Gehe zu Seite: Erste 2 3 Letzte |nächste|
Power cables: A different view of on impact of power on components
Arj
#1 erstellt: 02. Jan 2008, 10:58
very interesting read written by the head of Shunyata
http://www.audioasylum.com/audio/cables/messages/7311.html
seems to make sense..and is totally different from the way i have looked into power till now !
There are a lot of misconceptions about power transmission and power quality that make it difficult for some people to understand why a power cord makes a sonic difference. The first question is - do power cords make any difference at all? There is no sense in talking about theories of operation if we can't agree that there is an audible effect. Most of the thousands of people that use our power cords started out as sceptics and have answered that question for themselves. And no - I do not care to debate with people that have not done the simplest of tests about whether power cords work or not. The only cases where a high quality cord does not have significant effects is when it is used with a poor quality power conditioner that acts as a high impedance to instantaneous current flow.
MIsconception #1:
AC power is like water coming from a large power tank, flowing through several 10s of feet of power hose into a component. This implies that the component is at the end of this system.
Actually, the component sits between two power conductors: the hot and the neutral. AC power oscillates (alternates) back and forth at a 50-60hz rate. So power does not pour into the component at all. The component's power supply is within a complex network of wires and connectors. ALL of the wire and connectors can and do affect the performance of the component's power supply.
Misconception #2:
AC power can be contaminated just like water in a hose. This implies that once the water is contaminated at some point up stream, that is must be cleansed before it arrives at the audio component.
As stated in #1, the component is not a the end of the power hose. It is between two power hoses and the current is oscillating back and forth. Further, current is not like water at all. Electrons cannot be contaminated. There are two aspects to power transmission: the EM wave and the current flow. The current itself cannot be contaminated but the EM wave can be modulated with other frequencies. We usually call these other frequencies noise or EMI. Within the various parts of a power circuit there may be EMI in certain parts that are not present in others. EM energy can be transformed or redirected to lessen their effects.
Some PCs use capacitors, inductors, or ferrites in an attempt to control the EM fields around the audio component. The success of such an approach is completely dependent upon the specific design and the reactance of the power supply of the component to which the PC is attached.
Misconception #3:
There is up to a hundred feet of wire in the walls, so the last 6 feet of power cord can't possibly make any difference.
The PC is NOT the last 6 feet as stated in #1 and the local current and EM effects directly affect the sonic performance of the component. The power cord is not the last 6 feet, it is the first 6 feet from the perspective of the component.
Misconception #4:
There is a tremendous amount of electrical interference and EMI coming from outside the home that we need to protect our equipment from. This implies that we need some sort of power conditioner or filter to protect the equipment.
Most of the EMI that affects the audio quality of a system is generated by the audio components themselves. EM waves that travel through space dissipate in power as the square of the distance from the source and very high frequencies that propogate through the power circuit do not survive for long. Power lines present a high impedance to Mhz and Ghz signals due to the relatively high inductance of power lines.
A primary source of audible sonic degradation is caused by the power supplies. Most components use FWBR (full wave bridge rectifier) power supplies that generate an incredible amount of transiet noise when the rectifiers switch on. The design of a PC cord can significantly affect the reactance of these signals within the power supply. The PC is effectively part of the primary winding of the power transformer. The transition between the various metals used in a PC can cause EM reflections and diode-like rectification of the noise impulses as they propogate away from the power supply. If the PC presents a high impedance to these signals they will be reflected back into the power supply where they will intermodulate increasing the high frequency noise levels of the component. Most power supply filters are ineffective at blocking very high frequency noise components and much of it is passed through to the DC rails. The sonic effects of this include: high background noise levels, blurred or slurred transients and a general lack of clarity and purity of sound.
Misconception #5:
There is some sort of conspiracy amoung audio designers that keeps them from producing a "proper" power supply that is not affect by PC quality. This concept is like saying that if a speaker where properly designed, you wouldn't need to use a good quality speaker cable.
