HIFI-FORUM » English » DIY (Engl.) » Inside instead of Outside! | |
Inside instead of Outside!+A -A |
Neutral
09:35
erstellt: 09. Okt 2006, |
I have noticed that in practically all speakers drivers are mounted on the outside of the baffle (closer to the listener) and flush to the baffle with screws and / or nuts. However, on my friend's DIY speaker, the drivers are mounted on the inside of the baffle with screws. In other words, they are recessed by the width of the baffle, around 18mm. I told my friend that the sound engineer has mounted the drivers wrongly. I added that this would affected the sound quality due to edge diffraction and corraling of the tweeter's dispersion pattern. Was what I said correct from a technical point of view? Is this mounting pattern irrational or is there some benefit from this style of mounting? |
Manek
10:40
If I am not mistaken...Krish's speakers are mounted in sort of the same way......right Krish ? Now if Linn does it, there has to be a method behind the madness....but I wonder if your friends speaker maker had the same reasons for doing it ? Manek. |
Neutral
10:50
Linn? Wow! I thought that my friend's speaker maker was just plain nutty or clueless. ![]() |
Krish
07:00
erstellt: 10. Okt 2006, |
Yes |
viren
04:08
erstellt: 11. Okt 2006, |
Hi, I have a pair of speakers, Rogers Studio One, where the woofer is mounted from inside the baffle. But, only the woofer; the tweeters are mounted conventionally, recessed into the front of the baffle. However, the cabinet edge in front of the woofer is rounded off to avoid edge diffraction as far as possible. Diffraction is a problem with high frequencies, when wavelengths become comparable in length to cabinet dimensions. If the woofer is going to be rolled off by a crossover way before that, it should make no difference whether it is mounted from inside or outside. But I would never do an inside mounting to a midrange or tweeter driver (unless it's shaped like a horn!). Viren. |
Neutral
06:58
My friend bought a Proton D540 40W/ch stereo amp last night from Bangalore forum member Nietzche. So his speakers sprang to life. They sound great! simply great! I couldn't believe my ears - they are 25 years old speakers with a 12" Philips driver and a 3" Bolton tweeter and use a simple first order Bolton crossover. Classical music and Diana Krall simply sounded wonderful. It's as if the singers and instrumentalists were really there. The cabinets are massive, maybe around 70 litres in volume. They are ported - but the front port is fairly small as it is blocked by a wooden sieve reducing its effective width. The bass is tight and goes really low - no boom at all. Might not compete with the best new flrs, but for their age, they sure rock ![]() Viren, the room is small (150 sq ft) and listeners have to sit just in front of the massive speakers. So, I guess that while edge diffraction is certainly there, it will not be so apparent to a person within a 20 degree angle from the front. The waves from a 12" woofer should be long enough to escape unscathed. My take is that large enclosures rock - it's just that they take too much space and are way too heavy. |
Kamal
08:33
Its great that your friend enjoys the speakers so much,and its very true the size of the cabinet as well as its construction still matters. Age should certainly be of not much consideration if the results are so good-not every new development represents progress-look at the way the chorus over tubes is swelling. In some thread there was a discussion over whether mono souns more full & complete than stereo... The way things are going , we might soon have to dust off and reinstall granfathers Murphy Radio ! |
Arj
08:36
well the tivoli radio is a sort of miniaturised murphy !!! |
Kamal
08:40
Heard the Tivoli at the audio fair couple of years back -It sounded good!I guess retro is well & truly in ,except for females ![]() |
Arj
08:48
yeah... aint it a shame ![]() the allure of a madhubala glance is missing in the jhatkas on the new crop ! |
Kamal
09:19
To both the glance & the jhatkas ![]() |
DIY : Design of a Rack sivat am 27.09.2007 – Letzte Antwort am 04.10.2007 – 7 Beiträge |
My first pair of DIy interconneccts. Savyasaachi am 16.08.2007 – Letzte Antwort am 17.08.2007 – 7 Beiträge |
The king of hybrid headphone amplifiers.EHHA Savyasaachi am 18.05.2009 – Letzte Antwort am 27.05.2009 – 5 Beiträge |
75 ohm terminator on digital out of cdp/dvd player Manek am 01.03.2009 – Letzte Antwort am 11.03.2009 – 6 Beiträge |
DIY rip fence for circular saw quadtech am 06.05.2009 – Letzte Antwort am 06.05.2009 – 2 Beiträge |
Equipment Mods Manek am 24.05.2008 – Letzte Antwort am 06.06.2008 – 32 Beiträge |
Volunteers needed for listening test sivat am 30.08.2007 – Letzte Antwort am 17.10.2007 – 33 Beiträge |
IWAI Speakers. Anyone ? aks07 am 22.12.2008 – Letzte Antwort am 24.12.2008 – 4 Beiträge |
Sachiko speakers done quadtech am 11.06.2009 – Letzte Antwort am 21.05.2017 – 9 Beiträge |
More tube projects on the starting block Savyasaachi am 24.03.2009 – Letzte Antwort am 11.03.2010 – 31 Beiträge |
2006
- Registrierte Mitglieder928.550 ( Heute: 1 )
- Neuestes MitgliedBlake_Hardin
- Gesamtzahl an Themen1.558.460
- Gesamtzahl an Beiträgen21.702.823
