Gehe zu Seite: |vorherige| Erste .. 100 .. 200 . 210 . 220 . 230 . 240 . 249 250 251 252 253 254 255 256 257 258 . 260 . 270 . 280 . 290 . 300 .. 400 .. 500 .. Letzte |nächste|
Der Classic-Rock-Stammtisch
chriss71
#12617 erstellt: 21. Jan 2015, 14:17
Nochmal zurück zur Blood, Sweat & Tears Audio Fidelity SACD.
Ich wollte es gestern gar nicht wahrhaben, aber mit der Balance der SACD stimmt was nicht.
I listened again, and compared again to the Sony and MFSL. The Audio Fidelity has the vocals and bass pushed to the left channel, where the other two discs have vocals and bass mainly centered between the two speakers. Other than that placement of instruments is the same, but this wide seperation on the AF disc also gives a different sound to the drums, which come from both left and right.
Post 431
Look, what are you talking about? Just played my check disk. Vocals right down the middle as they should be, compared in mono to make sure. Straight down the middle. Everything else is just as it was when mixed back in the day. The sound is just like the producer, engineer and band intended. We reproduced it faithfully, naturally and with a feel for the organic sound of the brass instruments.
Get it together and figure out what is up with your system and stop blaming it on our new disk.
Post 432
I'm noticing the Gorts are heavily watching over this thread, so I'm a little worried that they, like many of us, are also waiting for "therockman's" review, with one finger prepared to hit the delete button!?! Hey, my copy hasn't shipped yet and I would like some fair and balanced reviews if there actually are some concerns with this release!
Posts 484
On the Sony SACD the vocals seem to be anchored dead-center, with a nice solid feel to them. On this new Audio Fidelity disc the vocals are slightly off-center and also seem to be less solid. The vocals on the Audio Fidelity disc seem to emanate just a few degrees to one side. Also the soundstage itself seems just slightly off kilter, with the percussion coming straight from the speakers whereas the Sony SACD has the percussion more centered between the two speakers.
Post 492
You are absolutely correct, it is a "non-issue." But it is a fact which I felt I had to report on. A fact is a fact, whether it is an issue or not.
Post 499
Nun zu den Fakten:
Der linke Kanal ist definitiv lauter als der rechte... (und zwar über das ganze Frequenzband)
BSandT - LeftRight
PS: GILT ALLES NUR FÜR DEN STEREO-LAYER (da kein Surround Setup)
[Beitrag von chriss71 am 21. Jan 2015, 14:26 bearbeitet]
Jugel
#12618 erstellt: 21. Jan 2015, 14:21
chriss71 (Beitrag #12617) schrieb:
...Nun zu den Fakten: Der linke Kanal ist definitiv lauter als der rechte...
Super Dann haben wir Ende Jenner ja schon den ersten Kanidaten für den Murks des Jahres (2015).
Jugel
chriss71
#12619 erstellt: 21. Jan 2015, 14:37
Naja, wäre möglich, dass es schon am Masterband so oben ist und die MoFi Leute bei ihrer SACD das korrigiert haben. DAS IST ABER SPEKULATION! Michael hat ja auch eine andere Version davon und mal sehen was er berichtet...
[Beitrag von chriss71 am 21. Jan 2015, 14:38 bearbeitet]
Biber2
#12620 erstellt: 21. Jan 2015, 19:24
Hallo chriss71,
ich wollte mich nur bei Dir bedanken, dass Du mich wieder an diese wunderbare BST CD erinnert hast. Ich habe sie seit Jahren nicht mehr gehört, einfach vergessen. Was für ein Fehler! Ich höre sie gerade wieder - hervorragend.
Die neue Version muss ich auch haben, auch wenn ein Kanal etwas leiser sein sollte
Biber2
chriss71
#12621 erstellt: 21. Jan 2015, 19:33
Ja, ist mir seit gestern auch so gegangen. Mit Child Is Father to the Man sicher die stärksten Blood, Sweat & Tears.
Käbbdn
#12622 erstellt: 22. Jan 2015, 09:41
Jetzt habt ihr mich auch angesteckt - jetzt kram ich die alte BS&T auch wieder raus.
