Sony 2023 X90L 55", 65", 75", 85", 98"
Jogitronic
#51 erstellt: 06. Jun 2023, 14:24
HDTV Polska gibt für SDR immerhin 441 Nits als maximale Helligkeit an. Das ist auch für helle Räume mehr als genug.
Shaoran
#52 erstellt: 06. Jun 2023, 16:42
Ist aber viel weniger als mein XE93 von 2017, der schafft bei SDR 800 Nits und mehr
Und an dem messe ich halt alle neuen Modelle.
Und wie gesagt, der X90K vom Vorjahr hat ja auch mehr geschafft, daher ist das ein berechtigter Kritikpunkt
[Beitrag von Shaoran am 06. Jun 2023, 16:43 bearbeitet]
celle
#53 erstellt: 21. Jun 2023, 04:52
Immer wieder erfrischend die Reviews von Rasmus zu lesen
The small increase in dimming zones doesn't improve HDR picture quality compared to previous Sony's 9-series LCD TVs in a substantial way. We continue to observe diffuse blooming around bright objects and a sort of milky effect to the whole picture in many movie sequences where the backlight system appears to get confused about how to balance its zones, even without the TV coming anywhere close to 1200 nits in most real use cases. In addition‚ it delivers subpar color saturation in HDR.
It is a simple concept to understand: Like other VA LCD panels, the VA LCD panel in Sony X90L has a native contrast ratio of around 5000:1 so to hit, for example, 1200 nits in any area of the picture, black depth in the zone area around the object must rise to around 0.25 nits (1200/0.25 ? 5000) – a 10x increase over its already modest black level in calibrated SDR mode – and this affects all other dark shades, too. It is no longer black but grey, and it gets worse when you are no longer sitting in the sweet spot directly in front of the TV. This is why the zone system often scales down its aggressiveness to try to some extent to avoid these effects, in turn significantly limiting peak brightness with real movie/game scenes. In theory, more zones will make the halos appear smaller in size but will make them look more pronounced and intense if brightness is increased further – the very best VA LCD panels hover around 7000:1 in contrast ratio.
Of course, some of these strength translate to content encoded in an HDR format if you are watching scenes bathed in sunlight, a sunny field or sports, but fully illuminated bright scenes really have very little to do with HDR (High Dynamic Range, aka contrast) – you can just crank up brightness in SDR mode to achieve the same effect – and ultimately X90L still does not cross the bar for what we believe is HDR picture quality.
https://www.flatpane...owfull&id=1687261543
Da bleibt aber eben nicht mehr viel Kontrast und Farbsättigung über ...
[Beitrag von celle am 21. Jun 2023, 08:45 bearbeitet]
Shaoran
#54 erstellt: 22. Jun 2023, 10:31
Also ich finde meinen Kontrast und Sättigung vom XE93 super, so gut sah noch nie ein TV aus bei uns und jeder der die letzten Jahr hier mit TV geguckt hat war mehr als begeistert immer
In der Theorie auf dem Papier mag es vielleicht so sein, aber was man selber sieht sieht mega aus, SDR mit 800Nits oder mehr macht mir mehr Spaß als SDR in 200nits, aber dafür auf dem Papier vielleicht bessere Werte
Hab ich ja anhand eines OLED TVs gemerkt den ich kurz davor hatte.
Jogitronic
#55 erstellt: 23. Jun 2023, 19:53
Review von HDTVTest
[Beitrag von Jogitronic am 23. Jun 2023, 19:55 bearbeitet]
Ralf65
#56 erstellt: 24. Jun 2023, 04:00
wie zu erwarten, ein solider Mittelklasse TV, der durch die geringe Anzahl an Dimming Zonen weit hinter seinen Möglichkeiten zurück bleibt und damit sehr viel Potenzial verspielt......
[Beitrag von Ralf65 am 24. Jun 2023, 04:08 bearbeitet]
Jhonny7
#57 erstellt: 24. Jun 2023, 08:50
Hallo Leute. Hat jemand schon dieses Gerät zu hause? Ich habe mir jetzt den x90l in 65 Zoll bestellt und hoffe ich werde es nicht bereuen (Lieferung Mittwoch). Vorab wollte ich fragen ob mir jemand bezüglich der Bildeinstellungen was sagen könnte. Kann man die vom x90k übernehmen? Kalibrieren lassen möchte ich nicht bei den Preisen. Habe leider kaum was finden können im Bezug auf Bildeinstellungen. Denke weil das Gerät relativ neu ist. Danke schon mal an alle
Jogitronic
#58 erstellt: 24. Jun 2023, 09:24
Du kannst die Bildeinstellungen der J- oder K-Serie nehmen, denn Sony hat da in den letzten Jahren nichts geändert.
