Good installer for HT System !
buxx11
#1 erstellt: 21. Jul 2007, 07:34
i just got a marantz sr4001 reciever and Mission M34i+Centre & surrounds for myself from S'pore.
I would like to know if anyone knows abt a Pro who can install this system for me..the wiring, banana plugs etc..
I live in east delhi.
Plz its urgent!!!
[Beitrag von buxx11 am 21. Jul 2007, 07:37 bearbeitet]
SDhawan
#2 erstellt: 22. Jul 2007, 18:54
Dear Buxx !!!
You may contact Sharda Pro-Acoustics S-block Panchsheel Park and these guy will be able to help you with the setup.
Or invite us over for dinner - Viren, Kamal, Rahul, Sunilyo, me, etc. and we may be able to "help" you
buxx11
#3 erstellt: 23. Jul 2007, 04:38
@sdhawan:Thx for the offer!Tho i managed to install it myself with the help of the local electrician!! Just had to use the wire cutter & splicer to put teh 20AWG OFC Spkr cable into the banana plugs. Connecting the Speakers,DVD Player,STB to the AVR was tedious but not difficult.Took me 3 long hrs-but i managed to get everything up & running..
SDhawan
#4 erstellt: 23. Jul 2007, 09:56
Great !
Now you must run the setup of the AVR while sitting in the listening position.
buxx11
#5 erstellt: 23. Jul 2007, 13:08
i hav tried to setup the dB levels of the speakers as best i could, but the test noise from the Front Left channel sounds very different from all the others!!
Wud u know whether teh SR4001 can upconvert Composite-> Component??
how much break-in do these spkrs need anyways?
SDhawan
#6 erstellt: 23. Jul 2007, 16:39
I have SR-4500 and it cannot up-convert composite to component. I think it doesn't anything to the video signal at all except for switching.
For setting up dB, you just need to match the sound level from all speakers at your listening position. The characte of the tone produced will differ with the type of speaker and is especially very different from the sub.
I don't know how much is the optimal breakin time - just keep playing & enjoying.
I strongly recommend that you buy these DVDs for the thrills:
-Gladiator
-Hero (English - actually Chinese)
-Pearl Harbor
-Saving Private Ryan
-Lord of Rings
-iRobots
-Finding Nemo
buxx11
#7 erstellt: 13. Aug 2007, 04:02
just one more question for u sanjay!
wat shud i set the LPF/HPF setting in the SR4001 to? its at 100Hz now.It has a option for 80Hz also.
I hav no sub, and the M34i r rated 44Hz-20Khz. The centre is 80Hz-20Khz, and the Rear Surrounds at 110Hz-20Khz.
i set up the AVR at 80Hz once and once during a movie; "The Hills have eyes" the AVR went into "Protect" mode.. Tho there was a problem in my APC inverter at that time.. i changed it bac to 100Hz after that incident..
here's a pic of my setup!
SDhawan
#8 erstellt: 16. Aug 2007, 16:50
Hi !
Sorry I looked at this post only today.
If you do not have a Sub then (perhaps) the LPF/HPF setting has no role to play - because it normally decide the frequency level below which the signal is sent to the Sub.
You should set your Sub=No (or absent), the left, right & center speaker and large and the surrounds as small. If you hear distortion from the center then set it to small as well.
Let me know the result.
And I don't think it's a good idea running your system through inverter - it would introduce a lot of electrical noise. Instead use a good transformer.
[Beitrag von SDhawan am 16. Aug 2007, 16:54 bearbeitet]
buxx11
#9 erstellt: 17. Aug 2007, 14:43
hi !
thx for replying !
I emailed Marantz abt it & they said to keep it at 100Hz & thats wat i hav done now..
I dont run my HT setup thro the Inverter- there was a spike or something in the mains supply that may hav contributed to the AVR going into "protect" mode or maybe the volume was just too high or something.. hasnt happened since.. Thank god !
P.S: Any good surge protector/powerstrip that u can recommend?
Am using a "MX" brand powerstrip as of now..
Or maybe i shud just use a Voltage stabiliser ?
SDhawan
#10 erstellt: 17. Aug 2007, 16:30
Hi !
Make sure the speaker wiring is not getting short anywhere. That can lead to AVR going into protect mode.
Looking for a good Sub
Harmon_Bro am 10.05.2005  –  Letzte Antwort am 10.05.2005  –  2 Beiträge
Speakers for HT
neono am 08.07.2006  –  Letzte Antwort am 08.07.2006  –  2 Beiträge
HT for 40k! Seperates! Can nyone help!
Edges am 28.06.2005  –  Letzte Antwort am 30.06.2005  –  27 Beiträge
5.x vs. 7.x for HT
hsmraj am 24.06.2005  –  Letzte Antwort am 29.06.2005  –  12 Beiträge
HT solution
phreek am 04.08.2005  –  Letzte Antwort am 14.08.2005  –  6 Beiträge
Help with HT
amber.jalan am 11.06.2007  –  Letzte Antwort am 03.07.2007  –  21 Beiträge
Home Theatre system in India
Vandana am 01.11.2005  –  Letzte Antwort am 13.01.2006  –  3 Beiträge
Looking for Speakers for Yamaha RX-V459
Nishikant am 08.06.2007  –  Letzte Antwort am 20.06.2007  –  7 Beiträge
New HT
linkitz am 07.01.2006  –  Letzte Antwort am 11.01.2006  –  2 Beiträge
5.1 sound for 30K
rshri am 07.02.2006  –  Letzte Antwort am 02.03.2006  –  39 Beiträge
2007
  • Registrierte Mitglieder928.479 ( Heute: 3 )
  • Neuestes MitgliedLsx6419246
  • Gesamtzahl an Themen1.558.298
  • Gesamtzahl an Beiträgen21.699.222