PowerSnakes have been tested with the most modest of mid-fi equipment and the most exotic SOTA components. We have yet to find a component that cannot be improved by replacing the power cord.
As long as power supply design is based upon FWBRs or switching supplies, the power cord will always be significant.
Misconception #6:
High-end power cords just increase the circuit capacitance acting as a high-freqency shunt.
There are some power cords that ARE designed this way. Some even insert capacitors within the cable to further increase capacitance. This approach has some positives and many negatives which I won't go into here.
Capacitance alone cannot account for the differences in a power cord's performance. There are some high-end power cords that are very effective that have virtually unmeasurable levels of capacitance. These cable are usually designed around hollow tubes with the conductors inside. The conductors are several inches apart and cannot significantly affect the capacitance of the power circuit.
MIsconception #7:
Power cords are just like speaker cables; the shorter the cable the better.
Some speaker cable designers would argue that a speaker cable below a certain length is not better. We will let them address the issue if they desire.
A speaker cable conducts an audio signal from the power amplifier to the speaker. The distance is quite small, on the order of a couple of feet to several feet. The quality of a speaker cable is determined by how well it can transmit the signal from the amplifier to the speaker without alteration.
A power cable on the other hand is not transmitting a signal. It is conducting A.C. power and its sonic superiority will be determined by its ability to deliver current (steady-state and instantaneous) and its ability to deal with the EMI effects of the components to which it is attached.
SInce a power cord is composed of a hot and neutral wire that the component sits between, a change in the length of the cord will increase the size of the "buffer" around the component. In the specific case of PowerSnakes - we use a proprietary substance within our cables that absorbs EMI. Increasing the length of the cable, increases the coupling effect to this substance, therefore increasing the performance of the cable.
In general, I would not recommend a power cord that is shorter than 3 feet or 1 meter in length. But subtle degrees of audio performance are not the only consideration when putting together an audio system. Esthetics are also important especially when the system is located in a beautiful home. I just point out the performance differences so that people can make an informed decision when determining the optimum length for their cables.
There is much more that can be discussed about power delivery but for the sake of brevity I'll cut it short at this point. On a personal note I would like to say that I was an audiophile long before I was a manufacturer of audio products. Before Shunyata Research I designed high speed networking devices and can tell you that there is a lot more money to be made in the computer industry. Like many of the of manufacturers of high-end audio components, I design my products for myself and for the love of music. If other people like what I have created - great. If after trying our product you prefer another - great. There is a wide diversity of preference and subjective perception amoung individuals. Thank goodness there is also a wide diversity of manufacturers that create products to serve a variety of tastes.
Caelin Gabriel
Shunyata Research Inc.
Behram
#2 erstellt: 02. Jan 2008, 11:27
I had an old HP Inkjet printer that was unrepairable. Fortunately its external Power supply and the HP Power Cord were OK. The HP power cord is slightly thicker than the usual IEC Computer cords, is what I've noticed. As this was a piece of junk, just out of curiosity I replaced my Pre amp Power cord with this HP Power Cord and the sonic difference was real.
Those of you having HP printers may try out this little excercise.
Behram
bhagwan69
#3 erstellt: 02. Jan 2008, 18:28
Interesting Article;
I would love to know what PC are used by our Forum Members ?
Apart from Printer Cords - sorry Behram - just kidding....
Seriously speaking, have other members used different PC's & 'heard' a difference ??
I have a few [many] lying around. You guys are most welcome to borrow for audition purposes if interested.
Arj
#4 erstellt: 02. Jan 2008, 18:36
i have used (and use) a DH labs, a Tara Labs and a chinese made Xindak power chord.
still working out the combinations on what with the source and what with the amp !
bombaywalla
#5 erstellt: 02. Jan 2008, 20:54
Arj,
when I spoke to someone in the audio industry that I respect & who products speak for themselves, I was informed that Shunyata power cords sucked big time!! I was told that they bloated all the parts of the audio spectrum thereby giving a false interpretation of the music being played.
