LG 42LH7000 mkv. Unterstützung?
cank22
#1 erstellt: 21. Mrz 2009, 13:02
Der neue LG 42LH7000 soll divx und mkv Dateien per USB abspielen können.
Das wäre schon toll, denn dann bräuchte man sich keinen Multimedia Player kaufen.
Hier die Daten:
http://uk.lge.com/products/model/detail/lcdtv_42lh7000.jhtml#
affenarsch
#2 erstellt: 22. Mrz 2009, 00:03
das gleiche hab ich mir auch gedacht. Hier mal den Auszug aus der englischen Anleitung
Movie(*.dat/*.mpg/*.mpeg/*.ts/*.trp/*.tp/*.vob/*.mp4/*.mkv/*.avi/*.divx) supporting file
Video format: DivX3.11, DivX4.12, DivX5.x, DivX6, Xvid1.00, Xvid1.01, Xvid1.02, Xvid1.03, Xvid 1.10-
beta-1/beta-2, Mpeg-1, Mpeg-2, Mpeg-4, H.264, AVC
Audio format : AC3(Dolby Digital), EAC3, AAC, Mpeg, MP3, PCM, HEAAC, CDDA
Bit rate : within 32 ~ 320kbps(MP3)
Subtitle format : *.smi/*.srt/*.sub(MicroDVD, SubViewer1.0/2.0)/*.ass/*.ssa/*.txt(TMPlayer)/*.psb(PowerDivx)
• Some user-created subtitles may not work properly.
• The screen may suffer temporary interruptions (image stoppage, faster playback, etc.) when the audio language is changed.
• A damaged movie file may not be played correctly, or some player functions may not be usable.
• Movie files produced with some encoders may not be played correctly.
• If the video and audio structure of recorded file is not interleaved, either video or audio is outputted.
• HD videos with a maximum of 1920x1080@25/30P or 1280x720@50/60P are supported, depending on the frame.
• Videos with resolutions higher than 1920X1080@25/30P or 1280x720@50/60P may not work properly
• Movie files other than the specified types and formats may not work properly.
• Max bitrate of playable movie file is 20Mbps.
• We do not guarantee smooth playback of profiles encoded level 4.1 or higher in H.264.
• DTS Audio codec is not supported.
• A movie file more than 30GB in file size is not supported for playback.
• A DivX movie file and its subtitle file must be located in the same folder.
• A video file name and its subtitle file name must be identical for it to be displayed.
• Playing a video via a USB connection that doesn’t support high speed may not work properly.
Klingt doch eigentlich sehr vielversprechend. Ich frag mich ob der Fernseher eine DTS-Tonspur in einer MKV-Datei über den Optical-Out durchschleifen kann.
CHE-24
#3 erstellt: 23. Mrz 2009, 15:30
Hey Leute schaut euch das hier Mal an
http://de.lge.com/products/model/detail/lcdtv_42lh7000.jhtml
Der Fernseher ist nun auf der Deutschen Website von LG aufgetaucht. Ich hab ihn vor 3 Wochen bestellt, anscheinend dauert es noch ein wenig mit der Lieferung. Sobald ich ihn hab, stelle ich euch meine ersten Eindrücke soweit es geht ausführlich dar.
samimukke
#4 erstellt: 23. Mrz 2009, 17:05
habt ihr schon vom
" LG Electronics 47LH7020 "
gehört?
also nach den daten zur urteilen,der HAMMER!!!
Diagonale: 47"/119cm • Auflösung: 1920x1080 • Format: 16:9 • Schnittstellen: 4x HDMIDiagonale: 47"/119cm • Auflösung: 1920x1080 • Format: 16:9 • Helligkeit: 500cd/m² • Kontrast: 100.000:1 (dynamisch) • Reaktionszeit: 3ms • Betrachtungswinkel (h/v): 178°/178° • Anschlüsse: 4x HDMI, Komponenten (YUV), 2x SCART, VGA, S-Video, Composite Video • Stromverbrauch: 230W • Maße (BxHxT): 101x75.4x33.4cm • Gewicht: 19.8kg • Besonderheiten: integrierter DVB-C/-T-Tuner (MPEG-4 AVC), 100Hz-Panel, 24p-Unterstützung, USB-Schnittstelle, DivX-Unterstützung, MKV-Unterstützung, Bluetooth
einfach nur die verbesserte version des " 47lg7000 "
peter2222
#5 erstellt: 23. Mrz 2009, 19:17
hi leute,
hab die neue H-Serie nur in UK gefunden!
