HIFI-FORUM » Stereo » Elektronik » Röhrengeräte » Röhrenverstäreker für Anfänger gesucht! | |
Röhrenverstäreker für Anfänger gesucht!+A -A |
nik13nakone
#1 erstellt: 06. Mrz 2017, 00:52 | |||
Bitte kann jemand helfen? Ich habe 3 Favoriten, aber weiß nicht welcher ist der Richtige? LS Infinity MS155, Wirkungsgrad 102 Über eure Meinung würde ich mich sehr freuen! Danke! 1. Music Angel MENG EL34 x 4 MINI L3 Vacuum Valve Hi-end Tube Integrated Amplifier 397€ Item Specifics Type :Integrated Amplifiers Input Power :110V-240V AVAILABLE Output Power :35W x 2 Class A Push Pull circuit design Output Tube :EL34x 4 Frequency :10Hz-70KHz Driver Tube :6N2 x 2 Signal/Noise Ratio :90dB Distortion :Less than 1% at full power Input Consumption :< 100w Ohms :4 ohms and 8 ohms Input Jack :2 groups Size Dimension :Width 285mm x Height 165mm x Depth 325mm Colour :Black Body Weight :15 kg Packing Includes :All the Tubes 2.YAQIN MS-34C BLABK EL34B x2 Tube Headphone & Integrated Amplifier 110v-240v D 504€ Input Power : 110V-240V AVAILABLE Output Power : Single Ended EL34 Class A Pentode Output Power 10.5W X 2 (4 or 8 ohms) Valve / Tube : EL34B x 2 / Octal 6SN7 X 2 Equal Loudness : 10KHz/1KHz(+8dB) Frequency : 6Hz to 38KHz(-2dB) Distortion : <=1.8% Signal/Noise Ratio : 73dB(A) Earphone Output : Earphone Optimum Output Impedance 32 ohms Audio Input : 3 group Input Sensitivity : 180mV(1K) Size Dimension : Width 11.42 inches x Height 6.3 inches x Lenght 9.45 inches Colour : BLACK Weight : 17.5 kg Packing Includes : All The tubes, 1.5m Power Cord & Full function aluminum remote control 3. Musical Paradise 400€ Model MP-301 MK3 Tubes (Default) 6L6 (6P3P) x 2, 6J8P x 2 Tubes (Optional) EL34 x 2, 6550 x 2 Topology Class-A Single Ended Output Power (RMS) 6.5W x 2 (Speaker) 2W x 2 (Headphone) Output impedance 4Ω- 8Ω(Speaker), 32Ω-600Ω(Headphone) Frequency Response 15Hz - 30Khz T.H.D <=1% (1Khz) S.N.R 88db AC Input 100-120V / 220-240V 50-60Hz Worldwide Use Weight 10KG Dimension (W 20CM x L 26CM x H 16CM) Warranty 1 Year Limited (One month for tubes) Tube Replacement Guide: 6J8P EL34 |
Anro1
#2 erstellt: 06. Mrz 2017, 13:16 | |||
Hallo zu der Angabe 102db/W/m bei den Lautsprechern hätte ich jetzt so meine Bedenken, aber egal die 3 von Dir ausgesuchten Röhrenverstärker Kaufideen machen sicher alle 3 ordentlich Musik an den Teilchen. Der Music Angel EL34 PP wäre meine Wahl auch wegen dem besten Geräuschspannungsabstand, die beiden anderen gehen aber sicher auch recht ordentlich, wobei man bei den vermeindlichen 102dB/W/m schon auf Brumm/Rausch achten sollte. Am besten wäre die Geräte auszuleihen zu Hause antesten. Grüsse und viel Spass und Freude bei der Auswahl und dem Musikhören. [Beitrag von Anro1 am 06. Mrz 2017, 13:17 bearbeitet] |
nik13nakone
#3 erstellt: 06. Mrz 2017, 21:49 | |||
Danke Anro! Auszuleihen wehre gute Idee, leider keiner im Bekanntenkreis hat solche Geräte und die Verkäufer sind sehr weit))) |
vegatronic
#4 erstellt: 07. Mrz 2017, 17:36 | |||
Hallo, schau mal unter https://www.destiny-audio.com, Herr Langer ist bekanntermaßen sehr freundlich und zuvorkommend und hilft auch bei Problemen - das ist viel wert. Gruß Thomas |
PeHaJoPe
#5 erstellt: 10. Mrz 2017, 12:05 | |||
Moin, ich bin der Meinung, daß es keine Audio-Geräte für Anfänger gibt, außer man will selber bauen. In Etwa kann man(n/Frau) schon in einem guten HiFi Fachgeschäft raushören ob man lieber mit Sand oder Röhren hören möchte und dann auch zw. Geräten der unteren, mittel oder oberen Preisklase. Wenn ein Guter Berater einem hilft spart man evtl viel, viel Kohle. Natürlich ist es auch eine persönliche finanzielle Entscheidung, aber ein gutes Nichtröhrengerät kann und ist genauso teuer wie ein teures gut oder schlechtes Röhrengerät. Aber da gehen die Meinungen wohl weit auseinander. Auf jeden Fall ist das Leben viel zu kurz um schlecht Musik zu hören. (Klugscheisser modus aus) |
MrJones4470
#6 erstellt: 10. Mrz 2017, 12:17 | |||
Den Satz muss man jetzt nicht wirklich verstehen oder? [Beitrag von MrJones4470 am 10. Mrz 2017, 13:43 bearbeitet] |
Yahoohu
#7 erstellt: 10. Mrz 2017, 18:22 | |||
