HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Fast kein Ton mehr vorne rechts | |
Fast kein Ton mehr vorne rechts+A -A |
Xotix
#1 erstellt: 07. Sep 2010, 17:24 | |
Hallo, ich habe nen Denon AVC-3800. Leider ist einer der Ausgang kaputt. Es liegt am Verstärker. Wenn ich etwas lauter mache und mit dem Ohr an den Lautsprecher gehe dann hörtm an den TOn, alelrdings sehr stark verzerrt. Man erkennt ihn eher als das man ihn hört. Was könnte es sein? Und was würde eine Reparatur in etwa kosten?
tri-comp
#2 erstellt: 08. Sep 2010, 05:58 | |
Hi, Impossible to say. Surround-Receivera are complicated and not easy to diagnose from a distance. You say you hear some distorted sound in the speaker. That would indicate the fault is NOT in the output amplifier. When it is defective it will put DC-voltage on the speaker-terminal and the protection-circuit disconnects the speaker. As this is not the case I would guess the amplifier is OK. The fault may be in the electronic input-switching or ANYWHERE in the signal-path. The receiver weights around 25Kg so I would think it's in a league where it would be reasonable to have it serviced I can help with schematics but you should find someone familiar with electronic circuits to do the actual repair. An oscilloscope will be required if there is a fault in the signal-switching. mfg, /tri-comp [Beitrag von tri-comp am 08. Sep 2010, 05:58 bearbeitet] |
Xotix
#3 erstellt: 08. Sep 2010, 06:28 | |
hmm, electronic input-switching? I just know that my speaker is okay since i switched the front left with the front right. the cable itself is also okay since it worked perfectly when i changed. (the one which is not on the broken output) Finding someone who is familiar with electronics shouldnt be my problem but if he can repair a amplifier. the distorted sound is like, hmm, if i turn up the volume and you go really! close to the speaker, you can recognize! the sound/melodie/bass from the song which is playing. or the tv. its very very disturbed. so you dont think it is the output itself? |
tri-comp
#4 erstellt: 08. Sep 2010, 11:07 | |
Almost always when the output-amplifier is defective and the sound is distorted because of this, the amplifier will put a DC-voltage on the speaker output terminals. Because this is deadly to the speakers, at least the bass-speaker, all amplifiers have a protection-circuit that constantly monitors the output for DC-voltage. If any is found, the Speaker-relay immediately disconnects the speakers and of course they are silent. This doesn't happen in your case, so I would expect the amplifier to be OK. The Speaker-relay itself may be defective; i.e. the contacts doesn't make fully contact. This is also a common fault, at least in older amplifiers. Your's it too new for this problem to appear already, I believe. The input signal-switching is done with integrated circuits in this Denon. I have seen these switching IC's become defective in many amplifiers, so that's quite common. When you find someone who will take a look at the receiver I can help with schematic diagrams. mfg, /tri-comp |
Xotix
#5 erstellt: 11. Sep 2010, 08:44 | |
My Speakers are okay. I really know that. Thats 4 sure. Hmm, i looks like now i just got the center and the left front speaker working. I will look if i find someone. [Beitrag von Xotix am 11. Sep 2010, 08:57 bearbeitet] |
Marantz SR8002 vorne rechts kein Ton bennehans am 03.03.2016 – Letzte Antwort am 04.03.2016 – 12 Beiträge |
Denon AVR-1705 links vorne kein Ton Ring_of_Death am 17.01.2010 – Letzte Antwort am 23.01.2010 – 4 Beiträge |
NAD 356 kein Ton mehr spawndwalk am 29.11.2017 – Letzte Antwort am 29.11.2017 – 4 Beiträge |
Onkyo TX-NR 5007 kein Ton secondhandhörer am 01.11.2011 – Letzte Antwort am 28.04.2019 – 195 Beiträge |
Denon AVR-1905 kein Ton thomasp78 am 05.07.2015 – Letzte Antwort am 05.07.2015 – 2 Beiträge |
t.amp defekt, kein ton Baldy-017 am 22.04.2019 – Letzte Antwort am 23.04.2019 – 11 Beiträge |
Sony STR DG 510 - rechte Kanäle ohne Ton ThomasausWB am 27.04.2020 – Letzte Antwort am 27.04.2020 – 2 Beiträge |
Yamaha RX-V361 geht nicht mehr vorne rechts 3ernd am 03.03.2012 – Letzte Antwort am 04.03.2012 – 3 Beiträge |
Denon 1507 kein Ton! ann-dee am 22.05.2011 – Letzte Antwort am 22.05.2011 – 3 Beiträge |
Onkyo TX-NR818 Probleme (kein Ton) BerndHennig am 26.07.2021 – Letzte Antwort am 30.07.2021 – 2 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder928.055 ( Heute: 1 )
- Neuestes MitgliedGaitDuets
- Gesamtzahl an Themen1.557.312
- Gesamtzahl an Beiträgen21.676.696
