NIKKO ALPHA II setzt aus
Manri
#1 erstellt: 10. Sep 2010, 09:39
Guten Tag,
ich benutze einen alten aber sehr gut klingenden HIFI Turm mit Nakamichi und Thorens Teilen.
Der Verstärker Nikko Alpha II setzt nach einigen Minuten einwandfreier Widergabe für eine gewisse Zeit aus und dann selbst wieder ein. Was kann das sein? Was kann ich tun?
Vielen Dank.
Manri
tri-comp
#2 erstellt: 10. Sep 2010, 18:47
Your amplifier is rather old and by now it is time to think about a re-cap.
All electrolytic capacitos should be replaced, except perhaps the main capacitors (4 x 10.000uF/63V) in the power-supply even if I think it would be wise also to replace them.
Now most likely what happens is that the protection-circuit itself is defective. Nikko did a couple of crazy things in this circuit possibly to save on money. Instead of using a bi-polar electrolytic capacitor they just used 2 ordinary polarized cap's minus-to-minus. Allthough this in theory makes a bi-polar capacitor in praxis it's the cheap-and-dirty variant.
Replace ALL electrolytic cap's in the protection circuit. They are:
C841 & C842 (The cap's described above) -> 220uF/16V
C844 -> 3,3uF/35V
C843 -> 220uF/16V
C840 -> 0,47uF/50V
C719L & C719R -> 0,47uF/50V
That should cure any instability in the protection-circuit.
Now consider the electrolytic cap's in the output-amplifier are of equal age. They will also soon cause all kinds of instability problems like self-oscillation and destruction of the output transistors when they finally deteriorate enough. Replace them now and enjoy many more years of pleasure from the Alpha-II.
These cap's are:
C701L & C701R -> 100uF/16V
C703L & C703R -> 220uF/80V !!
C707L & C707R -> 10uF/25V
C706L & C706R -> 470uF/16V
In the power-supply are 8 cap's that I would also replace:
C801~C808 -> 220uF/10V
With all capacitors use the same or higher voltage rating. Use 105-Degree Celsius capacitors, they last longer than 85-Degree variants in my opinion.
The above 're-cap' will be VERY inexpensive compaired with a burned-out amplifier caused by defective capacitors.
If you can do it yourself..??
Well, do you know how to use a soldering iron for starters?
mfg,
/tri-comp
Pflegetips - Nikko Alpha II
Maliq am 06.01.2009  –  Letzte Antwort am 09.01.2009  –  5 Beiträge
NIKKO Alpha II - SEHR heiß (Ruhestrom)?
Maliq am 18.08.2007  –  Letzte Antwort am 19.08.2007  –  4 Beiträge
Nikko Alpha 2 " Modifikation"
cv4004 am 03.07.2016  –  Letzte Antwort am 06.07.2016  –  7 Beiträge
Problem mit NIKKO ALPHA 2 Endverstärker
vespapx am 21.12.2009  –  Letzte Antwort am 22.12.2009  –  11 Beiträge
Nikko alpha 130, Ruhesteom, Gerät wird zu heiß
highfreek am 27.02.2021  –  Letzte Antwort am 27.02.2021  –  6 Beiträge
Nikko Receiver flackert
Siddy1 am 31.05.2013  –  Letzte Antwort am 01.06.2013  –  7 Beiträge
Nikko Verstärker. Relais defekt
DerWeihnachtsmann am 02.03.2009  –  Letzte Antwort am 03.03.2009  –  6 Beiträge
Defekt: Nikko TRM 750
mihih am 29.07.2010  –  Letzte Antwort am 13.08.2010  –  8 Beiträge
Nikko 5055, lohnt Repartur?
Empfau am 12.11.2013  –  Letzte Antwort am 24.11.2013  –  5 Beiträge
NIKKO TRM 750 Reperatur
Luminary am 26.01.2014  –  Letzte Antwort am 01.02.2014  –  7 Beiträge
  • Registrierte Mitglieder928.610 ( Heute: 6 )
  • Neuestes Mitgliedjnanon251050
  • Gesamtzahl an Themen1.558.585
  • Gesamtzahl an Beiträgen21.705.841