I've never used one myself so this IS 2nd-hand knowledge.
I do agree with the Shunyata that power cords do make a difference (& I have been able to hear the difference myself in my own system).
What I've discovered/found is that power cords that are soft/spongy when you try to press them between your fingers are the worst kind - they bloat some or all parts of the audio spectrum. The sound might be to your liking at 1st but long-term the sound will be much coloured.
If you want to read more on Power Cords & Power conditioners then there is a more humbler fellow by the name of Mike vanEvers (who also makes respectable audio gear) who also has much to say about these 2 items. Here is a link to his website & some of the techno-babble (to quote Mike vanEvers):
http://www.vansevers.com/technical.html
Of particular interest are #2 & #4
ani
#6 erstellt: 03. Jan 2008, 06:39
Hi all,
Interesting reading, but somehow am not convinced by most of the scientific explanations. May be science is yet to find out what they should measure or investigate
Yes I have tried a few cords and found that CD and Pre amps most sensitive to PC changes. Switching OFF the CD even changes the Vinyl system playback !!
Have tried Taralabs, VDH and a JPS, all sounded different.
I felt that to take better advantage of these PC I have to upgrade my system to higher level.
Regards
Anil
[Beitrag von ani am 03. Jan 2008, 06:45 bearbeitet]
Arj
#7 erstellt: 03. Jan 2008, 10:26
what i liked about the article was the idea that it is the last 1M which is the most important and that it is the electrical isolation (or the lack of it) which can cause issues in the power.
i have always been thinking of it only in terms of the purity of input power..but that should be pretty well negated by a good good rectfier in the component.
square_wave
#8 erstellt: 03. Jan 2008, 10:40
Interesting to note that the from the component’s perspective the power cord is the first 6ft of wire it sees.
Cords always made a difference in my system. Some for the better while some screwed up.
Amp_Nut
#9 erstellt: 03. Jan 2008, 16:35
While I an a believer that Power Cords and cables change the sound of a sufficiently resolving system, the reasons stated by Caelin Gabriel do not convince me.
Whether the wire is the 1st 3 feet or the last 3 feet of a 100 mile lenght, makes no difference ... since ALL the feet are in SERIES...
What goes in at one end of a series connection has to come out the other end, and flow in Exactly the same quatity throughout the zillion feet.
That is why a 2 inch length of fuse wire will protect 1 KM or whatever, of wire, connected to an appliance. And it does not matter a fig whether the fuse wire is located in the 1st 3 feet or the last last 3 feet or whatever.
Ofcourse, the Nebulus explanation of EM etc etc without a firm scientific ( as we know it ) explanation is hardly faith inducing from a company selling Rs 50K of power cord...
I share ani's view that "May be science is yet to find out what they should measure or investigate."
For my part, I am still looking for a convincing scientific explanation, for what I hear, from Power Cords.
Amp_Nut
#10 erstellt: 03. Jan 2008, 17:17
Power Cord to my Denon 2900 Universal Player : Cardas Gold
Power Cord to my Prima Luna PL2 Integrated Amp : Audio Power Industries 313.
particleman
#11 erstellt: 04. Jan 2008, 07:14
A super-informative site even for lo-fi laypersons such as myself. It has provided many enlightening hours of reading. Thank you very much!
Behram
#12 erstellt: 04. Jan 2008, 09:24
Some time ago on this very forum someone had put up a link of a site that shows the complete circuit diagram of an isolation transformer with centre tapped secondary and associated filter circuitry on the secondary winding. The forum member had high regards for its performance.
I tried to do a "Search" but cannot locate that thread. Could someone help me out please ?
Thanks in advance.
