Problem mit Pioneer VSX-D2011
Keksdreher
#1 erstellt: 13. Jun 2010, 12:06
Hallo zusammen, habe folgendes großes Problem mit meinem Pioneer-Receiver, er lässt sich nicht mehr einschalten und die Standbylampe blinkt nur noch, habe versucht einen Reset laut Handbuch zu machen, aber darauf reagiert das Gerät auch nicht mehr .... Was kann ich tun ? Bin für jede Hilfe dankbar.
tri-comp
#2 erstellt: 13. Jun 2010, 20:27
I'm afraid you're not going to like this answer ...apart from it being in English
This receiver is a very complicated and computer-controlled circuit.
A LOT of things may cause the power-down you are experiencing.
Most likely, of course it is a defective output amplifier ...but there are 7 of them!
A power-supply fault is also a possibility along with faults in the protection circuit itself.
What you need to do is to take the receiver to someone with a lot of experience in repairing highly complicated electronics.
Once you find him, and he wants a service-manual to complete the work, feel free to PM me for info on how to get one.
mfg,
/tri-comp
Keksdreher
#3 erstellt: 14. Jun 2010, 18:50
But is there some other possibility to Reset the Receiver ?? take out some fuse or smthg else ?!
tri-comp
#4 erstellt: 14. Jun 2010, 21:47
There is NOT another reset, but there is an explanation; at least I THINK the explanation of this 'Dead-State' is in the service-manual.
I read through it for more information and it seems that when DC on some amp-output is detected once, the amplifier locks-up and refuses more key-inputs and continously blinks the Stand-By LED. The speaker-relay disconnects the speakers for safety to avoid speaker-failure as well.
What you can do is to press simultaneously STEREO/DIRECT and TONE for more than 2 seconds a Diagnostic mode is entered. It will show sequentially in the display:
PROTECT CHECK DC
PROTECT CHECK OVERLOAD
PROTECT CHECK FANSTOP
PROTECT CHECK TEMP
Each item should show 0 (Zero) but my guess is, that the first line will show a value. It indicates a defective amplifier with DC on the output.
NOW, go back and read my recommendation in the first answer.
mfg,
/tri-comp
Keksdreher
#5 erstellt: 15. Jun 2010, 16:30
Ok thanks for your answer, so my Dad is electrician Engineer and also myself is graduated in electrician, so maybe we can try to fix it by ourself, because the Receiver is out of guarantee, and some repair will cost up to 200€ and thats a lot of money for such an old Receiver. But where i can get some electrical drawings or smthg like that ?!
Keksdreher
#6 erstellt: 15. Jun 2010, 16:33
Ok i tried to push Stereo/Direct and Tone, but nothing happens ...
tri-comp
#7 erstellt: 15. Jun 2010, 22:05
Actually I possibly made an error.
I read the service-manual again and I believe what Pioneer is trying to say is to push the TONE+ key along with the STEREO/DIRECT key for more than 2 seconds when the set is in stand-by mode.
Try this at least.
As I don't have the receiver on hand it's difficult to know if there is more than one TONEkey
PM me with your e-mail address for info on how to get the servie-manual.
mfg,
/tri-comp
Keksdreher
#8 erstellt: 21. Jun 2010, 13:50
Hey okay, so i was a few days not at home, and now i can turn on the receiver ?! but still no sound ... hmmm
So i tried to enter the diagnostic-mode tone+ and stereo/direct.
Display shows :
Prot CHK
DCDET 000
OVERLOAD 000
FANSTOP 000
TEMP 000
You can say anything about these messages ?
hopefully ...
audiophilanthrop
#9 erstellt: 21. Jun 2010, 15:08
Eigenartig, angeblich alles in Butter - aber paßt dazu, daß er jetzt einschaltet. Könnte sein, daß ihm irgendwelche Betriebsspannungen abgehen.
Alle Sicherungen sind OK?
Unter welchen Umständen ist der Fehler eigentlich aufgetreten?
Ich würde sagen, Mennjuell besorgen und fleißig mit dem Multimeter rumstochern, irgendwas wird schon faul sein...
Keksdreher
#10 erstellt: 21. Jun 2010, 15:31
Der Receiver schaltet ein und man hört deutlich das das Ausgangsrelais schaltet, dann läuft ungefähr alles 5-10 min problemlos. Dann verstummt alles, als wenn jemand mute drücken würde, aber man hört nicht das das Relais schaltet. Schalte ich den Receiver nun aus und warte eine zeitlang wiederholt sich das ganze ... Ich gehe soweit eigentlich von einem wärmeproblem aus ...
