HIFI-FORUM » English » Stereo (Engl.) » What is antiskating and what is it's function? | |
What is antiskating and what is it's function?+A -A |
jani
18:36
erstellt: 15. Okt 2010, |
Hi, I posess a Technics 1210 MK2.Can anyone please explain me what is "antiskating" and how does it work.My Turntable is new and I need to know these functions properly in order to operate it.So please help. Regards, Bumba |
bombaywalla
01:35
erstellt: 16. Okt 2010, |
anti-skating refers to those people who do not like to skate. these people often take to skiing or snow-boarding. ![]() |
bombaywalla
02:13
sorry, the situation was just begging me..... ![]() ![]() on a more serious note - anti-skating is a complex topic & there are many viewpoints on it hence many methods to resolve it. Basically, it refers to the centrifugal force that effects the pivot tone-arm as the tone-arm tracks the LP groove from the outer edge to the inner edge. The centrifugal force will pull the tone-arm towards the spindle (center hole of the LP). Linear tracking tone-arms do not suffer from skating since they linearly track the groove. As you know, the LP groove is V-shaped. One edge of the V is right channel & the other edge of the V is the left channel. To get good stereo sound, the stylus (don't call it a bloody "needle"!! ![]() This will happen if the anti-skating is correctly set such that the tone-arm is not pulled towards the spindle (center). If the anti-skating is not set, the stylus will be pushed against the inner groove (left channel) & you will get hardly or zero sound from the right channel. Over time, this is bad for your LPs as the stylus will mutilate the left channel groove & you will end up hearing a lot of groove distortion (which sounds like the voices splitting when the music gets loud or when the artist hits a high note in his/her voice). So, basically, you need to adjust the provided anti-skating dial such that you get equal sound from the left & right channels. In such a case, the tone-arm is free of any centrifugal force & can freely float from outer-most groove to inner-most groove as it tracks. Getting the anti-skating just right is a trial & error thing & will be adjusted over many LP playing sessions. It is usually not done in 1 sitting. Note that the key is to get the quantity of anti-skating just right because if you over-do it, then the tone-arm is (guess what??) slammed against the outer-groove (right channel) only & you get minimal sound from the left channel. In such a case, you have too much centripetal force (force pushing the tone-arm outwards towards the outer edge of the LP). What's a good way to check if you have your anti-skating set correctly?? One technique I have used is to find an old LP that you do not care about which has a large section of the lead-out groove. The lead-out groove is the area around the center of the LP after all the music tracks are completely finished. You will notice that this area is shinny since it has a widely-spaced lead-out groove. Place the stylus (very carefully) on this shinny part of the LP. If you have zero anti-skating set, the stylus will zip right away towards the spindle (because there is so much centrifugal force on it). As you gradually start increasing the anti-skating (the operative word here is "gradually"!) you will notice that the speed at which the stylus moves towards the spindle/center gradually slows down. Keep increasing the anti-skating until - you guessed it correctly! - you see the stylus move outwards i.e. away from the spindle/center. At this point you have too much anti-skating! Back off/reduce the amount of anti-skating such that the stylus slowly moves towards the spindle/center. Note that you will have to carefully put the stylus on the shinny lead-out groove part again & again as you gradually adjust the amount of anti-skating. Now, this is a good starting point. No sir, you are NOT done setting anti-skating! ![]() ![]() Hope that this helps...... |
bombaywalla
02:32
I forgot to add a link of some nice zoomed in views of the LP grooves: ![]() |
What is a good CD Changer Max3 am 12.11.2003 – Letzte Antwort am 25.11.2003 – 10 Beiträge |
What is a Good Speaker? SDhawan am 04.10.2004 – Letzte Antwort am 06.10.2004 – 3 Beiträge |
what is a graphic equaliser filmguy am 05.04.2005 – Letzte Antwort am 06.04.2005 – 2 Beiträge |
What is Wow & Flutter? philipmorris am 24.07.2006 – Letzte Antwort am 24.07.2006 – 2 Beiträge |
what is Speaker Break-In juggy_25 am 17.07.2006 – Letzte Antwort am 24.07.2006 – 6 Beiträge |
Graduating to NAD and don't know what ...? SDhawan am 15.08.2004 – Letzte Antwort am 21.08.2004 – 15 Beiträge |
What is dual mono in AVRs Bibs am 15.09.2006 – Letzte Antwort am 15.09.2006 – 2 Beiträge |
What Hifi Indian Edition - First Impressions Krish am 08.11.2005 – Letzte Antwort am 08.11.2005 – 3 Beiträge |
What Cables to use ?? abhi.pani am 19.01.2005 – Letzte Antwort am 19.01.2005 – 6 Beiträge |
What is your personal preference : Pure Stereo or HT? Prithvi am 28.04.2005 – Letzte Antwort am 29.04.2005 – 20 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.513 ( Heute: 5 )
- Neuestes Mitgliedkaiserstuhlbruno
- Gesamtzahl an Themen1.558.357
- Gesamtzahl an Beiträgen21.700.613