Behram.
bombaywalla
#13 erstellt: 04. Jan 2008, 17:35
I share these sentiments, Amp_Nut!!
bhagwan69
#14 erstellt: 05. Jan 2008, 07:18
Interesting timing;
I just received 3 PC's from Transparent Audio this morning.
http://transparentca...inkmm_powercord.html
They are in customs, I should get them by Monday. I will replace the 'Jorma Design' with this & try to listen for a difference.
I plan to use them on the CD & Pre Amplifier [is that OK ?]
I only have 3, so power amp will have to pass. My pre amp needs 2 power cords.
I wonder if the cables will make any difference.
Arj
#15 erstellt: 05. Jan 2008, 07:40
bhagwan69 schrieb:
I wonder if the cables will make any difference. :cut
we shall all await with bated breaths to find out your results
Behram
#16 erstellt: 05. Jan 2008, 08:03
Why so ?
Arj
#17 erstellt: 05. Jan 2008, 08:38
I am assuming separate layouts per channel ?
bhagwan69
#18 erstellt: 05. Jan 2008, 08:54
Yes;
You are correct.
Left & Right channels have seperate chasis. 2 for AC to DC & 2 for Pre Amplification.
Hence the 2 power supplies need 2 power cords. 1 for the left & the other for the right. Both are seperate - chassis - i.e.
Basically the pre amp is in 4 parts. Left Power & Right Power & Left Pre & Right Pre.
The Power Supply to the Pre has its own umbillical cord for pure DC. I think.
I will hook this up on Monday & let you know.
If anyone in Mumbai wants to try the cables out, I would be more than willing to lend them for a few days. However, the termination is Euro Schucko [had them specially ordered] so you will need a female Schucko to use this cord. Else the ground / earth will not connect.
bombaywalla
#19 erstellt: 06. Jan 2008, 00:19
Hello Bhagwan69,
we eargerly await your 1st impression of the Tranparent Audio cables.
which model did you buy?
Arj
#20 erstellt: 06. Jan 2008, 02:50
sir, you have now taken the curiosity over the results a notch higher.
what is your opinion on the sensitivity to power cables for your pre ?
while power is unarguably the most sensitive in the source and the pre, the dual mono setup with separate PSUs should make differences in powerchords very limited ??
do let us know your results !!!
bhagwan69
#21 erstellt: 06. Jan 2008, 05:48
Hello Sir !
I had posted the link in my earlier post:
http://www.hifi-foru.../power/powerlinkmm_A
This is the 'best' PC that TA makes.
The PowerLink MM with Euro Schucko Connectors.
Sure will let you know how it turns out.
bhagwan69
#22 erstellt: 06. Jan 2008, 05:53
[quote]while power is unarguably the most sensitive in the source and the pre, the dual mono setup with separate PSUs should make differences in powerchords very limited ??
[/quote]
Sir, you are very correct in your observation.
Since there is 'so much' issolation [physical] in the pre amplifier, a power cord change should not make any / much difference........
Unless, we go by what Shunyata's boss has to say;
The PC is the 1st entry into your component & the last exit from your component..............
All said, the fruit of the pudding is in the eating.
The Pudding has been made & shall be served on Monday / Tuesday. I shall eat it, share it with others & then decide, if it was worth it [financially & otherwise] !!!!
[Beitrag von bhagwan69 am 06. Jan 2008, 05:56 bearbeitet]
Amp_Nut
#23 erstellt: 06. Jan 2008, 13:50
At the risk of sounding obtuse, I beg to differ.
I would speculate the following, all IMHO ofcourse
1. Physically and electrically separating 2 stereo channels in a Pre Amp will improve Isololation, reduce cross talk, improve imaging etc.
2, It will NOT improve Transient response, bass slam, quality of treble and mid-range, fluidity of sound, tonal balance & cohieveness etc.
The power cords to the Pre will not affect performance parameters outlined in point 1.
The Power Cords WILL (IMHO Ofcourse) impact the Performance parameters indicated in Point 2; above.
So I wait with baited breath for Bhagwan69's verdict
bhagwan69
#24 erstellt: 06. Jan 2008, 14:00
Interesting - the way you put it.