Hier mal das "Kochrezept" für die OLED, welches das grundsätzliche Setting zeigt. Bei den LCD hast du z.B. noch Einstellungen für Local Dimming, welches man auf Mittel einstellen sollte.
Sonys generelle Bildeinstellungen
Das ist auch nicht erforderlich. Mit den o.g. Einstellungen erhältst du die werkseitige Kalibrierung und das sollte genügen.
Jhonny7
#59 erstellt: 24. Jun 2023, 10:26
Vielen Dank . Werd ich mal direkt Testen wenn das Ding heile ankommt
Jhonny7
#60 erstellt: 24. Jun 2023, 10:47
Übrigens ich habe das Gerät 65x90l für 1148,90€ bekommen mit Versand bei Expert. Is zwar abgelaufen das Angebot aber momentan bei Euronics für 1200€ zu haben.
celle
#61 erstellt: 29. Jun 2023, 06:23
Solltest vielleicht mal den Hersteller wechseln und nicht immer die dunkleren Sony OLED-TVs nehmen.
Ein G3 mit 300nit SDR-Vollflächenhelligkeit, um die 500nits (kalibriert, in deinen bevorzugten Modis geht also noch mehr) APL 50% sollte deinen XE93 durch den viel besseren "Punch" im Bild deutlich hinter sich lassen. Dann merkst du auch wie wichtig Blickwinkelstabilität für den Bildeindruck ist. Den besseren AR-Filter haben die WOLED-TVs ohnehin schon, was schon am Tag mehr Kontrast bedeutet.
Bei 800nits bleicht dein TV in dunklen Szenen komplett aus und das sieht man sofort im Direktvergleich.
Shaoran
#62 erstellt: 29. Jun 2023, 08:35
Ich hatte einen LG OLED davor, keinen Sony
Und für dich mag das so sein, das alles ausbleicht, ich merke das nicht wirklich, ich find selbst auf voller Power dunkle Szenen viel besser als vorher auf dem OLED.
Und das hat sich auch mit aktuellen OLEDs nicht geändert, das sehe ich ja am G2 von meinem Kumpel, der überzeugt mich selbst auf voller Pulle immer noch nicht im Vergleich.
Mag sein das der G3 jetzt mit MLA mich mehr überzeugen könnte, aber es wird immer noch nicht ausreichen damit ich mir einen OLED zulegen würde für meine Befürfnisse, ganz zu schweigen von LG schrecklicher TruMotion Bewegtbilddarstellung.
Und ich habe ja auch nix gegen die OLED Technik an sich, bei meinem Tablet und Smartphone hole ich mir auch nur welche mit OLED Display, aber bei TVs ist diese Technik für mich einfach noch nicht so weit.
Auf dem Papier und Messwerten kann OLED noch so toll sein, wenn aber mein Eindruck nunmal nicht passt, passt es nicht, egal wie viele Leute wie du es mir einreden wollen, sowas kann man ja nunmal nicht ändern
Daher sind diese LCD und OLED Diskussionen immer so unnötig, jeder soll holen was ihm persönlich besser passt und das sollte man auch akzeptieren
Es gibt nunmal nicht DIE eine Technologie die alles besser kann, in meinem Fall wäre OLED aber vielleicht in 20% der Zeit besser, das bringt mir nix.
[Beitrag von Shaoran am 29. Jun 2023, 11:11 bearbeitet]
Jhonny7
#63 erstellt: 29. Jun 2023, 20:05
Ich bräuchte einmal eure Hilfe. Ich bin unschlüssig, welche Schrauben ich bei der Wandhalterung verwenden sollte, die die sich auf der Rückseite des Gerätes abschrauben lassen oder die, die sich in der kleinen Tüte befinden. Die Dinger scheinen mir mit M6 irgendwie unsicher zu sein. Vielleicht bin ich auch nur paranoid. Laut meiner Berechnung lassen sich nämlich diese Schrauben gerade mal mit der Halterung vielleicht 5 mm reinschrauben
Jogitronic
#64 erstellt: 30. Jun 2023, 09:26
Sony X95L Mini LED TV vs X90L FALD LCD in HDR
Jogitronic
#65 erstellt: 01. Jul 2023, 16:51
Jogitronic
#66 erstellt: 07. Jul 2023, 14:33
Jogitronic
#67 erstellt: 15. Jul 2023, 14:30
Ralf65
#68 erstellt: 28. Jul 2023, 04:36
mal als Info zum X90L und da speziell zur 98" Variante,
dem Bericht nach, liefert CSOT (TCL) die 98" Panels für Marken wie Sony, Samsung, TCL, Xiaomi, Changhong und Haier.