Bei mir isses dann das MFSL-vinyl......
chriss71
#12623 erstellt: 22. Jan 2015, 10:12
Wobei es sich mit den ersten zwei Blood, Sweat & Tears dann auch erledigt hat (wobei die wirklich sehr gut sind). Mehr brauche ich nicht...
arnaoutchot
Moderator
#12624 erstellt: 22. Jan 2015, 10:17
Die ersten zwei Blood, Sweat & Tears-Platten finde ich sehr gut, um genau zu sein, finde ich die "Child is Father to the Man" absolut herausragend und die "BS&T 2" nur einen Tick darunter, was bei mir aber ein wenig mit der für mich knödeligen Stimme von David Clayton-Thomas zusammenhängt. Das waren Platten, die für meine Hörbegriffe perfekt die Hoch-Zeit des Classic Rock verkörpern, in der Einflüsse aus Blues, Jazz, Klassik und eben der Rockmusik verschmolzen. Ähnliches gelang zur gleichen Zeit Chicago (Transit Authority) mit der ersten Platte, der englischen Band If, Flock usw. Die dritte BS&T kann man noch gut hören, die 4 & New Blood habe ich dann schon gar nicht mehr ...
Für die erste scheint mir nun die AudioFidelity SACD top of the heap zu sein, bei der zweiten warte ich in Stereo mal noch den Vergleich zwischen Single Layer Columbia SACD und der AudioFidelity ab, in Mehrkanal wird sicherlich die AF punkten können, wenn ich gleich guten Klang der Quadro-Bänder der ersten mal unterstelle. Wer schnell und billig einen Überblick der ersten fünf haben will, kann das unten gezeigte Bündel nehmen, das scheinen die remasterten Versionen zu sein. Wer es nicht kennt: Es lohnt sich !
Kumbbl
#12625 erstellt: 22. Jan 2015, 16:56
ich hab vorhin im Supermarkt wegen langer Kassenschlange aus langeweile kurz die Plattenkritiken in der neuen Stereoplay durchgeblättert und bin hier auf eine euphorische Rezension eines offensichtlichen neuen Masterings von Meat Loafs Bat out of hell gestoßen - sie wird sogar als Klangtipp bezeichnet... im ernst, kann mir nicht vorstellen, dass aus diesem Mix was rauszuholen ist - aber interessant liest es sich schon - aber vermutlich nur eine von Sieveking gesponserte Rezension
Hier, darum gehts: Bat out of hell - Neuausgabe
konnte einer von euch die schon hören? Und ich will nix hören von wegen "wer hört schon diesen Schrott"
arnaoutchot
Moderator
#12626 erstellt: 22. Jan 2015, 17:03
Kumbbl (Beitrag #12625) schrieb:
Bat out of Hell -- konnte einer von euch die schon hören?
Hmm ... würde fast an ein Wunder grenzen, wenn hier bahnbrechende positive Unterschiede zu den mässig klingenden Remasters erreicht worden wären. Weiss nicht, was mit dem Masterband ist, aber Teile der Mehrspurbänder sind ja offensichtlich einem Brand zum Opfer gefallen, deswegen mussten für die SACD Neuaufnahmen gemacht werden (zB bei "Paradise by the Dashboard"-Light). Die Mehrkanal-Schicht der SACD ist auch nicht so übel. die entzerrt den Klangbrei etwas. Wenn ich die in Hong Kong mal deutlich billiger als den UVP sehe, könnet ich mal testweise zugreifen.
Kumbbl
#12627 erstellt: 22. Jan 2015, 17:09
ja, ich kenn diese SACD.... die neuaufnahmen stören mich ehrlich gesagt aber schon sehr, für mich passt das einfach nicht... egal, wenn du sie (die neue oben verlinkte, nicht die alte SACD) günstig siehst, ja, dann schlag doch mal zu ... gute idee......
[Beitrag von Kumbbl am 22. Jan 2015, 17:12 bearbeitet]
arnaoutchot
Moderator
#12628 erstellt: 22. Jan 2015, 17:23
Kumbbl (Beitrag #12627) schrieb:
egal, wenn du sie (die neue oben verlinkte, nicht die alte SACD) günstig siehst, ja, dann schlag doch mal zu ... gute idee...... ;)
Ja, klar die neue, die SACD hab ich ja schon ... Jetzt geh mal nach Hause und steh nicht in Supermarktschlangen rum, Du hast noch was zu tun ...
vanye
#12629 erstellt: 22. Jan 2015, 17:36
Hm, also ich bin nach wie vor mit dem Klang meiner CD von Bat Out Of Hell sehr zufrieden.
