FLAC
neono
#1 erstellt: 10. Feb 2007, 17:57
Will a FLAC encoded track play in a normal DVD/CD player?
Kamal
#2 erstellt: 10. Feb 2007, 18:01
Yep it will-when you burn a Flac encoded album onto a CDR,
it gets converted into the format that normal CD's use.
Check out wikipedia for more info-
neono
#3 erstellt: 10. Feb 2007, 18:14
Does that mean we can accomodate more than 60minutes of songs on a CD?
Amp_Nut
#4 erstellt: 10. Feb 2007, 18:33
A regular CD anyway has the capacity to store about 74 minutes of music.
If you fill a CD with MP-3 files, it will play ( on an mp-3 player for over 10 hours ! ( depending on the mp-3 compression choosen )
zhopudey
#5 erstellt: 10. Feb 2007, 18:58
If you burn the FLAC tracks as a data disc, it will NOT play on a CD player.
Kamal
#6 erstellt: 11. Feb 2007, 06:45
Well, obviously!
When you burn the files onto a CDR you would choose to burn them as an audio cd, wouldn't you?
FLAC is merely a "lossless" way of compresing music off a CD to facilitate ease of transmission over the net-sorta works like winzip does for data files;the Flac file which gets reconverted into the .cda format while burning onto a CDR, is bit for bit, identical to the original CD.
If your CD/DVD player can handle CDR's, it'll play.
Neutral
#7 erstellt: 11. Feb 2007, 07:35
Note that Flac, unlike a zip file, will play back on Winamp using a plugin. So you can use a computer as a source for your amp.
neono
#8 erstellt: 11. Feb 2007, 10:39
Understood...i was wondering how would a flac file on cd[as data cd]play on a regular dvd player... .
Neutral
#9 erstellt: 11. Feb 2007, 13:54
There actually exist a few players / portables that can play the Flac format as well. If you are buying a new player, then search one out (using the internet) that will natively play Flac.
I find DVD players pretty stupid. They can't even play a simple wav file (obtained from backing up an audio CD on a computer)
reignofchaos
#10 erstellt: 11. Feb 2007, 21:32
I find DVD players pretty stupid. They can't even play a simple wav file (obtained from backing up an audio CD on a computer) :(
Philips DVD players do play most formats without a hitch including mp3 and wav. FLAC... I'm not sure if any dvd player supports it. The only devices I know that natively plays FLAC are the Squeezebox and its bigger brother the Transporter.
Audio quality difference between DVD player and CD player
sandipb am 16.11.2007  –  Letzte Antwort am 17.11.2007  –  2 Beiträge
DVD player power supplies
Manek am 31.07.2006  –  Letzte Antwort am 04.08.2006  –  14 Beiträge
Using blue ray player as a high rez transport
Manek am 11.02.2012  –  Letzte Antwort am 21.03.2012  –  23 Beiträge
Need suggestions for Tuner/CD system
SUNILYO am 15.04.2008  –  Letzte Antwort am 23.04.2008  –  21 Beiträge
Comparison of modern graphics card to hardware DVD players for DVD decoding
reignofchaos am 03.09.2006  –  Letzte Antwort am 04.09.2006  –  6 Beiträge
Multimedia storage and playback (audio, vcd, dvd)
Manek am 27.06.2010  –  Letzte Antwort am 28.06.2010  –  5 Beiträge
The curse of DVD region encoding
sandipb am 14.11.2007  –  Letzte Antwort am 15.11.2007  –  8 Beiträge
Help in Selection Of the Right System
Menon am 10.09.2005  –  Letzte Antwort am 03.10.2005  –  3 Beiträge
Need good pic quality portable DVD player from Bangalore
Sonic_Master am 17.07.2005  –  Letzte Antwort am 07.10.2005  –  6 Beiträge
moser baer cdr's
Manek am 08.01.2009  –  Letzte Antwort am 09.01.2009  –  5 Beiträge
2007
  • Registrierte Mitglieder928.520 ( Heute: 3 )
  • Neuestes Mitgliedtusahivasat
  • Gesamtzahl an Themen1.558.364
  • Gesamtzahl an Beiträgen21.700.806