Ralf65
#69 erstellt: 30. Jul 2023, 04:26
ein detaillierter Test des X90L in 98" aus China von KEN
Infos aus der Übersetzung:
Die Basis des 98X90L beruht auf dem bekannten MediaTek SoC MT5895, Betriebssystem ist Android TV10.0, RAM 4GB+32GB.
Ausgestattet ist das 98" Modell mit einem Panel von CSOT (TCL) mit FALD Backlight und 128 Dimming Zonen (16 Horizontal, 8 Vertikal)
Das native Kontrast des Panels, gemessen nach ANSI, beträgt 5700:1, mit Local Dimming werden 11000:1 erreicht.
Maximal Helligkeit im Vollbild 500 bis 600 Nits
100%
Maximale Peak Helligkeit im SDR-Modus 900 bis 1000 Nits
SDR
Maximale Peak Helligkeit im HDR-Modus 1100 bis 1200 Nits
HDR
Bei der Wiedergabe der Test Disc mit 1000 Nits gemasterten Inhalten werden alle Details korrekt dargestellt,
1000
bei 2000 Nits gehen bereits einige Details verloren,
2000
bei mit 4000 Nits gemasterten Inhalten wird die Helligkeit überbelichtet und viele Highlight-Details gehen verloren.
4000
Das heißt, der 98X90L kann ein HDR-Signal mit bis zu 2000 Nits anzeigen. Wenn dieser Wert überschritten wird, gehen die HDR-Details verloren
Bei Betrachtung in normal heller Umgebung tagsüber ist kein Blooming zu erkennen, wie es aus dem Starfield Test hervorgeht,
man kann alle Details im Sternenhimmel erkennen, wobei der Schwarzwert nicht schwarz genug ist
Blooming
Die Farbraumabdeckung beträgt nach DCI-P3 95,46%, REC.2000 76%
[Beitrag von Ralf65 am 30. Jul 2023, 07:51 bearbeitet]
Ralf65
#70 erstellt: 02. Aug 2023, 07:05
das Video zu dem zuvor veröffentlichten Test des 98"
Ralf65
#71 erstellt: 03. Aug 2023, 18:29
ein Overview von Abt Electronics
Carisma1996
#72 erstellt: 04. Aug 2023, 20:33
Würde ein Upgrade von meinem jetzigen 55X95G auf einen 65X90L Sinn machen, sprich wäre hier das Bild besser oder gleich, weil meiner ein 95iger ist.
Shaoran
#73 erstellt: 05. Aug 2023, 08:08
Da du dich gleichzeitg auf vergrößerst vom Bild, würde ich sagen verbesserst du dich
Der X95G war ja jetzt auch kein Über TV, da kann der neue 90L locker mithalten und übertreffen.
Ralf65
#74 erstellt: 07. Aug 2023, 17:20
Hier nochmal ein Test des 55" X90L von whathifi
Jogitronic
#75 erstellt: 09. Aug 2023, 19:27
Surprising Truth about the Best MiniLED TV: QM8 vs Sony X90L
Ralf65
#76 erstellt: 12. Aug 2023, 05:33
der Test des X90L auf rtings
getestet wurde die 65" Variante
Ergebnis aus dem Side-by-Side Vergleich mit dem Vorgänger X90K
Zitat:
The Sony X90L/X90CL is a noticeable improvement over its predecessor, the Sony X90K. The X90L gets a lot brighter, especially in HDR, so bright specular highlights stand out better. The X90L also has a much better local dimming feature, resulting in significantly less blooming around bright areas of the screen, deeper blacks, and smoother (but still not great) zone transitions.
Nachfolgend die CAL-Settings
wobei zu beachten ist, das "jedes" Panel individuell für sich zu betrachten ist, die Settings daher abseits des getesteten Gerätes nie zu einem 100% identischen Ergebnis führen
in einem weiteren Vergleich mit dem Vorjahresmodell X95K
Im HDR Betrieb ist der X90L schon gut und kann fast zum X95K aufschließen,
im SDR Betrieb hingegen lässt sich der X90L sogar durch den X95L nichts mehr vormachen und erhält daher eine identische Bewertung
Dafür, das der X95K bereits mit MiniLED ausgestattet ist, hätte man hier sicherlich einen größeren Vorteil erwartet.....
