HIFI-FORUM » English » Stereo (Engl.) » A labour of Love | |
A labour of Love+A -A |
Savyasaachi
16:30
erstellt: 08. Feb 2006, ||
Hey all, Thisis just a small update . I will post a full review soon. Finally got rid of the 'buzzing gremlins' ![]() Rewired the entire amp and removed some redundant wires. The shielded cables seem to have done their job. Soon(probably tomorrow) ![]() A journey that has taken me almost 9 months. her's a picture of my workplace and a sneak peek at my amp showing its lovely rear ![]() will post better quality pics tomorrow..after 4 continuos hours of working on the amp am bushed! ![]() ![]() ![]() Savyasaachi [Beitrag von Savyasaachi am 08. Feb 2006, 16:32 bearbeitet] |
Savyasaachi
18:41
Hey guys, Only now at 11 in the night could i make out a very very faint humm from the drivers... ![]() I guess i will have to try and look for the problem.. However, it is nowhere near the previous levels. Am a bit disappointed with this new turn of events.. However, am still enjoying to the wonderful music it is able to turn out. Will take it to Arasu's place to try and try to remove the last of the irritating and ever persistent bugs. |
diskspinner
05:42
erstellt: 09. Feb 2006, ||
All the best. I am sure you will get rid of it soon. |
Amp_Nut
06:28
Trust U have made a "STAR" ground ... all circuit grounds to come to a single point on the Power Supply Capacitor Ground. Dont route allk grounds thru the Chasis... a sure way to get Hum that just wont go... Also can add a 100 ohm resistor between the Power Amp Input ground to the Power supply gnd. You may have to cut PCB tracks for this .... All the best ![]() |
Savyasaachi
07:01
hmm..usually what people recommend to use between input and power supply grounds is a 10 ohm resistor., I haven't tried that..Will try it as a last a resort. The way i have routed my ground is to take a wire from each of the three capacitor banks and ground them at one single point on the chassis. I am guessing that thisis what u are advising me against. right? I have three EI type transformers in my amplifier. one is a 650VA for my bridged lm4780s and OPA541. The otehr a 350VA for the paralleled LM4780s and a pair of isolated LM3886. the last one is a 20VA one for my crossover network. i have 7 amplifier modules in all. With 650VA tranny ----------------- 2 bridged LM4780s 1 OPA541 With 350VA tranny ------------------ 2 paralled Lm4780 2 LM3886 another point i want to mention is that i have directly grounded the input RCA ground connector to the chassis. Can you suggest how it should be done to eliminate possible ground loops? [Beitrag von Savyasaachi am 09. Feb 2006, 07:02 bearbeitet] |
nimz
07:11
WOW ![]() |
Amp_Nut
09:04
Hmmm.... multiple Power Supplies.... hmmm 1. First of all, you are correct... My earlier post should have read 10 ( TEN ) Ohms, not 100 Ohms. Sorry for the Typo.. The purpose of the small value resistor is to discourage a ground loop. Too high a resistor will add an output offset at the speakers. 2. Thanks for your detailed description of the grounding. Based on the fact there there is only a small amount of hummmm , you have got it almost correct. I would suggest the following : a. Remove the local chasis ground at the input RCAs. Run a ground wire from the RCAs to the power supply capacitor ground that feeds the input stage. This I suspect should help the most. Multiple RCAs should be grounded in their own, dedicated Star connection, with the Star Point on (one) the RCA with handling the lowest input signal level ( if each is for a different sensitivity ) b. Get all your 3 Power Supply capacitor grounds to meet at the -ve of the Input stage power supply capacitor. ( Not directly at the chasis) From this star point, run a single short, thick wire to a single point/bolt on the Chasis. This should be the Only ground connection on the chasis. All the Best ! ![]() |
Amp_Nut
09:11
Oops ! I forgot to mention.... I guess that you are Not deploying centre tapped Transformers ? If Yes, then the Centre Tap must be connected to its local Power supply capacitor ground terminal directly. The CT should not be connected to the metal chasis. The metal chasis should be isolated from the ground at all locations, except at a single point, as indicated in my earlier post... ![]() |
Amp_Nut
09:14
Oops Oops Oops ! ![]() If you can only hear a Faint Hum at 11 pm, and that too, with your ear inches away from the speaker, you dont have a Hum loop at all. That much of residual hum from the Power Supply is nornal. ![]() |
Savyasaachi
10:11
hey amp_nut thanks for that detailed reply. well i ahve posted this query on diyaudio.com and i have got the same repkly from them too. they too are saying that once i isolate the inpt ground from the chassis things should be fine. Will give it a try soon as i get home today evening and post an update. |
Savyasaachi
15:23
erstellt: 14. Feb 2006, ||
Hey amp nut, I think i just figured out why i am having this hummm. the star ground is connected to the stud on which the crossover is mounted which is inturn connected to the chassis. The crossover ground is not clean DC ground. It is AC ground of the crossover transformer. I will isolate it now and see if it solves the problem. A simple plastic washer ought to do it. Will post an update.. Cheers, Sachi |
Wanna Download ? Amp_Nut am 17.02.2012 – Letzte Antwort am 19.02.2012 – 2 Beiträge |
plight of a consumer myriad am 14.01.2005 – Letzte Antwort am 17.01.2005 – 6 Beiträge |
a piece of advise Prithvi am 24.02.2005 – Letzte Antwort am 28.02.2005 – 25 Beiträge |
An evening at Viren's Krish am 14.09.2005 – Letzte Antwort am 17.10.2005 – 16 Beiträge |
A Peculiar observation.more of a problem abhi.pani am 13.10.2006 – Letzte Antwort am 16.10.2006 – 28 Beiträge |
Visit to Lyrita Audio and forum member Viren Bakshi Jeeves am 28.04.2005 – Letzte Antwort am 01.08.2005 – 24 Beiträge |
A third type of AMP? Debu am 01.11.2006 – Letzte Antwort am 01.11.2006 – 2 Beiträge |
Taking care of floorstanders Bibs am 06.02.2006 – Letzte Antwort am 17.02.2006 – 7 Beiträge |
Pearls of Wisdom - 5 G_S_Madhav am 14.01.2009 – Letzte Antwort am 15.01.2009 – 5 Beiträge |
Of Speakers and Roaches soulforged am 21.04.2006 – Letzte Antwort am 05.05.2006 – 41 Beiträge |
2006
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.520 ( Heute: 3 )
- Neuestes Mitgliedtusahivasat
- Gesamtzahl an Themen1.558.364
- Gesamtzahl an Beiträgen21.700.808
