HIFI-FORUM » English » Offtopic (Engl.) » Installing External Hard Disk | |
Installing External Hard Disk+A -A |
SUNILYO
08:15
erstellt: 25. Aug 2006, |
Hi everyone, I have bought an external 3.5" IDE hard disk casing (USB based) for data transfers between my office and home PC. I am using the Samsung 80GB HDD (IDE) as the drive for this purposse. The problem is i am not able to install the proper drivers for it. I have tried everything that came with the supplied installation CD but it doent work. My PC recognizes the device as USB mass storage device but thats it. In the driver section of the device it displays "The driver for this device is not properly installed." My PC (office) config is P3-1.2MHZ, 256MB, 40GB My PC (home) config is Celeron 533 MHZ, 128MB, 10GB+80GB(planning to use as the external drive). What could be the problem? please help. [Beitrag von SUNILYO am 25. Aug 2006, 08:20 bearbeitet] |
stonedsufi
08:44
XP will not need any drivers. But if your pc is showing that a mass storage device is connected then go to my computer and see if the drive is reflected there... as drive D,E or any of the subsequent alphabets depending on how many have been already used up. if it is reflected then all you have to do is start transfering stuff... another thing.. there is a jumper setting(master or slave) that may have been specified by the casing manufacturers. have you followed it? for an understanding of the same you could go to ![]() see if the above mentioned helps otherwise will think of something else..... |
SUNILYO
09:08
It worked. it was the jumper setting was the culprit. Actually when i removed the HDD from my home by change i also removed the jumper. But after putting the jumper on the master pins it worked. Thanks stonedsufi. |
external dvd writer gbharani am 12.02.2007 – Letzte Antwort am 26.02.2007 – 22 Beiträge |
Great site! Forum newbie here paj4x4 am 21.01.2007 – Letzte Antwort am 21.01.2007 – 3 Beiträge |
Coming to Mumbai soulforged am 08.01.2007 – Letzte Antwort am 09.01.2007 – 5 Beiträge |
ADVANCE ACOUSTIC - NOW WITH SOUND & VISION SNV am 31.08.2011 – Letzte Antwort am 03.09.2011 – 7 Beiträge |
2006
- Registrierte Mitglieder928.520 ( Heute: 1 )
- Neuestes MitgliedDzxlasJem
- Gesamtzahl an Themen1.558.388
- Gesamtzahl an Beiträgen21.701.239
