Gorgeous 10 !
Soundsgreat
#1 erstellt: 04. Apr 2009, 15:42
Hello folks here's some good news for all the wharfedale fans !! The all new 10 series speakers are to be launched soon !!
Please read on for further details !
(Source a Finnish Website, The text is translated so some obvious mistakes, Please overlook these mistakes)
Wharfedale Diamond 10 series to Finland in April. Wharfedale Diamond 10 series to Australia in April.
Although the Diamond 9 series of sales continues to be strong, Wharfedale has decided to publish the Diamond 10 series this spring. Although the Diamond 9 series of sales continues to be strong, Wharfedale has decided to publish the Diamond 10 series this spring. This series will not replace its predecessor, but rather to complement the Wharfedale range. This series will not replace its predecessor, but rather to complement the Wharfedale range. Here are a few new features: Here are a few new features:
Series design is a British tradition, with the. Series design is a British tradition, with the. Housing to the classic lines combine modern selkeäpiirteiseen etulevyyn. Housing to the classic lines combine modern selkeäpiirteiseen etulevyyn.
Rounding the casing is not made to the traditional cutting method, but the multi-layered MDF laminate is heat-treated rounded. Rounding the casing is not made to the traditional cutting method, but the multi-layered MDF laminate is heat-treated rounded. This makes the casing more rigid and acoustically vaimeamman. This makes the casing more rigid and acoustically vaimeamman. This method is also used as a factory high-end models in the EVO2 and OPUS. This method is also used as a factory high-end models in the EVO2 and OPUS.
Trimmilevyt elements are diamond-cut aluminum. Trimmilevyt elements are diamond-cut aluminum. Refleksiputket is now directed backward, and the connector panel is black for revision, the aluminum casting. Refleksiputket is now directed backward, and the connector panel is black for revision, the aluminum casting.
The bass and middle tone elements rootstocks have been formulated to reduce unwanted reflections. This formulation would be possible to describe the word "audio stealth", where many of the body element of the normal pattern of the reflective surfaces are eliminated. As a component part of the back reflections are not affected by elements in the forward to the sound. The bass and middle tone elements rootstocks have been formulated to reduce unwanted reflections. This formulation would be possible to describe the word "audio stealth", where many of the body element of the normal pattern of the reflective surfaces have been eliminated. Thus the rear element of the reflections are not affected by elements in the forward to the sound.
Bass and keskiäänielementeissä used black Kevlar-cone. Kartioreunukset has been reworded to agree unwanted reflections element frame. Bass and keskiäänielementeissä used black Kevlar-cone. Kartioreunukset has been reworded to agree reflections reduction element of the frame. The pattern is also jäykistyksiä reducing kartioreunuksen resonance. The pattern is also jäykistyksiä reducing kartioreunuksen resonance.
Diamond 10 Series speakers stand, speakers, 10.0, 10.1, 10.2 and center speakers are magnetically shielded. Diamond 10 Series speakers stand, speakers, 10.0, 10.1, 10.2 and center speakers are magnetically shielded.
The series has 16 models - more than ever before. It consists of three stand-, five-floor, three middle and two rear speaker model. The series has 16 models - more than ever before. It consists of three stand-, five-floor, three middle and two rear-speaker model. These still need to be extended three subwoofermallia. All the speakers with a glossy black front. These still need to be extended three subwoofermallia. All the speakers with a glossy black front. Finishing the speaker are the same as the Diamond 9 series of more recent models: Finishing the speaker are the same as the Diamond 9 series of more recent models:
http://www.audiophil...chnische%20daten.jpg
Shahrukh
#2 erstellt: 04. Apr 2009, 15:52
The Diamonds hold a special place in my heart. I still think the 8 series was their best - yellow kevlar drivers and all!!
Soundsgreat
#3 erstellt: 04. Apr 2009, 17:47
Shahrukh The Diamond 8 Is not Was !!
Yes I totally Agree with you ! that 8series was a gem ! I like the 8.3 then 8.4 for its sheer musicality ! but too bad they didn't import to many of them !
Now the news is that they may phase out the 8 series ! which is very sad !
Anyway lets see how this new 10 series is going to be !
should land here in a months time as they hardly have a time lag in launching it here !!
Regards.
Shahrukh
#4 erstellt: 05. Apr 2009, 06:45
The 8.1 was my entry into this fascinating hobby of ours. I remember how wowed I was with its midrange and detail (for a Rs 8,000 speaker, that is.) Beautiful stuff! Let's see what the 10 series does!
Manek
#5 erstellt: 05. Apr 2009, 15:53
Sharukh,
My whardale favs in the 8 series were 8.2's. Nearly bought them years ago.
The evo's were well made but am not sure if they sold well, maybe they did.
Hey speaking of tweeters...what's happened to our peerless india ? The last time I checked their website was taken down I think.
Manek
Savyasaachi
#6 erstellt: 05. Apr 2009, 20:59
Heh..I have always had a soft spot for the Diamond 8s..
I had the Diamond 8.1 actives for a while and still have the 8.4s as the fronts for the HT. Even the 8 center which I think is a real bang for buck center channel.
I currently own an Evo10 paired with a Sansui AU-217 amp..its a kickass system for the 125$ I spent (80$ for the speakers $35 for the amp).
Never did warm up to the 9 series..maybe the 10 is going to be different..
abhi.pani
#7 erstellt: 06. Apr 2009, 05:44
Diamond 9 from Wharfdale seemed like a confused range. It neither had the details and musicality of Diamond 8 nor did it have anything special for the HT guys. It just sounded ordinary. Strangely its selling .
opinions on wharfedale diamond series
stevieboy am 01.02.2005  –  Letzte Antwort am 02.02.2005  –  9 Beiträge
wharfedale diamond SW 150
purnendu am 15.02.2007  –  Letzte Antwort am 19.02.2007  –  9 Beiträge
budgeted music ( wharfedale + denon )
alpotnis am 02.09.2005  –  Letzte Antwort am 26.09.2005  –  28 Beiträge
10 questions on computer based audio
Arj am 02.02.2009  –  Letzte Antwort am 30.05.2009  –  28 Beiträge
Sand filling of Diamond 8.4
benkenobi am 03.03.2005  –  Letzte Antwort am 03.03.2005  –  7 Beiträge
What happened to the NAD silverline series ?
square_wave am 21.02.2007  –  Letzte Antwort am 26.02.2007  –  16 Beiträge
Recommendations for Floorstanders
Psycholic am 24.01.2006  –  Letzte Antwort am 04.09.2006  –  28 Beiträge
Wharfedale Diamonds
Alymangy am 24.01.2005  –  Letzte Antwort am 25.01.2005  –  22 Beiträge
wharfedale diamond.5
srikarkav am 30.11.2005  –  Letzte Antwort am 05.12.2005  –  5 Beiträge
Wilson Alexandria X-2 Series 2 - $148000/-
bhagwan69 am 11.09.2007  –  Letzte Antwort am 11.09.2007  –  11 Beiträge
  • Registrierte Mitglieder928.513 ( Heute: 6 )
  • Neuestes MitgliedPokeball
  • Gesamtzahl an Themen1.558.358
  • Gesamtzahl an Beiträgen21.700.632
