HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Yamaha A-S301 help | |
Yamaha A-S301 help+A -A |
kartalkafadar
12:51
erstellt: 13. Jul 2024, |
Hello. I have a Yamaha A-S301 amplifier that I use at home. 1 week ago, while listening to music, after 1 hour, the sound distortion occurred on the left output. There is no problem on the right output. I opened the cover of the device and there is no burnt part visible to the eye. I tested solid speakers and cables, but the problem is in the output. I will try to add a video. Do you think the fault may be caused by the left output transistor? There is sound in the speaker, but it is not clear, distorted and crackly. ![]() ![]() |
CarlM.
13:32
Hi, Did you try different sources - especially optical vs. analog (OPTICAL vs. CD, TUNER)? What about the sound using headphones? Press PURE DIRECT ... any changes? Are you experienced in repairing equipment like this? Multimeter, soldering station? |
kartalkafadar
13:49
Yes, I tried, but the sound at the left output also produces a distorted tone. I tried tuner, phone, optic etc. all of them, while the right side gives good sound, the left side gives a crackling sound. Yes, I have a soldering station. I work in the technical department at Apple service, but I wanted to consult you because I have not repaired an amplifier before. Could one of the output transistors be faulty? Could it cause sound distortion? |
CarlM.
14:02
"Could one of the output transistors be faulty? Could it cause sound distortion? " In most cases the protection would be active. Therefore I don't believe so. The service manual is available for download here: ![]() Page 18 describes the way to use the self diagnostic function. If it detects no problems, it will be necessary to make some measurements (we'll see later). |
kartalkafadar
06:04
erstellt: 15. Jul 2024, |
Thank you, I will try this tonight. |
Poetry2me
08:57
I would recommend to check the block diagram first to help you identify where the problem could be and which parts to exclude. Note that many preamp functions of these amps are implemented within one big "Volume IC" (IC402). Yamaha is re-using their AV Receiver IC which originally supports many more channels than just stereo. So here they are using it to support functions like symmetrical input (CD), tone control, loudness, etc. ![]() To support further troubleshooting in case of power amp damage, please find here the left power amp schematic with colorized stages. ![]() - Johannes |
kartalkafadar
06:10
erstellt: 16. Jul 2024, |
Hello again. Last night, I made the troubleshooting combinations recommended by Yamaha. The sound was distorted on the left side. After this combination yesterday, there is no sound coming out from the left side, there is only sound on the right output. Thank you for the schematic. Which transistor should I look at before Q123A - Q123C transistors? My device's problem was the same as in the video. ![]() [Beitrag von kartalkafadar am 16. Jul 2024, 14:32 bearbeitet] |
Poetry2me
07:50
erstellt: 17. Jul 2024, |
As I read this, all your checks so far point in the direction of a damage in the left power amp section. The firmware self test you started did NOT give you an indication but may have completed the damage to a part in the power amp. But we already know a lot now. Since protection does not recognize the damage (does not trigger the relay to cut off loudspeaker terminals from the amp), ---> the damage is not likely to be in the last two current amplifying stages 4 "Driver" and 5 "Final". And generally, the amp works, it amplifies. Only just distorting somewhat, like an overdriven or limited signal. This means that ---> the damage is not likely to be in stage 1 "Differential input stage", the signal can be recognized as such. This leaves you with stages 2 and 3 which both belong to the VAS (Voltage Amplifying Stages). Interestingly, with Yamaha receivers and amps, we recently had multiple cases where single parts (resistors, diodes) in these stages failed due to overload of parts too weak by design. I would check the two SMD diodes D103 and D104 whether one of them has a fault, like a disconnect. SMD parts are usually placed on solder side of the PCB. Next I would check the resistor R124 which is in line with them. R124 is implemented as an oldschool through-hole resistor. Hope this helps. - Johannes [Beitrag von Poetry2me am 17. Jul 2024, 11:00 bearbeitet] |
kartalkafadar
08:58
Thank you for your answer. I will check the D103 and D104 diodes you mentioned and then check the R124 resistance. I will leave you feedback again. I want it to be useful to people who have the same problem. |
kartalkafadar
06:24
erstellt: 19. Jul 2024, |
[Beitrag von kartalkafadar am 19. Jul 2024, 13:44 bearbeitet] |
Valenzband
09:18
Better delete your email reference! You may receive a lot of SPAM otherwise as this forum is public. Use tab "private communication" ("Private Nachrichten" ) instead. |
kartalkafadar
13:49
Poetry2me
23:17
____CONGRATULATIONS____ for you successful repair ![]() Glad it worked out well. One more device saved for the planet's sake. And yes, I think that Yamaha does have an issue with dimensioning their parts. Maybe the impulse load of the components mentioned may be greater than expected. The components used should be able to handle impuls load better. - Johannes [Beitrag von Poetry2me am 19. Jul 2024, 23:18 bearbeitet] |
Poetry2me
23:31
kartalkafadar
06:26
erstellt: 22. Jul 2024, |
Yes . This is my opinion too. The cases he uses are small, the resistors may have lost their values in the heat. If we add both the temperature of the environment used and the operating time of the amplifier under load, these problems may arise. Apple made the same tantalum capacitor case mistake in the 2011 Macbook Pro model, and when the graphics card started to heat up, the device crashed. We solved this problem by enlarging the case. Fortunately, the problem was solved, thank you for the information, my friend. I would appreciate it if you could send me your e-mail address via private message. |
Teufel decoderstation 3 rear left output problem MarkBLN am 07.09.2021 – Letzte Antwort am 08.09.2021 – 9 Beiträge |
HIFI amplifier: diagnosing power amplifier stage hyuna am 05.01.2017 – Letzte Antwort am 13.01.2017 – 2 Beiträge |
Tuner problem with my STR-GX315 szabi am 29.11.2005 – Letzte Antwort am 05.03.2011 – 2 Beiträge |
Sony dtc 1000es Audio Design PRODAT 1 David.Box am 08.07.2019 – Letzte Antwort am 08.07.2019 – 3 Beiträge |
replacement for khl 7000 a fuse frans_callebaut am 01.04.2019 – Letzte Antwort am 02.04.2019 – 2 Beiträge |
SONY DTC-77 "funy" fehler Lajos_hu am 24.04.2016 – Letzte Antwort am 25.04.2016 – 6 Beiträge |
Kenwood KA-4040R stereo amp. L Channel week Almantas am 25.06.2024 – Letzte Antwort am 25.06.2024 – 2 Beiträge |
Dual MN-8010 battery? kabuco87 am 04.02.2005 – Letzte Antwort am 10.08.2011 – 3 Beiträge |
VSA 1000 David_Ramirez am 21.09.2021 – Letzte Antwort am 22.09.2021 – 5 Beiträge |
The amp e800 probleme megashooter am 17.12.2015 – Letzte Antwort am 18.12.2015 – 2 Beiträge |
2024
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder928.821 ( Heute: 11 )
- Neuestes Mitglied*Baramundi*
- Gesamtzahl an Themen1.559.072
- Gesamtzahl an Beiträgen21.716.837
