HIFI-FORUM » English » Stereo (Engl.) » Athena AS-F2 spekakers help | |
Athena AS-F2 spekakers help+A -A |
Sam2005_1980
#1 erstellt: 21. Jun 2005, 15:43 | |||||||
Hi, Thanks for your inputs to my previous post, I just bought a pair of Athena AS-F2 speakers and Harmon-Kardon HK3480 receiver(I think its good enough to drive them). Now I have, 1- A custom made notebook (I made it myself!) 2- 2 Athena AS-F2 speakers and 3- Harmon-Kardon HK3480 receiver(I think its good enough to drive them) The specs of the system: Notebook --------- Very stylish (Silver, Black) 15" Display AMD Athlon XP 2600+ CPU 60GB HDD 512MB DDR RAM 64 MB ATI Radeon graphics Multiformat DVD writer 4 USB 2.0 Ports TV-Out Firewire LAN Avermedia PCMCIA tv tuner card (I use this for recording tv programs) Average stereo sound card, only one output, where I connect my headphones for now -------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------- Receiver HK3480 ---------------- Amplification: Continuous power (FTC): 120 Watts per channel, 20Hz - 20kHz @ <0.07% THD Input sensitivity/impedance linear (high-level): 200mV/47k Ohms Signal/noise ratio (IHF-A) 95dB Frequency response at 1W +0dB,-3dB;10Hz - 110kHz High instantaneous current capability (HCC) ±45 Amps Transient intermodulation distortion (TIM) Unmeasurable Rise time 16 µsec Slew rate 40V/µsec FM Tuner Frequency range 87.5 - 108MHz Usable sensitivity (IHF) 1.12 µV/13.5dBf Signal/noise ratio (Mono/Stereo) 73/72dB Distortion (Mono/Stereo) 0.3%/0.4% IF rejection >80dB General: Power requirement AC 120V/60Hz -------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------- Speakers - Athena AS-F2 ----------------------- Tweeter: 1" Teteron Dome Magnetically Shielded Impedance: 8 ohms compatible Woofer: Dual 8" Injection Molded Polypropylene with Rubber Surround Magnetically Shielded Frequency Response: 35Hz - 20kHz +/- 3 dB Power Handling: 250 watts per channel Sensitivity: 93dB -------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------- I am a newbie, so please don't laugh at my questions, here they are 1- How do I connect my notebook to HK3480, what cable to buy? It is a simple stereo sound card, but I can buy creative audigy2 nx usb sound card, if its really needed. 2- How should I connect my receiver to speakers, I am thinking of buying 16 gauge cables from radioshack, will that be good, I am not sure about this, need you help, also about the connecters 3- What else do I need, I am not using any surge protector now, do I need to buy one, is yes are there any specs/brands? I do not have any cables, or power supply, have to buy everything I would appreciate any help on it. Thanks Sam |
benkenobi
#2 erstellt: 21. Jun 2005, 17:27 | |||||||
Congrats Sam...awesome speakers..and an equaly good receiver.. 1> u need to buy the best sound card that u can afford.. 2>Buy a digital coaxial cable..(i think the H/K has a digital input) i would suggest either of the folowing a>Bettercables.com b>Blue Jeans cable(do a google search)(go for one with canare connectors. 3> As for speaker cables..i would personally go for ordinary zip cord..but if buying branded cables makes u feel good then go for it..but keep it under limits..Don't go spending more than 50$ intotal(that itself is too much if u should ask me)..and for connectors buy a a couple of pairs of bananas from partsexpress or from partsconnexion.com(check this up and let u know) Cheers, Sachi p.s: regarding the power surge protector...a basic one would do as u guys have les problems to deal with when it comes to power quality.. |
benkenobi
#3 erstellt: 21. Jun 2005, 17:29 | |||||||
nobody is going to laugh at anyone's questions...believe me, i too am still learning things and consider myself a noob too..so chill and ask away without any second thoughts.. |
Arj
#4 erstellt: 21. Jun 2005, 17:35 | |||||||
1. U need a Converter from a 3inch Audio Jack to RCA. Ideally this http://www.amazon.co...electronics&n=172544 OR http://www.amazon.co.../102-9338090-2199363 Or else a Y adapter and 2 Interconnects (would suggest a longer version of the above) 2. Buy any good speaker cables with banana Pins. 12-14 gauge will do you very good. better to avaoid Bare wire from a pure maint point of view Since u like to make it yourselves, buy the cable and buy 4 banana plugs and put them together 3. Since your Laptop to Amp and Amp to Speaker connections are done. just relax and stop worrying about anything else and enjoy the music. And if anyone tells you to use a power conditioner / better cables or even a dedicatee CD Player. just ignore them. If you are enjoying your music that is good enough... And that can continue untill u get the itch and want to improve the sound..and when that has happened you have anyway come on to the dark side and no one would be able to salvage you after that [Beitrag von Arj am 21. Jun 2005, 17:37 bearbeitet] |
benkenobi
#5 erstellt: 21. Jun 2005, 17:56 | |||||||
That is what i used for my system for over 3 years and had no problems whatsoever..and i used a local make...paid 35 rupees
Like i said its a personal choice and a psychological one...i would settle for zip cord(12-14gauge) Just remember to keep them as short as posssible.