http://uk.lge.com/products/category/list/tv_lcdtv.jhtml
hoffe bald auf den 47lg90 (LED backlight)
greez
peter2222
#6 erstellt: 23. Mrz 2009, 19:54
maexx99
#7 erstellt: 23. Apr 2009, 09:14
Gibts schon neuigkeiten bezüglich dem LG?
Gruß maexx
Fuss001
#8 erstellt: 27. Mai 2009, 10:45
Grober Test aber ohne Bildqualität und Ton
ich hoffe es hilft...
ich schwanke zwischen dem LG 42LH7000 für um die 770,- EUR
und dem Sony KDL-40W5500 für 950,- EUR...schwierig
[Beitrag von Fuss001 am 27. Mai 2009, 10:47 bearbeitet]
M_i_c_h_a_e_l
#9 erstellt: 27. Mai 2009, 11:06
samimukke schrieb:
habt ihr schon vom
gehört?
das ist keine verbesserte version. der rand unten ist nur nicht rot, sondern schwarz.
Fuss001
#10 erstellt: 27. Mai 2009, 11:23
ich hätte einen Test....aber wie kann ich hier ein PDF das auf meinem PC ist anhängen?
Potze123
#11 erstellt: 10. Jun 2009, 21:13
Hi @ all,
weis schon irgendjemand ob die DTS-Tonspur in einer MKV-Datei über den Optical-Out durchgeschliefen wird? Würde mich brennend interessieren? Könnte das evtl. jemand testen?
Besten Dank im Voraus!!
Mightymod
#12 erstellt: 16. Jun 2009, 17:34
Nein das geht leider nicht, stört mich auch bischen, muss mein ganzes dts-material nach ac3 kovertieren.
Curiositatis
#13 erstellt: 04. Nov 2009, 02:25
Ist diese Unterstützung auch HD-fähig?
1920x1080p?
Gerade bei mkv ist HD ja sehr verbreitet.
Evtl. ist das bei TVs ja selbstverständlich, aber beim Topfield 7000 PVR geht nur SD (und auch nur DivX)!
nickilein
#14 erstellt: 04. Nov 2009, 20:32
jo ist es
42LH7000
merkur10 am 09.06.2009  –  Letzte Antwort am 15.06.2009  –  10 Beiträge
Kurzer Erfahrungsbericht LG 42LH7000
MarPer am 17.04.2009  –  Letzte Antwort am 08.12.2009  –  95 Beiträge
LG 42LH7000 DVB-C
maik2010 am 10.06.2009  –  Letzte Antwort am 22.08.2009  –  60 Beiträge
LG 42LH7000 geht nicht mehr an
buda80 am 26.10.2020  –  Letzte Antwort am 09.11.2020  –  5 Beiträge
42LH7000 brummt/surrt
Zotri am 03.09.2009  –  Letzte Antwort am 01.10.2009  –  4 Beiträge
Meine Erfahrungen mit dem 42lh7000
sabid am 25.04.2009  –  Letzte Antwort am 27.04.2009  –  2 Beiträge
VERBINDEN VOM 42LH7000 zu PANASONIC DMR EX81S
Toundl am 27.02.2010  –  Letzte Antwort am 27.02.2010  –  3 Beiträge
Fragen zum Firmware-Update für 42Lh7000
merkur10 am 13.08.2009  –  Letzte Antwort am 13.08.2009  –  7 Beiträge
42LH7000: 5V Spannung über den DVB-T
lunnik am 14.12.2009  –  Letzte Antwort am 18.12.2009  –  4 Beiträge
LG 32LE5300 - MKV ruckelt
hal9000x am 28.08.2011  –  Letzte Antwort am 28.08.2011  –  2 Beiträge
  • Registrierte Mitglieder928.949 ( Heute: 6 )
  • Neuestes MitgliedAsdemna
  • Gesamtzahl an Themen1.559.373
  • Gesamtzahl an Beiträgen21.724.792