@ Kumbbl: Hast PM ...
vanye
#12630 erstellt: 22. Jan 2015, 18:28
So, jetzt habe ich mal in die DVD reingehört, die ich bei meiner Ziggy Stardust entdeckt habe. Die Remixes sind nicht mein Ding. Vor allem die Snare, die sehr im Vordergrund steht, gefällt mir nicht. Insgesamt wirkt das für mich zu hell und sibilant.
Jetzt höre ich mir den Original Album Mix an und schneide gleich analog mit. Warum man die Musik als vob's auf die DVD legen muss, erschließt sich mir wirklich nicht. Vielleicht sollte ich mich mal mit Software zum Rippen von DVDs beschäftigen, aber bis jetzt habe ich nur zwei Audio-DVDs, beide aus Versehen gekauft - und so lange die gute alte Analogaufnahme funktioniert ...
hifi_raptor
#12631 erstellt: 22. Jan 2015, 19:41
Kumbbl schrieb:
i
...und weiter drunter im Artikel steht:
Den besten Klang erreichen Sie durch Verwendung von L’Art du Son CD/DVD Conditioner vor dem abspielen.
Also wer die BOOH nicht mag, einfach mit Konditionierer von Sieveking behandeln.
Dann kommt die bestimmt noch in HiRes und kostet lediglich die Hälfte.
Mal abgesehen davon das ICH das Album gut finde.
Käbbdn
#12632 erstellt: 22. Jan 2015, 21:03
Hinweis gemäß der EU-Verbraucherschutzrichtlinie: 1 Flasche L'Art du Son CD/DVD Conditoner enthält 100 mL aktive Substanz zur unverdünnten Benutzung. Diese Menge ist zur Behandlung von ca. 300 CDs/DVDs geeignet. Der Preis pro Liter entspräche € 500,-.
Meine Empfehlung:
Für die Kohle mehrere Flaschen erstklassigen Scotch Malt Whisky kaufen - damit klingt's, richtig angewendet, auch "um Klassen besser".
Ozone
#12633 erstellt: 22. Jan 2015, 21:05
Wenigstens hat das Schlangenöl einen verkaufsfördernden Namen.
chriss71
#12634 erstellt: 22. Jan 2015, 21:11
Käbbdn (Beitrag #12632) schrieb:
Für die Kohle mehrere Flaschen erstklassigen Scotch Malt Whisky kaufen - damit klingt's, richtig angewendet, auch "um Klassen besser". :L
Mr._Lovegrove
#12635 erstellt: 23. Jan 2015, 05:28
BOOH ist eines der größten Produktionsverbrechen der Rockgeschichte. Da hilft nix, aber auch gar nix.....
Kumbbl
#12636 erstellt: 23. Jan 2015, 08:33
:prost
ich empfehle hier einen Auchentoshan oder The Glenlivet - - meine beide Top- und Lieblingswiskys - am besten allerdings nicht äußerich sondern innerlich angewendet... bringt mehr als jeder Conditioner oder auch 32/384 Auflösung
Kumbbl
#12637 erstellt: 23. Jan 2015, 08:37
meine bisherigen ausgaben dieses Albums (und ich hab alle verfügbaren, egal ob LP oder CD) nterstützen dieses Aussage - aber wie immer stirbt die Hoffnung zuletzt....
beim zweiten großen Produktionsverbrechen Born to Run (Bruce) hat das jüngste Remaster zwar auch keine Wnder bewirkt (hat auch keiner erwartet) aber trotzdem klingt für mich die neue LP(!) hörbar am besten - und auch da hab ich alle anderen Ausgaben
velleicht bringt ja tatsächlich diese neue K2-Dingsbums-processed und mastered by Harakiri Sashimi (oder so ähnlich ) wirklich noch das benötigte Jota zum erträglichen......
chriss71
#12638 erstellt: 23. Jan 2015, 09:09
Just my 2cents: Sowohl bei Bat out of Hell als auch bei Born to run ist Hopfen und Malz verloren (zumindest was ein Remastering angeht, die 2 Promille die es unter Umständen besser klingt, machen das Kraut auch nicht fett....).
Das einzige was helfen würde, wäre ein Remix von den Original Multitracktapes. Alles andere ist für die Katz...
