HIFI-FORUM » English » Stereo (Engl.) » Onkyo Speaker SKF101 | |
Onkyo Speaker SKF101+A -A |
Srini
10:54
erstellt: 20. Jan 2005, |
Hi to all I am new member to this forum I bought a pair of Onkyo peakers at a sale in onkyo showroom, Bangalore. Speaker specifications 16 cm Cone Woofer x 2 2.5 cm Soft-Dome Tweeter Magnetically shielded Gold-plated,heavy-duty, multiway binding posts MDF cabinet Impedance: 6 ohm Max. input power: 150W Frequency response:32Hz-35kHz WHD: 216 x 921 x 285 mm Weight: 14.2 kg I would like to know about the speaker performance as I have tested it in the showroom and I am getting a NAD320BEE amp this month end. So I would like to know about this combination. Regards S.Giridhar |
12inchdriver
11:12
CONGRATULATIONS BUT YOU HAVE GOT THE ONES WHICH ARE USED FOR HT SYSTEMS.....WELL YOU NEED TO SEE HOW IT PERFORMS WITH NAD. |
Srini
11:31
Thank you for the reply I would like to know the difference between HT speakers and the stereo speakers |
12inchdriver
12:05
HT refers to the Home theatre and normally these speakers are used with subwoofers and you don't feel the bass deficiency.but when used for stereo you might notice the narrow range |
Srini
12:10
ok I got it But this speaker has 2 woofers so will it overcome the problem. How will be the vocals clarity because I love to hear slow romantic songs but I have observed at little high volumes the vocals starts to dominate so can u just explain me about it. |
SUB_BOSS
Gesperrt |
13:05
hi srini, vocals will definately be good as the 6 1/2 inch drivers are inherently more biased towards mids.it is not like you have a made a wrong buy.yes it is a good choice. But never be in the assumption that the double woofers will give you good bass, i've heard that Cadence can kick the ass out of JBL northridge with twin 10inch woofers.Since you listen to romantic music which are dominated by vocals I feel this will serve your purpose.My understanding is HT speakers are quite peaky with vocals and Stereo speakers are wider in range.but pure stereo is a very expensive affair.you could've tried ONKYO SKF 202( not available but some dealers stock it). It has 8 inch LF drivers and a very good speaker system for stereo. [Beitrag von SUB_BOSS am 20. Jan 2005, 13:14 bearbeitet] |
Srini
13:14
thank u Sub Boss for ur reply. If I need to connect a subwoofer to the Nad 320BEE amp is it possible. Usually the stereo amp have only two outputs so is there any possibility. |
SUB_BOSS
Gesperrt |
13:21
there is really no necessity that you need a sub to boost bass, it has plenty of it. What i meant was you can never get too close to low frequencies and I'm reffering to below 40hz. You have chosen a very good amp.Congrats on your purchase and enjoy the beautiful combo NAD+ONKYO. P.S . where did you buy the amp and how much did u pay. |
SUB_BOSS
Gesperrt |
14:50
ops sorry you r buying from US.I wanted to know if there is any diffrence in specs.i mean between Asian and US models...coz i've seen some diffrences in other brands. |
Hemanth
16:29
Nad 320bee specs for US +++++++++++++++++++++++++++++++++++++++++++++++++ SPECIFICATIONS - NAD C 320BEE Pre-Amp Section Line level inputs Input impedance (R+C) 200k ohm / 320pF Input sensitivity; rated power 220mV Frequency response (-3dB 3Hz - 70kHz) ±0.3dB Line level outputs Output impedance 80 ohm Tape Source Z + 1k ohm Phones 220 ohm Signal/noise ratio 106dB Tone controls Treble 5dB at 10kHz Bass 8dB at 100Hz Remote Control Yes Power Amp Section Continuous output power 50W (17dBW) Rated distortion (THD 20Hz-20kHz) 0.03% Clipping power 68W (18dBW) IHF dynamic headroom at 8 ohm +3.4dB IHF dynamic power at 8 ohm 110W (20.41dBW) IHF dynamic power at 4 ohm 160W (22.04dBW) IHF dynamic power at 2 ohm 210W (23.2dBW) Damping factor (ref. 8 ohm, 50Hz) >60 Input impedance 20kohm/ 470pF Input sensitivity (for rated power into 8 ohm) 630mA Voltage gain 29dB Frequency response; 20Hz-20kHz +/-0.3dB -3dB at: 3Hz/70kHz Signal/noise ratio; ref 1W 100dB Signal/noise ratio; ref rated power 117dB Physical Specifications Dimensions (W x H x D) 171/8 x 315/16 x 117/16" (435 x 100 x 290mm) Net weight 14.33 lbs (6.5kg) Shipping weight 16.98 lbs (7.7kg) +++++++++++++++++++++++++++++++++++++++++++++++++ 2 x 50W Minimum Continuous Power into 4 / 8 ohms 110W, 160W, 210W, IHF Dynamic power into 8, 4 and 2 ohms, respectively PowerDriveTM amplifier technology Headphones socket Relay Input Switching High Current HolmgrenTM Toroidal Power Transformer 7 Line inputs, including two tape in/outs All discrete circuitry Short signal path from input to output All sockets Gold Plated Bass and Treble controls with Tone Defeat switch Main-amp Input & Pre-amp Output NAD Soft ClippingTM IR Input & Output 12V Trigger Output Full System Remote control including Stand-by/Off |
SPEAKER HELP MetalDave am 26.06.2005 – Letzte Antwort am 26.06.2005 – 6 Beiträge |
Speaker for Onkyo tx-nr900:Bangalore manishk13 am 24.01.2005 – Letzte Antwort am 25.01.2005 – 3 Beiträge |
Bright amp with which speaker. Alymangy am 02.02.2005 – Letzte Antwort am 02.02.2005 – 12 Beiträge |
Which speaker to pair Marantz PM17 + CD7300 - Decision made :) bharathana am 23.08.2007 – Letzte Antwort am 27.10.2007 – 34 Beiträge |
Speaker opinion vcs am 27.03.2006 – Letzte Antwort am 27.03.2006 – 12 Beiträge |
Newbie speaker audition Ananth am 06.02.2007 – Letzte Antwort am 11.02.2007 – 12 Beiträge |
Speaker Help txs_dude am 22.02.2004 – Letzte Antwort am 23.02.2004 – 3 Beiträge |
Suggestions Speaker stands and Subwoofer kvish am 09.09.2006 – Letzte Antwort am 20.09.2006 – 21 Beiträge |
Speaker Design & Building What Is It All About ? jsa_ind am 21.08.2005 – Letzte Antwort am 02.11.2005 – 125 Beiträge |
What Cables to use ?? abhi.pani am 19.01.2005 – Letzte Antwort am 19.01.2005 – 6 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 7 )
- Neuestes Mitgliedeunicen907643281
- Gesamtzahl an Themen1.558.305
- Gesamtzahl an Beiträgen21.699.365