Will keep you guys posted......
The PowerLink MM is a 2 meter, 10 AWG, high current capability, grounded power cord which is precision constructed of heavy, solid core OFHC conductors for greater power handling. Teflon insulation and three shields help reduce noise. The carefully-designed network circuit rejects RF noise. The cord is UL and CE approved for high voltage, high heat applications; it is available with 15- or 20-amp IEC connectors. The PowerLink MM allows high current, high powered amplifiers to achieve all the dynamic ease, punch, clarity, and neutrality of which they are capable. Its sturdy construction, termination integrity, and noise blocking technology make it a safe and musically satisfying alternative to standard and audiophile grade power cords. The PowerLink MM power cord has a network module, like those on Transparent analog interconnects and speaker cables, to reduce high frequency noise. This network is a far more effective noise reducer and sounds far more neutral than the "cable alone" approach of audiophile power cords. Many audiophile cords have resonances that actually increase the impact of noise in the frequency areas affected by these resonances. The effect may be euphonic, but these euphonic distortions prevent you from hearing your favorite music as it was recorded. Transparent PowerLink MM cords are truly transparent.
[Beitrag von bhagwan69 am 06. Jan 2008, 14:06 bearbeitet]
Arj
#25 erstellt: 06. Jan 2008, 16:01
I do use a transparen MM+ speaker wire with the network box. not sure of what it does over another cable i use the Goertz MI2 which is a low inductance/high capacitance cable..
but again speaker cables behave differently to power cables
bhagwan69
#26 erstellt: 07. Jan 2008, 04:13
Reference MM Speaker Cable
(Printer Friendly Version)
Reference MM Speaker Cable consists of many heavy strands of individually insulated oxygen-free copper. Reference MM displays ideal low noise, low resonance and low distortion properties in audio signal applications. Reference MM achieves these qualities because of the strengths of MM Technology, which represents a complete redesign of over 300 audio cables in our line: new strand size, new tighter-spec components, improvements to layout, more effective damping, and new network housings.
Transparent's flagship OPUS MM cables were the first to introduce the new streamline shape in an incredibly stiff, lightweight, and costly carbon fiber shell. Using the OPUS MM shape as a model, Transparent focused on using more cost effective nonmetallic materials in the rest of the MM line-up that could be molded or machined to achieve this new shape. The finest example of this is Reference MM, which shares electrical characteristics with OPUS MM and uses the same damped suspension and adjustable feet to decouple the network from room borne resonance.
Sir, the cable you use is near reference level. In fact it is 1 step below the 'opus'
This is a very very serious cable.
Could we exchange cables for a few days ?
I would love to hear this cable in my set up.
I could give you my Argento VDM Reference is exchange for a week or so.
http://transparentcable.com/products/audio/ref_mm_spkcable.html
What speaker do you use this cable with ? It retails @ 15 K US ++ for a 3 M set.....
bhagwan69
#27 erstellt: 07. Jan 2008, 04:37
Is this the cable that you use :-
I sure would love to hear it; serious.
In my chain, i.e. I have auditioned it elsewhere [well the opus] but in my set up, would be a golden chance.
Arj
#28 erstellt: 07. Jan 2008, 04:59
Sir you are scaring me ! my entire system does not cost that much.
what i use is the older version of the MusicWave plus 8" . it is only 2 levels above the entry level.
(i should have written it as MW+ not MM+ which i wrote..My Mistake)
http://www.transparentcable.com/products/audio/plus_spkcable.html
the reason i liked them is that they apparently finetune the dielectric and impedence to keep the response curve the same across all the different lengths unlike regular bul wire..but of course no proof of it is available
[Beitrag von Arj am 07. Jan 2008, 05:06 bearbeitet]
bhagwan69
#29 erstellt: 07. Jan 2008, 08:30
oh oh !!
How much difference a MW & MM can make.
Sorry Sir.
I was under the wrong impression.