Kumbbl
#12639 erstellt: 23. Jan 2015, 09:20
wie immer sind wir hier der gleichen meinung, so ist es - aber du weißt ja Chriss, bei ein paar wenigen Alben machen halt auch 2 promille das Kraut zumindest eine spur fetter und da bin ich auf der Suche nach dem maximal fetten Kraut
chriss71
#12640 erstellt: 23. Jan 2015, 09:25
Kumbbl (Beitrag #12639) schrieb:
aber du weißt ja Chriss, bei ein paar wenigen Alben machen halt auch 2 promille das Kraut zumindest eine spur fetter und da bin ich auf der Suche nach dem maximal fetten Kraut ;)
Bin ich ja froh, dass ich diese Krankheit nicht alleine hab...
schmiddi
#12641 erstellt: 23. Jan 2015, 09:34
Ich habe mir gestern die BOOH mal wieder angehört, auf Grund der Diskussion hier. Es handelt sich um die CD von 1989.
Na ja was soll ich sagen, da fehlen glaube ich doch ein wenig mehr als 2 Promille
Kumbbl
#12642 erstellt: 23. Jan 2015, 09:40
schmiddi (Beitrag #12641) schrieb:
Na ja was soll ich sagen, da fehlen glaube ich doch ein wenig mehr als 2 Promille :prost
keine Frage, eigentlich fehlen ca. 90 PROZENT, aber manche wären eben schon um 2 Promille froh
und jetzt halte ich BOOH gar nicht mal für ein Hammeralbum (wenn auch für ein in summe gutes), aber es sind einfach 3 Hammersongs drauf...
[Beitrag von Kumbbl am 23. Jan 2015, 09:42 bearbeitet]
vanye
#12643 erstellt: 23. Jan 2015, 10:43
Three outta seven ain't bad.
Obwohl, ich komme auf vier Hammersongs:
Bat out of Hell
Two out of three ain't bad
Paradise by the dashboard light
For crying out loud
Und You took the words ... finde ich mindestens sehr gut! Also fast fünf von sieben.
Kumbbl
#12644 erstellt: 23. Jan 2015, 11:11
Ok, wenn wir schon dabei sind:
Bat out of Hell
For crying out loud
Und You took the words ... finde ich auch sehr gut, stimmt Also würde ich sagen, 3 Hammer und ein sehr guter
Kumbbl
#12645 erstellt: 23. Jan 2015, 11:18
arnaoutchot (Beitrag #12628) schrieb:
:D
Ja, klar die neue, die SACD hab ich ja schon ... Jetzt geh mal nach Hause und steh nicht in Supermarktschlangen rum, Du hast noch was zu tun ... :D
bin ja schon dran .... in einer stunde abgeschlossen...
hifi_raptor
#12646 erstellt: 24. Jan 2015, 12:53
Servus
gerade auf dem HDX konserviert, hatte ja das Konzert in der RAH gehört:
Immerhin war die Tour ratz fatz ausverkauft.
Einfach gut.
IMHO
Kommt ja hier im Forum direkt hinter der BOOH.
Happy Weekend
vanye
#12647 erstellt: 24. Jan 2015, 14:31
Meinen krankheitsbedingten Zwangsaufenthalt zu Hause habe ich mal genutzt, um mir das 1979er Paris-Konzert von AC/DC auf BluRay in ausreichender Lautstärke anzuschauen. Ich hoffe, den Nachbarn hat es so gut gefallen wie mir!
Die Klangqualität der Stereospur ist nicht überragend aber ausreichend, finde ich. Dafür ist das Bild überraschend gut, was für mich gut passte, da kurz vor Weihnachten unsere alte Röhre den Geist aufgegeben hatte und jetzt durch einen modernen Flachmann ersetzt ist. Insgesamt kommt die Atmosphäre super rüber: die Luft brennt auf der Bühne.
Ich persönlich hätte gerne auf die Film- und Intervieweinblendungen während des Konzert verzichtet. So etwas habe ich lieber als Bonus-Features. Aber OK, irgendwas ist halt immer ... Insgesamt jedenfalls eine dicke Empfehlung für alle AC/DC Fans - besonders die, die den Gesang von Bon Scott mögen.
[Beitrag von vanye am 24. Jan 2015, 14:32 bearbeitet]
Jugel
#12648 erstellt: 26. Jan 2015, 15:09
"Eddie Van Halen wird sechzig", schreibt die FAZ heute und widmet ihm einen lesenswerten Artikel: "Auf dem Wellenkamm" (klick).
Fragt sich nur, welches Album untern Laser soll...