X90L
[Beitrag von Ralf65 am 12. Aug 2023, 10:12 bearbeitet]
Jogitronic
#77 erstellt: 15. Aug 2023, 14:51
Ralf65
#78 erstellt: 24. Aug 2023, 02:39
RalphAC
#79 erstellt: 24. Aug 2023, 20:36
Aktuell ist der 85er bei expert Neuss für 2.311,43 im Angebot (inkl. 79,90 € Versand). Bei 350 € Cashback kostet der 85er unter 2.000 €.
Angebot ist mittlerweile abgelaufen.
[Beitrag von RalphAC am 25. Aug 2023, 03:33 bearbeitet]
uepps
#80 erstellt: 27. Aug 2023, 07:39
@Jhonny7
Hatte die ganze Zeit auf einen Erfahrungsbericht von dir gehofft. Kannste da mal schreiben wie du mit dem zu Frieden bist oder ob nicht?
Würde mich natürlich auch über Erfahrungsbericht anderer Besitzer freuen.
Bei unserem MediMax gibt's den ab morgen in einer Aktion mit Rabatte für 1239,20. Dafür könnte ich schwach werden.
[Beitrag von uepps am 27. Aug 2023, 07:40 bearbeitet]
RalphAC
#81 erstellt: 27. Aug 2023, 13:49
Im avsforum gibt es einen owners-Thread zum X90L. Vielleicht findest du da Infos, die dir weiterhelfen. Da ich nicht weiß, ob ich das Forum hier verlinken darf, lass ich es lieber. Noch ein kleiner Hinweis: die Forenadresse endet mit .com
celle
#82 erstellt: 29. Aug 2023, 04:49
Hisense bringt nun auch einen 100" Mini-LED-LCD mit 1620 Dimmignzonen und der ist bei Otto.de schon für 3499€ gelistet. Sony sollte mal seine Preise beim 98" überdenken. TCL bringt auch zwei neue 98" TVs. Klar wird der Sony die bessere Bildelektronik und Software haben, aber der Aufpreis ist das niemals Wert. Immerhin vergleicht man hier das Bild mit Projektoren und Kurzdistanzbeamern.
hanseat500
#83 erstellt: 29. Aug 2023, 05:27
celle (Beitrag #82) schrieb:
Hisense bringt nun auch einen 100" Mini-LED-LCD mit 1620 Dimmignzonen und der ist bei Otto.de schon für 3499€ gelistet.. .
Wo gibts denn bei Otto einen 100 " Hisense Mini LED TV ? Ich konnte da keinen finden, in der Größe gibt es dort nur Laser TVs . Ein Link wäre schön.
MrWhite66
#84 erstellt: 29. Aug 2023, 05:30
Bitte: https://www.otto.de/...riationId=1761756970
Aktuell kann man den TV aber nicht bestellen.
uepps
#85 erstellt: 29. Aug 2023, 06:53
RalphAC (Beitrag #81) schrieb:
Im avsforum gibt es einen owners-Thread zum X90L. Vielleicht findest du da Infos, die dir weiterhelfen. Da ich nicht weiß, ob ich das Forum hier verlinken darf, lass ich es lieber. Noch ein kleiner Hinweis: die Forenadresse endet mit .com ;)
Kann man das Forum auch auf Deutsch einstellen?
Mich interessiert eigentlich der Erfahrungsbericht von Jhonny7. Oder ist dort einer?
MrWhite66
#86 erstellt: 29. Aug 2023, 07:39
Jeder Browser kann das.
TEMUR
#87 erstellt: 30. Aug 2023, 14:37
Hallo, ich kurz vorm Kauf von 65X90L. Jetzt habe ich ein video entdeckt, wo unter anderem auf Blooming eingegangen wird.
Hier ist der Link:
https://youtube.com/watch?v=a9afnA9519o&feature=shared
Ab 2:03
Ist das wirklich so schlimm? Oder ist es in Realität eher vernachlässigbar?
Ralf65
#88 erstellt: 30. Aug 2023, 15:17
in dem Video wird doch extra mit "Einblendung" darauf hingewiesen, das zur Verdeutlichung des Bloomings das Bild überbelichtet wurde...
Natürlich wird man das Blooming auch in der Realität erkennen, mit der (geringen) Anzahl an Dimming Zonen kann man dies nun mal nicht vermeiden, geschweige denn eliminieren, so wie in dem Video explizit dargestellt, ist es in der Realität jedenfalls nicht.