True..but i think u could go any buy a better soundcard(but i understand that it would be too costly for a laptop...not that u can't have fun with the standard ones...i know i did, with my 35 buck stereo jack to 2 RCA cable.
That's true, the upgrade bug has bitten me so badly that i am gunning for a triamped active system... Cheers, Sachi |
Sam2005_1980
#6 erstellt: 21. Jun 2005, 20:07 | |||||||
thanks a lot guys! so now i am buying 1- stereo jack to 2 RCA cable 2- a basic power surge protector 3- 4 banana plugs i think i should be able to get all the above stuff at Radioshack. I will buy above stuff first, then later on probably buy a better sound card, i would have to throw only stereo jack to 2 RCA cable, and buy a digital coaxial cable. I think i have only option with sound card as i can use an external card, creative audigy2 nx usb, is there any other external sound card which is better than audigy2 nx? Also I am still not sure about the speaker cable, would i be able to use 12 gauge speaker cable. I came across this forum on net, found this excerpt --------------------- --------------------- What is the deal with big big speaker wire?? You put big 12 guage speaker wire on it when the power cable for the whole system is only 14-16 guage. I havent ever seen bigger than 12 guage on an ac power cord, i think how can there be more current coming out than whats going in? --------------------- --------------------- Does it mean, if i am putting in 12 gauge cables, then i also would have to have a thicker power cable? Please advice which speaker cable should i buy? I agree now that my earlier choice, 16 gauge would be a bit thin, but what else do i have to do (about power cables, etc ) so that 12 gauge cable would actually be used? Sam |
Arj
#7 erstellt: 21. Jun 2005, 21:39 | |||||||
Speaker cable and power cables have no relation to each other. go with 12 Gauge since it is globally acepted to be pretty good and you should have no problems with it..although i do not see why 16 gauge would not be good either. and forget about powerchords untill the bug bites you hard and you have upgraded your amp,speakers and have got a dedicated cdp.... [Beitrag von Arj am 21. Jun 2005, 21:40 bearbeitet] |
Sam2005_1980
#8 erstellt: 22. Jun 2005, 21:17 | |||||||
thanks a lot guys!!! for all the help. Got all my queries solved, i am still waiting for reciever to arrive, probably hook up all the things this weekend, and will listen to my first real audio system. |
Narrowed to 2! (Paradigm & Athena) Virgil am 19.07.2005 – Letzte Antwort am 26.07.2005 – 3 Beiträge |
Got a quotation for Athena & Mirage abhi.pani am 28.07.2005 – Letzte Antwort am 28.07.2005 – 5 Beiträge |
Help!!!!!!!!!!!!!!!! neckie am 16.09.2005 – Letzte Antwort am 21.09.2005 – 20 Beiträge |
SPEAKER HELP MetalDave am 26.06.2005 – Letzte Antwort am 26.06.2005 – 6 Beiträge |
Help! mmx_2 am 27.12.2004 – Letzte Antwort am 29.12.2004 – 12 Beiträge |
Help!!!!!!!!!!!!!!!! neckie am 15.04.2005 – Letzte Antwort am 15.04.2005 – 3 Beiträge |
Stereo help! Ironpants am 23.05.2005 – Letzte Antwort am 23.05.2005 – 2 Beiträge |
Help with DAC cww504 am 25.07.2004 – Letzte Antwort am 26.07.2004 – 2 Beiträge |
help needed - floorstanding speaker Sam2005_1980 am 08.06.2005 – Letzte Antwort am 17.06.2005 – 7 Beiträge |
Audition Experience: Help purnendu am 02.05.2011 – Letzte Antwort am 24.05.2011 – 24 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.479 ( Heute: 2 )
- Neuestes Mitgliedjuli7994292
- Gesamtzahl an Themen1.558.317
- Gesamtzahl an Beiträgen21.699.604
