HIFI-FORUM » English » Stereo (Engl.) » Yamaha RX-V450+Bose AM5 - Setup Help Req | |
Yamaha RX-V450+Bose AM5 - Setup Help Req+A -A |
Nitin
14:58
erstellt: 27. Nov 2005, |
Hi all I am new Mumbai based member of this forum & also new to audio world I recently purchased Yamaha RX-V450 with Bose AM5 speakers & plan to have a 5.1 system in stages I have certain Queries on the subject : 1. Need help on positioning the Sats & subs to improve sound The product manual has limited information. My current placement of sats is 3 ft apart, 1 ft away from wall on a TV set, Sub on Gr level in a corner facing wall.Room size 15 X 12 ft 2. The cables provided with Bose AM5 are simple cables would it really help in going in for better cables & connectors. Where can I buy these in Mumbai. Budgets would be Rs 1K max. I have checked with Sanen Aucos. at Mulund they have cables at Rs 20-30 per mtr, is it a good option 3. The connection to speakers is 2 pair of cables Frt-L&R from Amp which get into sub module and sats get connected from sub. In such case I am unable to select the 3 channel output (Frt L&R + Centre) available from amp. Will such selection give better sound ?? Please suggest. Thanks in advance |
Arj
15:29
Hi Nitin, I have a similiar setup but with Bose AM3 and an Onkyo. Since the coverage of Voice in the AM5 os not very good, I would either suggest the VCS10 center speaker and any matching surrounds if you want an all bose setup OR you can think of the Wharfedale WH2 center and dipole speaker pair..they match quite well for sensitivity. Regarding cables would suggest retaining the Bose cables. i did upgrade to slightly expensice QED flatwire..but there is not much diference. What could make a differen is a SUB as the bassmodule does not go low enough. |
milpai
00:49
erstellt: 28. Nov 2005, |
Wow, this thread reminded me of my system in India - Bose Am5 II + Yammy Stereo amp. Need to sell it, the next time I come there. It is lying as such in my home, since my parents do not use it much. BTW, who is the Bose dealer in Mumbai now? Way back in 1994 they were located in Dadar, but closed shop except for servicing and moved to Delhi. |
Nitin
05:33
Bose has opened their stores in India The ones at Mumbai are at Cross Roads Mall-HajiAli and Inrorbit Mall-Malad. They also exist at DEL, CHN, BLR, AHMD Details available on Url :http://www.boseindia.com/ |
Arj
08:46
regarding positioning.. keep it around 2m-3 from theTV and such that the two speakers, and the center channel forms an Arc with you as the center. place the acoustimass inthe corner which has 2 solid walls, with the woofer pointing to the front. Regarding the center channel speaker, since you do not have one, you cannot use the output. you will have to play the receiver in the 2.1 dolby mode or stereo mode (varies from receiver to receiver). Whenever you upgrade, get the center channel as in a 5.1 setup that actually playes 60-75% of all sound ! hence is more important than the main speakers also ! |
Help!!!!!!!!!!!!!!!! neckie am 16.09.2005 – Letzte Antwort am 21.09.2005 – 20 Beiträge |
Help needed!! neckie am 21.03.2005 – Letzte Antwort am 23.03.2005 – 30 Beiträge |
Help! mmx_2 am 27.12.2004 – Letzte Antwort am 29.12.2004 – 12 Beiträge |
Help!!!!!!!!!!!!!!!! neckie am 15.04.2005 – Letzte Antwort am 15.04.2005 – 3 Beiträge |
SPEAKER HELP MetalDave am 26.06.2005 – Letzte Antwort am 26.06.2005 – 6 Beiträge |
Help needed in selecting Equilisers neckie am 17.02.2005 – Letzte Antwort am 21.02.2005 – 12 Beiträge |
Help Required -Startup Hi Fi Anand.Patil am 28.03.2005 – Letzte Antwort am 30.03.2005 – 16 Beiträge |
help needed - floorstanding speaker Sam2005_1980 am 08.06.2005 – Letzte Antwort am 17.06.2005 – 7 Beiträge |
Digital Cable Help Arj am 24.03.2009 – Letzte Antwort am 30.03.2009 – 19 Beiträge |
Budget amp and speakers. Help!! Psycholic am 30.06.2005 – Letzte Antwort am 30.06.2005 – 8 Beiträge |
2005
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder928.520 ( Heute: 5 )
- Neuestes Mitgliedrk57
- Gesamtzahl an Themen1.558.393
- Gesamtzahl an Beiträgen21.701.385
