HIFI-FORUM » English » DIY (Engl.) » LM318+LM3886 MyRef amp completed | |
LM318+LM3886 MyRef amp completed+A -A |
quadtech
13:00
erstellt: 14. Apr 2009, |
Folks, I completed the MyRef RevC amp, for which there was a recent group PCB buy on diyaudio. It is a "composite" amp - LM318 driving an LM3886. The chassis has a spartan, industrial look, and everything is made easy to remove. Got chassis and toroid locally in Hyderabad. I mounted the PCBs on a "mezzanine" card made from an electrical switchboard sheet. The shaft coupler is the brass insert from a 60A electrical connector. Both items are from a local electrical shop. The front bushing for the shaft was scavenged from a cheap rotary switch. The power switch contacts have 1KV rated caps across them. No turn-on or turn-off thump at all, and the amp is dead quiet. DC offset is like 5mV. The amp sounds quite fine to me. Some things like the cheesy LED holder and the knob will be replaced once I have better ones. I may also build a small input relay board to switch between 3 sets of RCA inputs. The build pics are here - ![]() Thanks for looking Prasad [Beitrag von quadtech am 14. Apr 2009, 13:01 bearbeitet] |
Savyasaachi
14:58
very neat build.congratulations...The important question is, how does it sound? ![]() |
Soundsgreat
15:10
Hi, Prasad congrats on a fine build ![]() As Sachi has asked please elaborate on the sound please ![]() Also is this GB still up ?? if so please post the links ! Finally please do post the cost of the entire project so that we can also think of making one for ourselves ![]() Regards. |
quadtech
16:31
The group buy is over, but the guy who ran it, Peter Schroeder, might still have a few PCBs. A single sided PCB pdf is also available for download, if you want to try toner transfer. AFAIK, there are no exotic components on the board, so should be easy to buy the parts, esp in Blr or Mumbai. The chipamp definitely sounds very good and I am quite pleased with it. If you really push me to make a choice, the KT77 tube amp I built earlier is a bit warmer and easier on my ears. Here is the cost breakup - Pair of PCBs with parts - $65 24-0-24, 300 VA toroid - Rs 1500 Chassis made by a sheet metal shop - Rs 700 6mm aluminium rod for extension shaft - Rs 25 60Amp elect connector for the shaft coupler - Rs 35 Heatsinks - I had a piece with me which I cut in two - I think I paid Rs 100 for it a while back. I may replace with a better ones later. I already had a lot of misc hardware (binding posts, RCAs, nuts, spacers, wires etc), but I'd estimate that to be Rs 500 or so. Prasad |
Soundsgreat
07:16
erstellt: 15. Apr 2009, |
Hi, Prasad thanks a lot for the info ![]() The total price is approx 10K,which I think is not at all bad !! so I think will like to give it a try ![]() when you say the tube was warmer (offcourse its well known for that kinda sound ) does that mean the Chip Amp sounded forward or bright ?? Also buddy can you tell me bit more bout it ? has the Amp had sufficient Burn-in ?? coz that is what mainly dictates the final sound !! Also please do share what related electronics and speakers you are using ?? Regards. |
quadtech
18:03
erstellt: 17. Apr 2009, |
Sreekanth, This design was posted by Mauro Penasa in the chipamps forum on diyaudio - ![]() The original thread on this amp has the subject "My "audiophile" LM3886 approach" The questions from the recent group buy was discussed under the subject "The new "My Ref" Rev C thread" The schematics, pcb layout were posted around here (see a few posts before this one too) - ![]() I am reluctant to be too specific about the sound of this amp for multiple reasons - I am using cheap test speakers, my source is an cheap old dvd player as a source, and I am not blessed with "audiophile" ears. The amp has not had any burn-in yet, perhaps a total of a couple of hours. Here's the obligatory Chinese rip-off - ![]() Prasad [Beitrag von quadtech am 17. Apr 2009, 18:07 bearbeitet] |
Soundsgreat
06:06
erstellt: 18. Apr 2009, |
Hi, Prasad thanks once again for all the info ![]() How did you get my name ?? PM'ed someone here ![]()
Ok no worries, I thought so myself regarding the burn-in so only mentioned it in my last post ! If you later (after duly burning it) decide to pen a sentence or two bout the sound it'll be interesting to read ![]() Regards. |
KT77 Pushpull integrated amp quadtech am 25.12.2008 – Letzte Antwort am 13.01.2009 – 10 Beiträge |
My second DIY tube amp .The starving student Millet Hybrid Savyasaachi am 11.03.2009 – Letzte Antwort am 18.03.2009 – 13 Beiträge |
DIY Headphone amp Manek am 20.09.2006 – Letzte Antwort am 21.09.2006 – 25 Beiträge |
Santa Claus DIY Tube Amp screamgigi am 14.10.2006 – Letzte Antwort am 09.10.2007 – 237 Beiträge |
Old Arphi 60x2 watts amp Manek am 05.04.2009 – Letzte Antwort am 08.04.2009 – 6 Beiträge |
300 watt Hi-fi power amp project. hydrovac am 19.07.2013 – Letzte Antwort am 19.09.2013 – 5 Beiträge |
Slightly OT - CNC cutting for DIY quadtech am 16.02.2009 – Letzte Antwort am 29.03.2009 – 6 Beiträge |
peerless india website updated and some questions poochandy am 09.03.2008 – Letzte Antwort am 07.10.2008 – 8 Beiträge |
Sachiko speakers done quadtech am 11.06.2009 – Letzte Antwort am 21.05.2017 – 9 Beiträge |
Bought my first tubes.now need an amp to put them in Savyasaachi am 09.02.2009 – Letzte Antwort am 11.02.2009 – 5 Beiträge |
- Registrierte Mitglieder928.550 ( Heute: 8 )
- Neuestes Mitglieduouououo
- Gesamtzahl an Themen1.558.469
- Gesamtzahl an Beiträgen21.703.085