Arj
#30 erstellt: 07. Jan 2008, 09:07
please do not apologise..was my error.
yes a W and M can make all the difference
bhagwan69
#31 erstellt: 07. Jan 2008, 15:56
This may take a while;
I still have to get my speakers to play to a level that satisfies [ ], before I make any changes. The positions are still being experimented with. Once I am set with that, I will change the power cords.
Currently I dropped the PC's off to another friends place.
Will get it back on Saturday.
Does any one else want to try them out ? In Bombay preferrably.......do let me know, I sure could lend them out for a few days.
bhagwan69
#32 erstellt: 11. Jan 2008, 05:13
Heard a difference last night !!
I had lrnt my PC's to another friend.
Went to his place last evening.
Switeched between vdH & TA and this was done only on the Power Amplifiers & the difference was apparent.
Switch it On too was present.
Got so me Valhalla Power Cords back to try. Would like to compare that with the Powerlink MM.
Unfortunately, termination is US [on the Nordost], so will have to figure something out.....
P.S. I gave 3 PC's to Behram to try out too. He will write about it soon, I hope.........
bombaywalla
#33 erstellt: 11. Jan 2008, 14:25
Man, you are messing with some top-of-line stuff!!!
lucky fellow!
bhagwan69
#34 erstellt: 11. Jan 2008, 16:05
Hello 'B' !
How are you ?
To be truthful to you, was never a believer in PC's
I/C's & Speaker Cables make a difference - sure - that is very very easy to know.
PC's would make such a big difference, I heard for the 1st time.
I had personally moved over from vdH to Jorma Design some 3 years back and last year upgraded the connectors [termination] to Oyaide. I had never planned to 'spend' this kind of money on PC's
But, what happened last night, astonished me. The difference was 'chalk & cheese'
Now, I shall do the Nordost Valhalla & Transparent Cable PowerLink Super Power Cord comparison on a CD Player & then put in the MM & check again.
This has really become interesting !!!
lucky fellow!
Sir, I shall use the words, 'Poor Fellow' instead. The Cables are bleeding me. The cost is prohibitive.
The problem is that the difference can be 'heard' so you can't even walk away..........
SNV
#35 erstellt: 11. Jan 2008, 18:17
Wah bhai wah, Poor Fellow uses a PC worth rs 80,000/-. (20k more and one can buy the new Tata Nano car)
Id sure like to be poor as you bhagwanji.
Regards
SNV
bhagwan69
#36 erstellt: 11. Jan 2008, 19:56
The actual problem is I need 6 of them.
I got 3 to try, but I will have to buy 6 for all the equipment. 2 for Pre + 2 for Power & 2 for CD Player.
All this will surely make me very very poor and in debt !!!!
Do not wish for it, it is not a pleasant state to be in - trust me.
bombaywalla
#37 erstellt: 11. Jan 2008, 20:54
yup! the dual mono implemenatation thru out the chain sure makes buying expensive power cords a PROHIBITIVE bill!!
Personally, I have 5 PCs that I would need to swap out should I decide to. It's the FAT bill that has kept me from doing so.......
bombaywalla
#38 erstellt: 11. Jan 2008, 20:58
bhagwan69 schrieb:
Hello 'B' !
How are you ?
lucky fellow!
Bhawanji,
I am fine, Sir! Thank you for asking.
Indeed, PCs do make a difference. The diff is system dependent & AC power quality dependent.
AC power-wise, for me, the eye-opener was the wall outlet! I never believed that it could make a diff until I went to a friend's house & we heard the sonic differences among the cheap outlets that builders put when the build a house, a non-cryo treated Hubbel 5363, a cryo treated Hubbell 5363 & a Wattgate. Boy, did that listening session totally change my opinion on this matter or what??
bhagwan69
#39 erstellt: 12. Jan 2008, 04:58
Sir, same problem @ my end.
