you clearly see the screws that hold the cover.
This oldie needs:
1) New rubber belts
2) A new pinch-roller
3) Mostly they need to be renovated renewing the complete white plastic gear-module. It's actually quite easy to replace when you take care to insert the new one EXACTLY like the old hooking-up levers correctly. Just 3 screws (...as I remember) need to go out to replace the entire gear-unit.
4) The Capstan Motor may be worn-out. Before renovating ANYTHING just grap the capstan shaft from the top-side and see if it has any slack. Push it from side to side and feel if it fits firmly in the bearing or it goes 'clack' - 'clack' from side to side. If it 'clack's throw away the recorder. A new motor is far too expensive.
I used to have a friend who is now dead. He made new teflon-bearings for me to replace the original phosphorous-bronze bearings and teflon will NEVER wear out.
good luck,
mfg,
/tri-comp
Lautsprecher B&O Beovox 2700: wie öffnen?
Rossi68 am 28.07.2007  –  Letzte Antwort am 30.07.2007  –  6 Beiträge
Beomaster 5000
Schnino am 01.02.2016  –  Letzte Antwort am 01.08.2016  –  4 Beiträge
B&O - Bedienungsanleitung
bangbuex007 am 14.09.2008  –  Letzte Antwort am 19.09.2008  –  2 Beiträge
B & O Beomaster 1400 Skalenseil
Hans-Hermann am 02.12.2019  –  Letzte Antwort am 08.12.2019  –  5 Beiträge
B & O Overtuere Radiio defekt
norwegen11 am 28.09.2013  –  Letzte Antwort am 30.09.2013  –  4 Beiträge
su-vx 720 technics
papaja am 05.01.2008  –  Letzte Antwort am 05.01.2008  –  3 Beiträge
Reparatur B&O Beocenter 3500
am 20.03.2008  –  Letzte Antwort am 23.03.2008  –  8 Beiträge
Reparaturanleitung B&O Beogram 1000
grattler01 am 17.04.2009  –  Letzte Antwort am 18.04.2009  –  2 Beiträge
B&O Beocenter 7700 Reparaturversuch
Joad am 19.08.2012  –  Letzte Antwort am 13.09.2012  –  12 Beiträge
Ältere B&O Anlage nachrüsten
gigaganti am 21.09.2014  –  Letzte Antwort am 21.09.2014  –  2 Beiträge
  • Registrierte Mitglieder928.687 ( Heute: 1 )
  • Neuestes Mitgliededlalbertina
  • Gesamtzahl an Themen1.558.773
  • Gesamtzahl an Beiträgen21.710.284