Jugel
Käbbdn
#12649 erstellt: 26. Jan 2015, 16:14
Na, da ist die Auswahl doch gar nicht sooooo groß, oder ??
Ich empfehle dieses hier:
VanHalen
Happy Birthday!!
Kumbbl
#12650 erstellt: 27. Jan 2015, 08:19
yo, das einzig durchgehend gute Album von Van Halen - IMHO.
und diese DCC ist in der Tat eine derjenigen, die auch heute noch zu recht den Klangreferenz-Stempel tragen - was auf einige (viele?) andere DCCs mittlerweile nicht mehr zutrifft...
vanye
#12651 erstellt: 27. Jan 2015, 14:44
Das Album Fly By Night von Rush ist jetzt auf Highresaudio im neuen Jubiläums-Remaster verfügbar als 24/96 FLAC. Zuerst war ich irritiert, da als Jahr 2014 angegeben war und auch nur dieses eine Format verfügbar ist (angekündigt waren DSD (2.8mHz), 24/192 und 24/96 ).
Ich habe daraufhin mal eine Mail an Highresaudio geschrieben und nachgefragt. Es handelt sich tatsächlich um das neue Remaster. Die Jahreszahl wurde inzwischen auf der Website korrigiert. Der Herr, der mir freundlicherweise antwortete, sagte auch, dass sich das Angebot auf 24/96 beschränke, weil sie bei der Qualitätskontrolle keinen Unterschied zur 24/192 messen konnten und sie für DSD von Universal noch nicht lizensiert sind. Er rät mir auch zur FLAC-Datei, da er davon ausgeht, dass die DSD-Datei aus der PCM gewandelt wurde.
Nun ja, DSD möchte ich sowieso nicht (zum Glück brauchen wir in diesem Thread keine diesbezüglichen Glaubensgrundsätze zu diskutieren) und ich werde dann wohl mal bei der 24/96 zuschlagen. Qobuz bietet zwar die 24/192 an, aber nachdem Highresaudio meine Mail so schnell und ausführlich beantwortet hat (und auf der Website nachgebessert), fühle ich mich da gut aufgehoben. Und dass gerade ich einen Unterschied zwischen den Auflösungen hören könnte, bezweifle ich jetzt mal.
Ich schmeiß mal den Download an ...
vanye
#12652 erstellt: 27. Jan 2015, 17:43
So, habe Fly By Night jetzt einmal gehört. Gut ist schon einmal aus meiner Sicht, dass dieses Remaster sehr leise ist. Ich musste ungewöhnlich weit aufdrehen, bis ich "meine" Abhörlautstärke erreicht hatte. Gut gelungen finde ich auch den Kompromiss zwischen Durchhörbarkeit, Räumlichkeit und Punch. Dies ist bei Rockmusik für mich immer ein entscheidendes Kriterium. Insoweit alles richtig. Stellenweise fiel mir die Stimme als etwas sibilant auf, während die Becken an der einen oder anderen Stelle meiner Meinung nach etwas mehr "Crash" vertragen könnten.
Caveat: Ich kenne keine andere digitale Version dieses Albums, besaß bisher nur die deutsche Vinyl-Erstausgabe. Insgesamt würde ich in meiner Hörsituation das digitale Remaster bevorzugen.
[Beitrag von vanye am 27. Jan 2015, 17:44 bearbeitet]
vanye
#12653 erstellt: 27. Jan 2015, 18:11
Und wenn ich schon mal einkaufe, kann es natürlich nicht bei einem Album bleiben. Quasi als Beifang auf Highresaudio ist mir auch noch Trigger Hippy von der gleichnamigen Band ins Netz gegangen. Leider für meine Ohren zu laut abgemischt (wenn schon 24 Bit) aber musikalisch ganz feiner Bluesrock.
Der Bandname war mir völlig unbekannt. Ein reiner Zufallsfund. Aber Wikipedia hat mir gerade erzählt, dass es sich unter anderem um einige Black Crowes Akteure und Joan Osborne handelt. Reinhören lohnt sich also allemal, wenn man auf Southern-/Bluesrock steht.
Meinen dritten "Fang" von heute erspare ich Euch lieber. Schätze mal nicht, dass klassische Gitarre Euer Ding ist.
