HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Sony GX 70 ES | |
Sony GX 70 ES+A -A |
watzata
#1 erstellt: 19. Okt 2007, 12:03 | |||||
Hallo Mein Name ist Klaus Ich habe ein Problem mit einem Receiver von Sony,GX70ES. Der geht von allein nach ca 10min immer aus. Nach einem Neustart läuft er dann wieder einige Zeit. Kennt sich hier jemand damit aus? Oder hat noch einer eine Quelle für eine Bedienungsanleitung? Danke für eure Mühe Klaus |
tri-comp
#2 erstellt: 20. Okt 2007, 10:19 | |||||
Hi Klaus, First of all: Your Sony is a STR-GX70ES. It's impossible to say exactly why it cuts-out after a few minutes. Most likely because the protection-circuit is doing it's job and something is not working as it should. It can be the output amplifier, it can be the power-supply or even the protection-circuit itself. In your output amplifier there is a chip STK-3102/3. I would check solderings around it and do some measuring as well. For that you will need the service-manual. ...and some experience with an oscilloscope & a digital multimeter. I can help with the manual. PM me with your e-mail address for a free pdf-copy. Kind regards, /tri-comp |
STR-GX70ES_user
#3 erstellt: 15. Okt 2008, 14:46 | |||||
Hello, looking on the internet to find a possible solution for my problem with my Sony STR-GX70ES, ran in to this topic. The problem discribed looks very simular to my problem. My STR-GX70ES started with the same problems listed above, but now the protection circuit falls in as soon as it is switched on (red "P" blinking on display). I was also thinking about a faulty amplifier chip, in my case it's a STK3082 III, but that's a simular chip as the STK3102/3 i found out. Can anyone confirm that a faulty amplifier chip can cause the protection circuit to fall in. @tri-comp, i am also interested to receive a copy of the service manual. Regards, Geert Keizer [Beitrag von STR-GX70ES_user am 15. Okt 2008, 14:51 bearbeitet] |
audiophilanthrop
#4 erstellt: 17. Okt 2008, 11:11 | |||||
It absolutely can. If one of the output transistors shorts out, for example, you'd get DC on the output and the protection circuitry activates. For basic diagnosis, I would get a datasheet for the STK plus a multimeter and test for conductivity where it shouldn't be. A short between collector and emitter of a transistor would be a dead giveaway. |
STR-GX70ES_user
#5 erstellt: 20. Okt 2008, 11:21 | |||||
I already did some basic measurement on the chip. I have measured potential on te ouputchannels to check if an undesired DC potential exsits, this was not the case. Now i realize this could be the case because of an activated protection circuit, but the te supply voltages are still present. I will try to measure conductivity as discribed above, but do i have to de-solder the chip to do this measurement. |
audiophilanthrop
#6 erstellt: 21. Okt 2008, 12:16 | |||||
So far, so good.
Wait.. you measured behind the loudspeaker relay? In case of working protection circuitry, there'll never be any significant DC levels at this point.
No, normally desoldering should not be required for such a basic check. |
STR-GX70ES_user
#7 erstellt: 22. Okt 2008, 15:46 | |||||
I measured directly at the pins of the STK3082. |
audiophilanthrop
#8 erstellt: 22. Okt 2008, 19:57 | |||||
So the problem apparently lies elsewhere. I would guess that the STK is only a pre-driver of sorts (common for higher-end mass-market amps at the time), so there could still be something wrong after it. There should be some test points for idle current and DC offset adjustment, I'd try measuring there. If that still doesn't turn up any DC, the protection circuitry needs a closer look. Service docs would be required at this point. |
STR-GX70ES_user
#9 erstellt: 03. Feb 2010, 15:35 | |||||
Problem is still not solved Can someone send me a servicemanual of the STR-GX70 ES? |
jomoss
#10 erstellt: 14. Sep 2010, 20:29 | |||||
Hi, my name is Jo, I recently bought a second hand STR-GX70 ES. It seemed to work ok in the shop, but when i got it home and plugged my speakers in to it there is this feedback noise like the earthing wires are loose or something. I'm not that great technically and would really appreciate some advice. I have tried different speakers with it, in the A and B speaker sockets, but the buzzing noise is always there. I noticed that buzzing noise changed frequency when i switched it to CD, Radio, Phono etc... I know this is not normal obviosly i thought it might be a common problem or an easy one to fix...? Help please, Thanks |
Ro808
#11 erstellt: 16. Feb 2012, 19:36 | |||||
Hallo, Ich habe auch ein Sony GX 70 ES. Das Gerat spielt nur am Rechter Kanal und Links sehr leise. I switch to English , because most of the posts here are in English. The serivice manual is in my posession and I could send anyone who is interested a copy. If someone is familiar with this issue (1 Channel delivers a normal and 1 (left) a very low output SIGNAL), please let me know. Regards, Roland |
Akai GX 266D badischakai am 25.12.2013 – Letzte Antwort am 26.12.2013 – 2 Beiträge |
Reparaturr Akai GX 75 Rabuek2 am 08.02.2023 – Letzte Antwort am 02.04.2023 – 12 Beiträge |
technics SA GX 200 -defekt- Franky76 am 02.01.2014 – Letzte Antwort am 08.01.2014 – 3 Beiträge |
Technics Receiver SA GX 550 kratzt. *SurroundFan* am 10.08.2011 – Letzte Antwort am 15.08.2011 – 4 Beiträge |
Sony STR-GX-315 Transistor für Lautsprechertrennrelais wird im Standby heiß! Dr.Cable am 20.12.2012 – Letzte Antwort am 08.01.2013 – 7 Beiträge |
hilfe mein stereo Resiver SA GX 130 D ist defekt Kawakaki am 01.01.2014 – Letzte Antwort am 01.01.2014 – 2 Beiträge |
hilfe mein stereo Resiver SA GX 130 D ist defekt Kawakaki am 01.01.2014 – Letzte Antwort am 14.02.2014 – 5 Beiträge |
Mein geliebtes AKAI GX 6 will nicht mehr... Diplomat_V8 am 26.06.2005 – Letzte Antwort am 23.08.2010 – 9 Beiträge |
Pioneer A-70 Kaputt ? Daniel_94 am 15.01.2010 – Letzte Antwort am 30.01.2010 – 13 Beiträge |
Begrenzerschaltung Blaupunkt MX-70 Audiovirus am 01.06.2014 – Letzte Antwort am 08.06.2014 – 7 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder927.021 ( Heute: 2 )
- Neuestes Mitgliedhoffmannmoritz
- Gesamtzahl an Themen1.554.565
- Gesamtzahl an Beiträgen21.616.769