Ob oder wie stark Du das am Ende als womöglich störend empfindest, das hängt ganz von Deinem persönlichen Seheindruck ab,
[Beitrag von Ralf65 am 30. Aug 2023, 15:24 bearbeitet]
TEMUR
#89 erstellt: 30. Aug 2023, 15:52
Achso, ok danke. Das hatte ich jetzt nicht verstanden. Keine gute Englischkenntnisse leider.
Das Problem ist, ich möchte es vor Ort kaufen, da ich dann keine Versandkosten zahlen muss und mit 0% finanzieren kann.
Aber da gibt es ja dann kein Rückgaberecht.
Selbst wenn ich es vor Ort probeschauen würde, würde es mir nicht helfen, weil ich nicht weiß wie es dann abends bei Filme schauen aussehen würde.
Schwierige Entscheidung.
Ralf65
#90 erstellt: 31. Aug 2023, 02:43
Ralf65
#91 erstellt: 31. Aug 2023, 03:10
Ich kenne natürlich Dein Geschäft der Wahl nicht, bei mir vor Ort jedenfalls, hat man mir stets im Gespräch ein Rückgaberecht innerhalb von 14 Tagen bei Nichtgefallen eingeräumt....
Das ist zugegeben eine schwierige Entscheidung, in dem Punkt kannst Du dir allerdings sicher sein, erkennen wirst Du es hier und da auf jeden Fall,
wenn Du einen TV ganz ohne Blooming bevorzugst, dann muss Du zwangsläufig auf die OLED Technik setzen, oder aber eben für noch weniger Blooming auf ein höherwertiges Modell mit deutlich mehr Dimming Zonen, was dann aber auch deutlich teurer ist, oder aber nicht mehr von Sony (siehe Vergleich im Video, vorheriger Post)
[Beitrag von Ralf65 am 31. Aug 2023, 03:17 bearbeitet]
TEMUR
#92 erstellt: 31. Aug 2023, 09:26
Also zugegeben, ich habe vor Ort in Fachmärkten nie gefragt, ob man auch Rückgaberecht hat. Vielleicht wäre es doch möglich. Ich bin nur davon ausgegangen, dass man vor Ort gekaufte Waren nicht zurückgeben kann.
Und erkennen würde ich es wahrscheinlich, aber ob es mich abends bei Filme schauen stören würde, kann ich ja nur sagen, wenn ich es zu Hause ausprobiert habe.
OLED kommt leider nicht in Frage, weil ich auch gerne viel Live TV schaue, wo auch viel statische Bilder sind, z.B. bei Nachrichten oder Sportsendungen usw.
Andere Alternative wäre eigentlich Samsung QN90B Serie. Aber, muss ich noch schauen.
Jogitronic
#93 erstellt: 31. Aug 2023, 10:16
Firmware-Update auf Version 6.7283
https://www.sony.de/...5l/software/00294716
Vorteile und Verbesserungen
Verbessert den Prozess zur Wiederherstellung der Verbindung zum gespeicherten WLAN-Zugriffspunkt nach dem Aus- und Einschalten
Erhöht die Sicherheit des Fernsehers
RealMax
#94 erstellt: 07. Sep 2023, 17:57
Hallo zusammen,
kann mir jemand sagen ob der Sony X90L ein VA oder IPS Panel hat? Im Netz dazu gibt es unterschiedliche Aussagen. So wie ich das verstanden habe macht Sony da keine Angaben und es können sowohl IPS als auch VA Panels verbaut werden. Nur der X95L hat wohl gesichert ein VA Panel
Ralf65
#95 erstellt: 08. Sep 2023, 02:46
Bei der Modellreihe X90L ist ein VA Panel verbaut, u.a. erkennbar an dem hohen nativen Kontrastverhältnis, sowie der Pixelstruktur, siehe auch HIER
Screenshot 2023-09-08 044532
in den Oberklasse Modellen, bzw. dem oberen Einstieg dazu (X90 Reihe) kommen bis dato bei Sony ausschließlich VA Panels zu Einsatz,
zudem wird die X90 Reihe bis dato grundsätzlich "ohne" das "X-Wide Angle" Feature ausgestattet....
