HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Akai gx 630 defekt | |
Akai gx 630 defekt+A -A |
Antonello4923
07:46
erstellt: 21. Okt 2021, |
Hi friends I remind you again to help I have an akai gx 630 which was given to me by a gentleman but said he lit it and made white smoke I tried it and it came out the white smoke was a 2sc945 transistor in the command board forward back play rec I replaced the component and before turning on I gave a general check and I found the cause of the fault I think a capacitor with the polarity reversed on the relay board I put the condenser back in the right position I turn on and nothing smokes anymore so i thought now everything is fine but is not so I have two problems if I press forward play stop the functions are ok but if I press rewind it always starts forward practically does not rewind the reel 2 problem does not record the signal enters but does not record so i should solve the rewind problem first I checked all components on the relay board and they are still intact on the command board except for those small vertical resistors and impossible to check them one by one the scheme is there but I don't understand much as being self-taught I don't have a great technical background |
Ingor
09:14
erstellt: 23. Okt 2021, |
The rewind button should do two things: Fast forward relay is engaged and rewind relay is enganged If only the fast forward relay pulls on without the rewind relay the spindle spins always forward. I marked the important circuits. You have to look there. - Check the relay Does it pulled on? - When it does, check the contacts an cabling. - When it doesn`t check the circuit between the red marks. ![]() The second problem is a totaly other thing. When you record, does it erease the old recording on the tape? When you push the source monitor switch to "source" is the input signal at the output? Do the level meter swing? |
Antonello4923
08:32
erstellt: 28. Okt 2021, |
I answer on the second problem the input signal feels good and the vu meters oscillate ... but I want to be able to fix the tape rewind and feed problem first this morning turned it on and no longer even in advance while it is in play if I press forward or rewind it goes to stop |
Antonello4923
14:15
update i replaced tr9 (2sc945) and now it works fast forward I have yet to figure out what blocks the rewind (tr9 was short) |
Akai GX 630 D lisa-pferd am 14.03.2008 – Letzte Antwort am 14.03.2008 – 2 Beiträge |
Tonbandmaschine Akai GX 630 DB (Defekt/Wartung) Appdepp am 21.01.2021 – Letzte Antwort am 21.01.2021 – 4 Beiträge |
Akai GX 630 Rückwand öffnen didiersire am 01.09.2009 – Letzte Antwort am 01.09.2009 – 2 Beiträge |
AKAI GX 210D defekt rogolf am 12.11.2007 – Letzte Antwort am 14.11.2007 – 8 Beiträge |
Akai GX 260D DEFEKT hifi-freak2001 am 27.01.2018 – Letzte Antwort am 11.05.2019 – 3 Beiträge |
Gleichlaufschwankungen bei einer Akai GX 630 D caot am 06.08.2009 – Letzte Antwort am 07.08.2009 – 5 Beiträge |
AKAI GX-630-D Bias Leak bukongahelas am 01.06.2010 – Letzte Antwort am 02.06.2010 – 4 Beiträge |
Akai GX 630 DB Reparatur Hilferuf Claudia_E. am 11.12.2012 – Letzte Antwort am 19.12.2012 – 3 Beiträge |
Akai GX-215D Wiedergabe defekt ollidag am 05.07.2011 – Letzte Antwort am 06.07.2011 – 3 Beiträge |
AKAI GX-75 Motor defekt plook am 28.06.2016 – Letzte Antwort am 20.04.2023 – 9 Beiträge |
2021
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder928.750 ( Heute: 2 )
- Neuestes MitgliedDachsDoedel
- Gesamtzahl an Themen1.558.883
- Gesamtzahl an Beiträgen21.712.922
