HIFI-FORUM » Stereo » Elektronik » Akku für SONY TCD-D3 DAT WALKMAN | |
Akku für SONY TCD-D3 DAT WALKMAN+A -A |
earsplitter
#1 erstellt: 17. Aug 2007, 11:01 | |
Hallo, Ich brauche Hilfe. Könnte Jemand mir erteilen wo kann ich finden Akkus für meine SONY TCD-D3 DAT WALKMAN. Habe schon alles probierte aber kein Lösung so Weit. Danke für Ihre Antwort. Mfg. Earsplitter |
tri-comp
#2 erstellt: 18. Aug 2007, 13:28 | |
Hi, THIS is a problem not easily solved! First, the battery (6V, 1.5Amp) Typeno. = BP-D3 Sony Partno. = 1-528-334-11 (AEP, EA) Sony Partn0. = 1-528-333-11 (US, CND, UK, E, AUS) You are right, the batterypack is not supplied any more. HOWEVER, most custom batterypacks are just custom on the OUT-side. IN-side they consist of standard AA-, C- or even D-cells. In your case they are NiCD cells I believe, because of the age. In most cases they could just be replaced with modern NiMH cells of the same physical size. The gain will be higher yield of performance. The existing pack runs around 2 hours. If replaced with NiMH expect closer to 3- 3.5 hours. So, you should OPEN the old pack in some way. Carefully, because it doesn't live shielded in some battery compartment but is part of the recorders exterior and you don't want scars on your vintage jewel If it's clearly seen the pack is made by 2 halves, just glued together, I usually put it in a wise and SQUEEZE it. The plastic will snap open along the glued edges in some weaker places and the rest can be done carefully by hand with a knife and a broad screwdriver. If it's not made out by 2 halves, but looks moulded into one piece, it's going to be harder. Cutting/sawing in the only way and that's going to leave scars. Still, you must open it. Inside you'll find the cells, connected in series. 5 of them, most likely (5 x 1,2V = 6V). Measure length and diameter and try to find what's available within measurements. If you have to choose smaller cells, don't worry. They have at least the same capacity as the originals. The new cells should be bought with metal strips already at each end for easy soldering. Before final re-assembly/glueing, try to just keep things in place by wrapping a couple of rubber-bands around the pack. Does it charge? does it run for at least a couple of hours on a charge? If so, it's time to do the final re-assembly. ....and probably to invite the family for a small party, celebrating Sorry, just don't know how to write all of this in German. Kind regards, /tri-comp P.S. I have the Service-Manual in pdf-format. It's yours for free if you send me a PM with your e-mail address. |
Sony TCD-D3 DAT wolfwurm am 30.12.2006 – Letzte Antwort am 07.01.2007 – 2 Beiträge |
Sony TCD D3 Portable DAT William_C.R. am 10.01.2007 – Letzte Antwort am 26.01.2007 – 5 Beiträge |
DAT Walkman SONY TCD-D7 Braucht Reparatur cortin am 03.07.2006 – Letzte Antwort am 04.07.2006 – 3 Beiträge |
HILFE! ---> SONY TCD-D7 DAT-RECORDER WALKMAN klangtheater am 04.08.2008 – Letzte Antwort am 05.08.2008 – 2 Beiträge |
Sony TCD-D7 - Error 01 gardan am 07.02.2007 – Letzte Antwort am 07.02.2007 – 2 Beiträge |
Sony TCD D100 DAT Walkman Aussetzer am Ende des Bandes bei Neuaufnahmen mit 120er Cassetten DOSORDIE am 17.12.2009 – Letzte Antwort am 30.12.2009 – 4 Beiträge |
Qualitätsunterschiede DAT-Longplay zu DAT-Standardplay? Demo01 am 19.02.2008 – Letzte Antwort am 24.02.2008 – 9 Beiträge |
Sony DTC-57ES DAT Handbuch jh4all am 02.11.2006 – Letzte Antwort am 02.11.2006 – 2 Beiträge |
Sony MZ-R 30 Akku defekt??? vanielik am 21.05.2004 – Letzte Antwort am 26.05.2004 – 3 Beiträge |
Haltbarkeit von DAT Bändern stanko3 am 17.07.2006 – Letzte Antwort am 23.07.2006 – 2 Beiträge |
2007
- (Trafo-)Brummen beseitigen?
- Registrierte Mitglieder927.038 ( Heute: 6 )
- Neuestes Mitglieds.bibus1974
- Gesamtzahl an Themen1.554.622
- Gesamtzahl an Beiträgen21.618.334