[Beitrag von Ralf65 am 08. Sep 2023, 02:53 bearbeitet]
MrWhite66
#96 erstellt: 08. Sep 2023, 07:30
RealMax (Beitrag #94) schrieb:
Hallo zusammen,
Lass mich raten, du hast ein Video von TecTracks HD angesehen, welcher in seinem „Review“ zum X90L ja verkündet hat, dass in der X90L Baureihe unterschiedliche Panel verbaut werden. Diese Aussage ist, wie ganz, ganz viel von ihm, absoluter Quatsch! Wie Ralf65 schon völlig geschrieben hat, kommen in der X90 Baureihe ausschließlich VA-Panel zum Einsatz.
*FirstClass*
#97 erstellt: 01. Okt 2023, 03:53
Und gewonnen hat der Sony
Shutout TV Test
Airen
#98 erstellt: 01. Okt 2023, 12:54
Hallo Community,
Ich hoffe ich bin hier richtig.
Ich hatte einen Sony 85X9096 der durch Blitzschlag das zeitliche
segnete.
Habe nun eine 85X90L als Nachfolger.
Kann ich die Settinga vom 9096 übernehmen oder hat jemand Anpassungen?
Kann man den SkyQ Receiver an den HDMI 4 anschließen oder nur an HDMI 1 oder 2?
Ralf65
#99 erstellt: 06. Okt 2023, 02:03
Die Basis Settings kann man übernehmen (findest Du z.B. HIER), erweiterte Settings jedoch (z.B. Weißabgleich) sind für jedes Gerät individuell zu ermitteln, möchte man das Optimum herausholen
Kann man an allen Ports betreiben
TEMUR
#100 erstellt: 12. Okt 2023, 13:41
Hallo, ich hätte eine Frage. Ich könnte in einem Fachmarkt 65X90L und 65X95L testen.
Was mir sofort auffiel, dass 65X95L bei der Bedienung träge war als 65X90L.
Beide waren auf neuestem Stand. Wie kann das sein? Die Bedienung von 65X90L war flüssiger.
Ich will nun das 65X95L bestellen, bin mir aber jetzt nicht sicher. Was wenn das nicht gefixt wird oder so.
Hat hier noch jemand das 65X95L?
Ralf65
#101 erstellt: 13. Okt 2023, 08:54
eigentlich sollte das nicht sein, da die Hardware ja identisch ist,
was immer sein kann, nach einem FW Update z.B., dass das System danach träger reagiert, das kann man i.d.R. mit einem Factory-Reset wieder beheben.
Wenn Du speziell zum Verhalten des X95L Äußerungen von Usern dazu suchst, dann solltest Du die Frage im entsprechenden X95L Thread stellen
Sony 2023 MiniLED X95L 65", 75", 85"
Ralf65 am 10.02.2023  –  Letzte Antwort am 10.11.2024  –  1879 Beiträge
Sony 2019 XG85 55" 65" 75 85"
Ralf65 am 08.01.2019  –  Letzte Antwort am 02.06.2020  –  87 Beiträge
Sony 2023 8K Mini-LED Z9L 75", 85"
Ralf65 am 10.02.2023  –  Letzte Antwort am 09.03.2023  –  4 Beiträge
Sony 2018 XF85 43", 49", 55", 65", 75" , 85??
Ralf65 am 09.01.2018  –  Letzte Antwort am 10.11.2018  –  46 Beiträge
Sony 2020 XH95 49"/55"/65"/75"/85"
Ralf65 am 16.11.2019  –  Letzte Antwort am 11.10.2024  –  4017 Beiträge
Sony 2020 XH80 43"/49"/55"/65"/75"/85"
Ralf65 am 16.11.2019  –  Letzte Antwort am 10.03.2021  –  22 Beiträge
Sony 2020 XH90/XH92 55"/65"/75"/85"
Ralf65 am 07.01.2020  –  Letzte Antwort am 01.10.2024  –  6618 Beiträge
Sony 2022 4K X90K, X93K, X94K 55"/65"/75"/85"
Ralf65 am 04.01.2022  –  Letzte Antwort am 27.06.2023  –  160 Beiträge
Sony 2021 X95J 4K 65", 75", 85"
Ralf65 am 07.01.2021  –  Letzte Antwort am 21.09.2024  –  2900 Beiträge
Sony 2024 Bravia 9 75",85" Bravia 7 65",75",85"
Ralf65 am 27.11.2023  –  Letzte Antwort am 04.12.2024  –  3432 Beiträge
  • Registrierte Mitglieder928.456 ( Heute: 9 )
  • Neuestes MitgliedMone_1994
  • Gesamtzahl an Themen1.558.258
  • Gesamtzahl an Beiträgen21.698.274