Hallo nik13nakone, ich denke, Du meinst die Infinity SM155, oder? Trotz des hohen Wirkungsgrades würde ich diese Lautsprecher mit keinem der von Dir genannten Röhrenverstärkern betreiben. Zu den Infinitys passen Transistorverstärker einfach besser. Eine alternative wären Hybride (Röhrenvorstufe und Transistorendstufen), da gibt es einige mit netter Optik. Weitere Gründe: Du importierst selber aus China. Will heissen, auf Dich kommen auch noch Zollgebühren und die Einfuhrumsatzsteuer zu. Da haben schon einige bei der zuständigen Abholstelle dumm geguckt. Wenn auf dem Transport irgend etwas in die Hose geht, fangen die Umstände an: Wer war´s, wer zahlt die Rückfracht, etc. Den ganzen zeitlichen Aspekt mal aussen vor. Kann gutgehen, muss aber nicht. Im übrigen: Von den drei Verstärkern kannst Du den Yaqin und den Musical Paradise knicken, einfach zu wenig Leistung. Bei Ebay, bzw. Ebay Kleinanzeigen gibt es auch immer wieder mal gute gebrauchte Verstärker, seien es Röhren- oder Transistorgeräte. Hinfahren, selber ansehen und anhören (und bei Röhren immer auf Brummen achten). Beste Grüße - Yahoohu |
nik13nakone
#8 erstellt: 10. Mrz 2017, 20:16 | |||
Ja, ich habe selbst 10 mal gelesen))))) Vielen Dank für eure Meinungen! Es stimmt, natürlich SM155 Ich überlege noch wie ich weitergehe... |
nik13nakone
#9 erstellt: 10. Mrz 2017, 21:19 | |||
Ich plane in diesem Jahr Focal Aria 926 oder Sonus faber Chameleon T erwerben. Die beide habe ich selbst mit viele andere verglichen, aber leder nicht miteinander. Von diese Perspektive soll ich dann ein Röhrenverstärker mit mehr Power suchen? |
Yahoohu
#10 erstellt: 10. Mrz 2017, 22:09 | |||
Wenn es denn unbedingt ein Röhrenverstärker sein muß..... wie sieht es denn mit Deinem maximalen Budget aus? Darf es auch gebraucht sein? |
nadeto
#11 erstellt: 10. Mrz 2017, 22:54 | |||
Cayin Röhrenverstärker kannst du ruhig anschauen, ist In China hochwertig für De produziert. https://cayin.com/produkt-kategorie/vollverstarker/ |
nik13nakone
#12 erstellt: 11. Mrz 2017, 15:34 | |||
Budget bis 1000€ und es darf gebraucht sein. Seit ein Monat habe ich Luxman L-510, im vergleich mit meinem alten NAD C-356BEE er klingt ausgezeichnet! Ich bin sehr zufrieden. Ich weiß nicht warum, aber ich möchte ein Röhrenverstärker Klasse A und Eintakt haben. Vielleicht zu viel Forum gelesen))) Cayin macht aber so wie ich sehe nur AB oder? [Beitrag von nik13nakone am 12. Mrz 2017, 03:22 bearbeitet] |
DB
#13 erstellt: 12. Mrz 2017, 12:35 | |||
Weder Betriebsklasse noch Betriebsart sind als alleiniges Qualitätsmerkmal entscheidend. Wenn Du ein Auto willst, entscheidest Du den Kauf doch sicher auch nicht nach der Anzahl der Radmuttern. MfG DB |
PeHaJoPe
#14 erstellt: 12. Mrz 2017, 15:14 | |||
Ups, das kommt davon wenn man das Geschriebene nicht nochmal prüft.
ja so schnell kann man sinnloses schreiben. Dennoch würde ich heute nicht nochmals den Fehler machen und mir erst was Billiges kaufen um dann irgendwann nach vielem Geldrausschmeißen ein gutes Gerät zu kaufen. Ist hald eine Frage des Wollen haben und können bezahlen. ps: ich hoffe das war veständlicher |
Anfänger Synthifreak am 07.06.2009 – Letzte Antwort am 09.06.2009 – 3 Beiträge |
Billiger Röhrenverstärker für Anfänger Tony-Montana am 04.07.2008 – Letzte Antwort am 04.07.2008 – 8 Beiträge |
Röhrenverstärker für ABSOLUTEN Anfänger Wulgamot am 29.12.2008 – Letzte Antwort am 03.01.2009 – 20 Beiträge |
Röhrenverstärker -Eigenbau für Anfänger DAApisto am 09.06.2013 – Letzte Antwort am 10.01.2014 – 38 Beiträge |
Röhrenverstärker gesucht X4TwS am 25.10.2007 – Letzte Antwort am 07.01.2008 – 26 Beiträge |
Röhren Anfänger tyrub am 28.06.2011 – Letzte Antwort am 05.08.2011 – 112 Beiträge |
röhren-bausatz SE für Anfänger wl am 11.03.2005 – Letzte Antwort am 15.03.2005 – 7 Beiträge |
Röhren-Anfänger sucht Hilfe MengoMan am 25.04.2006 – Letzte Antwort am 27.04.2006 – 5 Beiträge |
Eigenbau Röhre Anfänger riod am 07.05.2006 – Letzte Antwort am 07.05.2006 – 4 Beiträge |
Röhrenverstärker selbstbau (Anfänger) master24680 am 28.08.2006 – Letzte Antwort am 02.09.2006 – 17 Beiträge |
2017
- Lua 4040 c Klang?
- Masse, aber richtig !
- Lua 4040 c Klang?
- Registrierte Mitglieder927.132 ( Heute: 1 )
- Neuestes MitgliedMichael2806
- Gesamtzahl an Themen1.554.879
- Gesamtzahl an Beiträgen21.623.852