Ozone
#12654 erstellt: 27. Jan 2015, 18:20
vanye (Beitrag #12653) schrieb:
Meinen dritten "Fang" von heute erspare ich Euch lieber. Schätze mal nicht, dass klassische Gitarre Euer Ding ist. :D
Gackern und nicht legen gilt nicht. Also raus mit dem Fang!
vanye
#12655 erstellt: 27. Jan 2015, 18:29
Gackern und nicht legen gilt nicht. Also raus mit dem Fang! :)
Na gut, ehe ich mich schlagen lasse.
Emanuele Buono: Guitar Recital
maho69
#12656 erstellt: 27. Jan 2015, 19:23
Ehrlich gesagt habe ich in der Eile "Guitar Rectal" gelesen
RocknRollCowboy
#12657 erstellt: 27. Jan 2015, 20:07
"Trigger Hippy" weiß zu gefallen.
Hätte mir jedoch mehr Songs in der Art von "Nothing New" und "Mississippi Mud" gewünscht. Also ich bin halt mehr der Rocker.
Die gibt´s hier drauf: Cadillac Three
Dirty Southern und Country Rock.
Beispiele zum Reinhören mit Original Videos:
gibt´s hier
leider mit Werbung
Georg
vanye
#12658 erstellt: 28. Jan 2015, 12:50
Meine Ohren haben mich wohl bezüglich der Lautheit nicht getäuscht:
foobar2000 1.3.7 / Dynamic Range Meter 1.1.1
log date: 2015-01-28 12:43:32
Analyzed: Geddy Lee, Alex Lifeson, Neil Peart / Fly By Night (HiRez)
DR Peak RMS Duration Track
DR12 -2.20 dB -15.59 dB 4:27 01-Anthem
DR13 -2.95 dB -16.97 dB 3:29 02-Best I Can
DR12 -2.65 dB -16.09 dB 3:05 03-Beneath, Between & Behind
DR12 -2.72 dB -18.16 dB 9:32 04-By-Tor And The Snow Dog
DR12 -3.04 dB -16.71 dB 3:23 05-Fly By Night
DR13 -2.01 dB -17.88 dB 3:05 06-Making Memories
DR13 -7.63 dB -26.32 dB 5:01 07-Rivendell
DR12 -3.15 dB -18.86 dB 6:49 08-In The End
Number of tracks: 8
Official DR value: DR13
Samplerate: 96000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 3013 kbps
Codec: FLAC
log date: 2015-01-28 12:46:51
Analyzed: Trigger Hippy / Trigger Hippy
DR7 0.00 dB -8.06 dB 5:05 01-Rise Up Singing
DR6 0.00 dB -7.40 dB 4:32 02-Turpentine
DR6 0.00 dB -8.18 dB 5:49 03-Heartache On The Line
DR6 0.00 dB -7.10 dB 4:21 04-Cave Hill Cemetery
DR6 0.00 dB -7.23 dB 5:32 05-Tennessee Mud
DR6 0.00 dB -7.82 dB 3:13 06-Pretty Mess
DR6 0.00 dB -7.54 dB 3:48 07-Pocahontas
DR7 0.00 dB -9.45 dB 6:37 08-Dry County
DR6 0.00 dB -7.77 dB 3:16 09-Nothing New
DR6 0.00 dB -8.37 dB 5:41 10-Ain’t Persuaded Yet
DR8 0.00 dB -10.09 dB 4:55 11-Adelaide
Number of tracks: 11
Official DR value: DR6
Samplerate: 44100 Hz
Channels: 2
Bits per sample: 24
Bitrate: 1591 kbps
Codec: FLAC
Käbbdn
#12659 erstellt: 29. Jan 2015, 10:29
Hier ist noch ein Versuch eingetrudelt, eine 2014-er Scheibe dauerhaft in meine Sammlung zu integrieren:
Crippled Black Phoenix - White Light Generator
In Besprechungen wird häufig der Vergleich mit den frühen Pink Floyd gezogen, und das Wort "Prog" fällt auch häufig.
Passt beides nicht so recht, finde ich - ist aber auch nicht ganz falsch. Jedenfalls, wer auf die eher schwermütig-melodische Ecke kann, mag mal ein Ohr riskieren......
White light Generator
bela
#12660 erstellt: 29. Jan 2015, 11:57
Moin
Bei CRIPPLED BLACK PHOENIX solltest Du unbedingt in die hier mal rein hören.
