Sony KDL defekt ? Code ?
Heim_kino
#1 erstellt: 10. Aug 2015, 17:48
Hallo kann einer was mit dem Code anfangen ( er schaltet ab und blinkt dann 16 mal ...kurze Pause dann wieder 16 mal und immer das gleiche ) ? Der vom Sony Support sagte , hätte er noch nie gehört.
Mfg Ronny
zeg
#2 erstellt: 11. Aug 2015, 07:58
Sicher das es 16x sind?
Habe nur das hier gefunden - bis 14x:
Sony Bravia KDL LCD TV error codes for red led blinking flashing light
Red led light blinks flashes, red light error code troubleshooting Chart, TV shutsdown
Always try power reset, unplug powercord for 5 mins then factory reset tv & update with usb drive from sony site- http://esupport.sony.com/US/perl/swu-download.pl?upd_id=7151
0 no red standby light-check powercord or bad main logic board or power board, check standby volts
1 red blink not used
2 red flashes is bad power board, solution replace power board
3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
4 red blinks- can be LD board or main logic board, check inverter board wires for arcing to ground
5 red flashes- bad lcd panel connection or internal lcd short- squeeze bezel to locate bad connection
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
7 red flashes- main board over heating, can be short on power board or main logic board
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
9 blinks- check fan error, * if TV has fans
10 blinks- digital board or tuner board * some Sony TVs may not have this board
11 red flashes- bad main board, bad IC, replace main logic board
12 red light flashes is tcon error bad T-con board or bad LCD panel, replace tcon board usually
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
14 red flashes HFR- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board.
-z.
eraser4400
#3 erstellt: 11. Aug 2015, 08:03
Sicher? 16 gibbet nämlich nicht. Max. 8 sind bei Sony angesagt.
Hier mal die Aufschlüsselung (auch für Andere, deren TV-LED, Disco spielt...):
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Heim_kino
#4 erstellt: 11. Aug 2015, 12:28
Danke erstmal Aber er blinkt 16 mal ... bin auch nicht der erste mit dem Fehler .
http://www.wer-weiss-was.de/t/sony-lcd-tv-blinkt-16mal/8832967
Ich betreibe ihn ohne Media Receiver . Also direkt vom Sat Receiver mit HDMI .
Habe schon Werksreset versucht , leider ohne Erfolg .
Heim_kino
#5 erstellt: 18. Aug 2015, 15:58
Hallo es gibt Neues . Wir waren bei Expert ... das Signal Board sei defekt und nicht zu beschaffen . Also TV in Müll
Meine Frage an euch . Ist das Signal Board das Mainboard oder T-Con Board ?
Hat einer ein Tipp wo ich das gebraucht oder neu noch bekommen könnte . Danke
Sony KDL 46V5500 defekt!
lakueh am 19.09.2010  –  Letzte Antwort am 19.09.2010  –  2 Beiträge
Code für Sony TV
phari54 am 12.06.2011  –  Letzte Antwort am 12.06.2011  –  3 Beiträge
Sony KDL-46W4500 Guide defekt?
robsen78 am 18.10.2009  –  Letzte Antwort am 18.10.2009  –  2 Beiträge
Sony Bravia KDL-40W5500 defekt?
Cwicky am 28.11.2011  –  Letzte Antwort am 30.11.2011  –  3 Beiträge
Sony KDL W65 955 defekt
Botzo1588 am 05.10.2015  –  Letzte Antwort am 05.10.2015  –  3 Beiträge
[KDL-46W5740] Fehler Code 6
Heinz_Ketchup am 18.04.2010  –  Letzte Antwort am 20.04.2010  –  5 Beiträge
KDL-55W955B Mainboard defekt?
Nic_75 am 23.06.2022  –  Letzte Antwort am 24.06.2022  –  4 Beiträge
KDL-46W5500 Display Defekt?
JimMeier am 16.01.2018  –  Letzte Antwort am 18.01.2018  –  4 Beiträge
Suche Remote Code
Schmierstoff am 30.12.2010  –  Letzte Antwort am 17.03.2012  –  10 Beiträge
Display von Sony Bravia KDL-32D3000 defekt
fraunz_24 am 27.01.2009  –  Letzte Antwort am 27.01.2009  –  3 Beiträge
2015
  • Registrierte Mitglieder928.405 ( Heute: 7 )
  • Neuestes MitgliedNukem28
  • Gesamtzahl an Themen1.558.134
  • Gesamtzahl an Beiträgen21.694.865
Top Hersteller in Sony Widget schließen
