Dual C844 assistance of the club required
Alex_MGM
#1 erstellt: 04. Apr 2009, 17:06
Collegues, I got (from ebay.de) C844 deck with several defects. All bugs exept one are fixed.
One defect remains.
The reset counter, memory and set bnobs do not affect anything.
When looking the electric diagram memory sw pcp is simply 4 knobs with two states: pressed - short sircuit and not pressed - open sircuit.
When in the deck when looking with multimeter situation is different. When knod is not pressed - open sircuit. Bun when the knor is pressed - there is resistance about 10K ohms.
From the other side, when shorting the appropriate contacts with 1.5K ohm resistor - functions (reset counter, memory,..) operates normally.
So please advice, should I exchange the knobs in SW PCB to normal ones withiut resistance?
Also one more question. power transistor on radiator at the control PCB is rather worm-hot while deck is operatind. Is it normally?
Thanks in advance,
Alexander
Fuego
#2 erstellt: 04. Apr 2009, 18:55
Hello Alexander,
you have to open the knobs carefully and clean them (e.g. with Isopropanol). After cleaning, they should work again.
The power transistor on radiator at the control PCB is always very hot. That`s normal.
Kind regards
Fuego
Dual C844 deck. assistance of the club required
Alex_MGM am 02.05.2009  –  Letzte Antwort am 05.05.2009  –  3 Beiträge
Dual C844 Reparatur
am 25.09.2005  –  Letzte Antwort am 26.09.2005  –  3 Beiträge
-- Dual C844 -- Capstanmotorregelung spinnt
SirSinnlos am 06.05.2012  –  Letzte Antwort am 06.05.2012  –  3 Beiträge
Dual C844 macht zicken
declaration am 07.09.2013  –  Letzte Antwort am 07.09.2013  –  4 Beiträge
Dual C844 Riemen passt nicht !
Ultrakonkret am 24.02.2021  –  Letzte Antwort am 24.02.2021  –  3 Beiträge
Dual c844 nach Riemenwechsel bei play direkt in FF
nick541 am 02.06.2023  –  Letzte Antwort am 03.06.2023  –  2 Beiträge
Accuphase P600 problema digital display
yena60 am 13.11.2021  –  Letzte Antwort am 19.03.2024  –  4 Beiträge
Chasing Dual 704 circuit board
Cairns4me am 15.09.2024  –  Letzte Antwort am 15.09.2024  –  2 Beiträge
Dual cv62
flying-revolver am 16.07.2007  –  Letzte Antwort am 17.07.2007  –  7 Beiträge
Dual CV5650
arnie86 am 25.09.2008  –  Letzte Antwort am 25.09.2008  –  3 Beiträge
  • Registrierte Mitglieder928.735 ( Heute: 9 )
  • Neuestes MitgliedTimoL312
  • Gesamtzahl an Themen1.558.858
  • Gesamtzahl an Beiträgen21.712.447