I never used 'super expensive' PC's for this same reason. I deally I should have gone in for the Argento Flow, that would have completed my set, however, each PC is 2.5 K EURO.
I dropped the idea & looked @ American Options instead.
I have gotten 3 so far, I need to get 3 more.
This will have to be done; The difference is too much to ignore..............trust me. I hate the results - sure makes me loose / spend more money & I definately do not like it.
p.s. I will go and listen to the Nordost Valhalla & TA [entry level] PC on Sunday.
Amp_Nut
#40 erstellt: 12. Jan 2008, 05:00
Do tell us more.
I have always been a firm believer in Power Cords, I believe it generally has the more impact on Non Valve equipment ..
abhi.pani
#41 erstellt: 14. Jan 2008, 06:32
Amp_Nut schrieb:
Do tell us more.
Me too curious about this one....
Hi Bombaywalla, did your friend change the entire wiring or just the connectors/sockets ??
bhagwan69
#42 erstellt: 14. Jan 2008, 07:12
I did this test on Saturday;
We used a Transparent Canle - Power Link Super Power Cord
http://transparentcable.com/products/power/powerlink_super.html
against a Nordost Valahalla Power Cord
http://nordost.com/index.php?id=340
against a PS Audio Power Cord
I do not recollect the model... sorry
We only changed it on the CD Player.
There were 3 of us present, Deaf + Switch it on & myself.
The difference was apparent.
The PS Audio was out classed in less than 1 second.
The Transparent Audio Power Cord was better than the Nordost 3 : 0 vote. All of us preferred the TA PC over the Nordost Valhalla PC.
Deaf may shed some light on the details of the test.
bhagwan69
#43 erstellt: 14. Jan 2008, 07:18
The TA PC we used in this test was the 3rd from the top.
I did not take my MM PC's there [termination issue].
Basically the 3rd best TA was better than the Best from Nordost.
If we were to compare the MM to the Valhalla, it would be a wash out.
Actually I am working on borrowing a few cords from Siltech, G6 - Ruby Mountain.
I have begged for it. If they come, I shall test it against the TA Pc - MM's.
That will make for a very very interesting observation.
The problem is the termination.
I use Euro Schucko,
The Siltech G-6's [SATT done] are UK Termination.
Hence, the testing procedure is not easy & streamlined.
Or correct for that matter.
If they come, I will let you guys know, how it turned out...........
bombaywalla
#44 erstellt: 14. Jan 2008, 15:12
Thanx for the PC shoot-out details, Bhagwan69.
Interesting results indeed - the 3rd-from-the-top Transparent Audio PC bested the top-of-the-line Nordost.
bombaywalla
#45 erstellt: 14. Jan 2008, 15:19
abhi.pani schrieb:
Amp_Nut schrieb:
Do tell us more.
Amp_Nut, Abhijit,
Not much more to say other than I am firm believer that quality of wall outlets has a (profound) impact on the overall sonics.
I've found that wall outlets MUST have pure brass in their construction. Any Nickel/Zinc plating makes the sound brittle & edgy. If you are listening to CD music, you'll get a bad case of digitis with those Nickel/Zinc plated outlets - I did!
On top of this, cryo treated wall outlets sound even better (truer tonal timbral accuracy, better tonal balance, speakers disappearing in the room) than non-cryo'd outlets.
One warning - good quality outlets can be costly - take a look at the offering from Furutech, Oyaide, Wattgate to get a feel!
I've found that they are worth it despite that!
My friend has dedicated wiring to this audio room. So, he changed both - wiring & wall outlets. Maximum positive impact!
Same case for my audio set up.
bhagwan69
#46 erstellt: 11. Feb 2008, 14:51
Just got my 3 PC's
Installed them into the rack 45 mins back.
The damn 'box' is too big. Occupies too much space !!!
The difference is too apparent.
I have only put the cables on the Pre & CD.
Power Amp is still on the Jorma Design.
However, the diiference is too much too miss.
