HIFI-FORUM » Reparatur & Wartung » Hifi-Klassiker » Pioneer HPM 60 Hochtöner kratzt | |
Pioneer HPM 60 Hochtöner kratzt+A -A |
earl-of-gaarden
#1 erstellt: 22. Aug 2008, 20:35 | |
hallo... bei meinen hpm 60 kratzt der hochtöner einer box gelegentlich leicht. welche ursachen kann das haben? danke für tipps! gruss oli |
tri-comp
#2 erstellt: 25. Aug 2008, 22:27 | |
Do you mean the silver foil speaker (Partno: HP015A)? If it is the rather flat model without a transformer at the back then see below: It may be corroded inside. It is possible to dis-assemble the speaker my unscrewing the 2 screws at the speaker-terminals and very carefully pry the speaker open with a small screwdriver around the edge of the plastic front. The impedance of the speaker is extremely low (don't know HOW low but probably a fraction of an ohm) and it carries high currents through the silver foil membrane. Any corrosion will raise the impedance and the speaker will sound wrong, eventually be completely silent. You need a 'glassfazerpinzel' to clean the foil contact-points. Carefull!! Clean after brushing with alcohol. Clean underside of speaker terminal lugs the same way. Re-assemble the speaker and tighten both screws firmly without cracking the plastic. Gently squeeze the cable clamps with a flatnose plier to make better contact when they are pushed onto the speaker lugs. Sorry, I can barely explain this in English (not my native language) and absolutely not in German. Hope you see what I mean. Good luck, mfg, /tri-comp |
Hilfe für Pioneer HPM 60 Püh am 07.05.2011 – Letzte Antwort am 08.05.2011 – 2 Beiträge |
Pioneer HPM 60 Ersatz Tieftöner diswa am 30.03.2019 – Letzte Antwort am 31.03.2019 – 5 Beiträge |
Defekter HT Pioneer HPM 100 harald64646 am 08.08.2006 – Letzte Antwort am 10.08.2006 – 42 Beiträge |
Pioneer HPM-100, Problem zultan32 am 06.03.2009 – Letzte Antwort am 26.03.2009 – 11 Beiträge |
Hochtöner kratzt. Austauschen? egrot am 07.04.2009 – Letzte Antwort am 07.04.2009 – 4 Beiträge |
Pioneer HPM 1oo, Regler kratzen. assiv8 am 15.08.2008 – Letzte Antwort am 19.08.2008 – 13 Beiträge |
Pioneer HPM-100 mid reparatur PsyAffair am 28.09.2010 – Letzte Antwort am 28.09.2010 – 4 Beiträge |
Pioneer HPM 110 Mitteltöner defekt chris91g am 11.05.2017 – Letzte Antwort am 11.05.2017 – 2 Beiträge |
Pioneer SX 525 kratzt sollbruch am 05.03.2016 – Letzte Antwort am 12.03.2016 – 4 Beiträge |
Pioneer HPM 100, Bass Chassis defekt? assiv8 am 19.04.2008 – Letzte Antwort am 28.10.2009 – 17 Beiträge |
- WD40 als Kontaktspray?
- "Tapedeck-Reparatur" Thread
- Registrierte Mitglieder927.103 ( Heute: 1 )
- Neuestes MitgliedScrap_metal_regenera...
- Gesamtzahl an Themen1.554.787
- Gesamtzahl an Beiträgen21.621.849