Da treffen die Attribute "Prog" und frühe PF eher zu:
619NxQCMXyL
Ozone
#12661 erstellt: 29. Jan 2015, 11:59
Die CBP sind sehr interessant. Bin erst vor kurzem über den 7 Minuten Thread drauf gestossen und muss sagen, die Scheiben haben was.
bela
#12662 erstellt: 29. Jan 2015, 12:04
Da hat mich vor Jahren meine Ex-Freundin (Du hörst doch so'n Kram) drauf aufmerksam gemacht.
Mittlerweile habe ich den kompletten Katalog als super klingendes Vinyl
TomGroove
#12663 erstellt: 29. Jan 2015, 12:16
die von Bela erwaehnte gab es sogar mal als freien Download in der Flac Version. Bin mir nicht sicher,
ob es immer noch so ist
[Beitrag von TomGroove am 29. Jan 2015, 22:43 bearbeitet]
Käbbdn
#12664 erstellt: 29. Jan 2015, 14:58
HaHaHa - mit den Worten "Du hörst doch so'n Zeug...." ist mir die Truppe auch empfohlen worden.......
"I, Vigilante" läuft gerade, auf'm PC im Büro, und erfreut auch meine Mitarbeiter hier.......:D
vanye
#12665 erstellt: 30. Jan 2015, 18:13
Ich habe mir auf Eure Empfehlung hin jetzt mal die Love: Forever Changes zugelegt. Ist heute angekommen und gefällt mir inhaltlich auch gut. Schöne Empfehlung!
Ich habe die "Remastered & Expanded" CD. Leider ist Track 9 (The Good Humor Man He Sees Everything Like This) fehlerhaft, am Ende hört es sich wie Lesefehler an. Ist das normal oder nur meine CD? Ich hole mir mal gerade noch von Amazon meinen Autoripp, schauen, ob der Fehler auch darauf zu hören ist ...
Edit: Tatsächlich, die MP3 aus dem Amazon Autoripp hat das auch. Wie sieht es bei Euren Ausgaben aus?
[Beitrag von vanye am 30. Jan 2015, 18:19 bearbeitet]
arnaoutchot
Moderator
#12666 erstellt: 30. Jan 2015, 18:29
Das gehört so, ist kein Fehler ... erschrecke auch jedesmal wieder.
vanye
#12667 erstellt: 30. Jan 2015, 18:50
Das gehört so, ist kein Fehler ... erschrecke auch jedesmal wieder. ;)
Ach so. Gut, dann bin ich beruhigt. Danke für die schnelle Auskunft!
[Beitrag von vanye am 30. Jan 2015, 18:50 bearbeitet]
Aufbau einer "audiophilen" Classic-Rock-Sammlung (1965-1980)
arnaoutchot am 23.09.2010  –  Letzte Antwort am 29.09.2024  –  3170 Beiträge
Gute Rockmusik nach 1980 in bestmöglicher Klangqualität
arnaoutchot am 23.02.2011  –  Letzte Antwort am 05.03.2024  –  311 Beiträge
Aufbau einer "audiophilen" Pop- Sammlung
Mr._Lovegrove am 04.08.2011  –  Letzte Antwort am 06.01.2019  –  19 Beiträge
Übersicht Rock Genres
Mrc381 am 15.06.2011  –  Letzte Antwort am 18.06.2011  –  6 Beiträge
Suche Rockmusik
Uli72 am 05.04.2011  –  Letzte Antwort am 06.07.2011  –  22 Beiträge
Suche LIVE Rockmusik wie...
PausIZ am 18.12.2015  –  Letzte Antwort am 30.01.2016  –  3 Beiträge
Fitness-Rock gesucht
Sunlion am 09.11.2024  –  Letzte Antwort am 21.11.2024  –  6 Beiträge
Überbewertete Rock CD's/LP's
Tosato am 05.11.2017  –  Letzte Antwort am 05.01.2022  –  248 Beiträge
Einfluss von J.R.R. Tolkiens "Herr der Ringe" auf die Rock-Musik
arnaoutchot am 29.04.2020  –  Letzte Antwort am 07.02.2022  –  36 Beiträge
Suche gute deutsche Rock Review Seite
thomsen1512 am 03.04.2015  –  Letzte Antwort am 13.04.2015  –  5 Beiträge
  • Registrierte Mitglieder928.191 ( Heute: 12 )
  • Neuestes MitgliedMrHoschy94
  • Gesamtzahl an Themen1.557.659
  • Gesamtzahl an Beiträgen21.683.941