The 'Noise Floor' has dropped by 'miles'
The 'grunje' has moved away. Sound stage has gone back - signigicantly.
You may not miss the PC if it was not is your set up, however all said, if you had to go back to the older PC's after the PLMM - boy that will be very very difficult.
Trust Me; well if you don't, cool drop by and listen for your self. I will be ready to do the swap and demonstrate !!!
ALS
#47 erstellt: 11. Feb 2008, 16:58
Bhagwab, What brand are they? All 3 same or diff brands?
Have you ever tried Chris's PCs (VH Audio, US).
bhagwan69
#48 erstellt: 11. Feb 2008, 17:33
It is :-
PowerLink MM Power Cord
All 3 are the same - Euro Schucko Termination - 2M long.
This is the Link :-
No sir, never tried this.
I used to use Jorma Design - Sweden prior to this.
bombaywalla
#49 erstellt: 12. Feb 2008, 00:09
ALS,
Ahem!...
Bhagwan is playing in a very top-notch field - he has the top-of-the-line Transparent Audio power cable. It's expensive! & that's an understatement.
The VH Audio power cables simply do not play in that league!
bhagwan69
#50 erstellt: 12. Feb 2008, 04:43
Hello Bombaywala !
I have never heard the VH Audio products;
Are they good ?
You see, more often 'prices' are no indication of the product quality. More a function of Marketing Cost & Designers Ego'
Hence, it is not correct to judge the performance of products by their price !!!!
I have auditioned so many products at different places in different times & they are rather expensive [at least from my point of view] and they do not even sound average !!! Case in point being MBL. Below par......
So if a VH Audio cord is good, I sure am ready to listen to it.
All said, this PLMM is a 'serious' PC. May be bloody expensive - cheaper than the Siltech [this is what I actually wanted - Ruby Mountain] - but there is a difference & it is very very 'audible'
Simply like a component upgrade !!! Please do not bash me for saying that !
[Beitrag von bhagwan69 am 12. Feb 2008, 04:46 bearbeitet]
Arj
#51 erstellt: 12. Feb 2008, 05:01
ALS schrieb:
B
ALS, these fall into the VFM (Value for Money) segment and are good for upto more than 1 or 2 steps above entry level components .
I had bought some oyaide power socket from him which i still have to install/get installed
[Beitrag von Arj am 12. Feb 2008, 05:04 bearbeitet]
Power sources and components
Arj am 27.06.2007  –  Letzte Antwort am 29.06.2007  –  21 Beiträge
impact of sound
Arj am 16.11.2006  –  Letzte Antwort am 17.11.2006  –  5 Beiträge
A different approach towards traditional speaker setup
Arj am 04.12.2005  –  Letzte Antwort am 07.12.2005  –  7 Beiträge
Advice on speakers
Krish am 11.01.2005  –  Letzte Antwort am 12.01.2005  –  15 Beiträge
Inputs on an AVR
Betelguese am 18.05.2005  –  Letzte Antwort am 20.05.2005  –  7 Beiträge
Request 'Gyan' On Digital Interface Formats
Amp_Nut am 06.03.2008  –  Letzte Antwort am 10.03.2008  –  11 Beiträge
Discovered a nice power cable
abhi.pani am 01.04.2008  –  Letzte Antwort am 02.11.2008  –  24 Beiträge
Shielded Cables
myriad am 31.12.2004  –  Letzte Antwort am 07.01.2005  –  15 Beiträge
4th of July trip.
bombaywalla am 09.07.2010  –  Letzte Antwort am 15.07.2010  –  8 Beiträge
Tube PreAmp and SS Power Amp
herculepirate am 23.04.2007  –  Letzte Antwort am 13.05.2007  –  48 Beiträge
  • Registrierte Mitglieder928.479 ( Heute: 2 )
  • Neuestes Mitgliedjuli7994292
  • Gesamtzahl an Themen1.558.317
  • Gesamtzahl an Beiträgen21.699.604