Habe das Gerät schon aufgeschraubt und versucht mit Kältespray eine Fehlerquelle zu lokalisieren, leider bisher ergebnislos. Eine Werkstatt meinte sicher zu sein, das der Fehler iwo in der Digitalplatine sein muss, aber auch dort mit Kältespray kein Ergebnis ... Ca. Reparaturkosten 200€ aufwärts, und die sind mir das Gerät nicht wert, auch wenn ich damit sehr zufrieden bin/war ...
Deswegen versuche ich zu retten was zu retten ist, denn irgendwie funktioniert er ja wohl
Das Gerät verfügt bauseits über 2 interne Lüfter von denen zu keiner Zeit auch nur einer läuft was ich auch schon sehr merkwürdig finde ...
Korrektur, nach 15 min warten, funktioniert er ca. 3 sekunden einwandfrei und "mutet" dann ...
So ca. Stunde später läuft er ca. 4 min und "mutet" dann.
[Beitrag von Keksdreher am 21. Jun 2010, 17:03 bearbeitet]
audiophilanthrop
#11 erstellt: 22. Jun 2010, 00:52
Zur Eingrenzung: Hat er eine "Pure Direct"-Funktion, die den ganzen Digitalkrempel umgeht? Dann aktiviere die mal.
Ansonsten suche mal nach allen Spannungsreglern (78xx/79xx) und was sich sonst so an kühlkörperbestückten Transistoren usw. findet, gerade im Netzteilbereich. Da gibt es gern schlechte Lötstellen, evtl. auch geschwächte Halbleiter.
Keksdreher
#12 erstellt: 23. Jun 2010, 16:18
Also was du meinst wird wohl die Stereo/Direct funktion sein, aber auch in diesem Modus dasselbe Problem hatte ich auch schonmal versucht, deswegen finde ich es merkwürdig das die Werkstatt meint das es auf der Digitalprozessor Platine zum dem Problem kommt, wobei ich nicht weiss ob das Signal trotz dieser Funktion durch diese "gejagt" wird ...
Nach den Transistoren etc. auch im Netzteilbereich werde ich morgen mal schauen ... heute ist erstmal Schland
misfits
#13 erstellt: 18. Sep 2010, 23:34
Hast du mittlerweile die Lösung gefunden?Oder doch verkauft?
Hab den kleinen Bruder hier und dasselbe Problem.Stand by blinkt nur noch.Mittels tasten kombi steht dan amp error und geht wieder aus.Vorher lies er sich normal einschalten nur halt kein ton dabei.
Hab dann die "selbstdiagnose" durchführen lassen wobei bei DC der 255 erschien.also wenn der Wert 0 sein sollte ein wenig hoch^^.
Danke für die Antwort.
Keksdreher
#14 erstellt: 19. Sep 2010, 14:18
Hallo, nein mein Receiver lässt dich zwar wieder einschalten aber die Sache mit dem Ton funktioniert noch immer nicht.
Also meiner zeigt bei der Selbstdiagnose alle Werte als OK an, aber dennoch schaltet er nach einigen minuten den Ton ab und dieser kommt auch nicht wieder, es sei denn man schaltet ihn wieder aus.
Das mit der blinkenden Standbylampe, ja ich hatte ihn einfach ein paar Tage vom Netz getrennt danach liess er sich wieder einschalten, habe ich auch keine erklärung für.
misfits
#15 erstellt: 19. Sep 2010, 17:04
Hmm.Klingt irgendwie nach puffer batterie.Wenn die nach längerer Standzeit sich entladen scheint der Fehlerspeicher auch keine spannung mehr zu bekommen und ist wieder "leer".Bis halt das alte problem da.Hab das Service manual falls du es brauchst ;-)
muss meinen wohl oder übel mal auseinader bauen.
Keksdreher
#16 erstellt: 19. Sep 2010, 17:24
Danke, habe das ServiceManual auch zur Hand, aber ich weiss beim besten willen nicht mehr wo ich ansetzen soll ...
War wohl echt begeistert von dem Receiver, aber langsam bin ich mit meinem Latein am ende, werde ihn kurz oder lang wohl dem Schrott überlassen :´(
Pioneer VSX-D2011 IR Sensor (Fernbedienung) kaputt?
HiFi?JoHannes! am 03.02.2019  –  Letzte Antwort am 11.02.2019  –  10 Beiträge
Speicherkondensatortausch bei Pioneer VSX-D1011 / 2011
mopett1100 am 14.09.2012  –  Letzte Antwort am 11.04.2023  –  15 Beiträge
pioneer vsx d1011
mika15 am 16.02.2015  –  Letzte Antwort am 18.02.2015  –  4 Beiträge
Flachkabel Pioneer VSX-1016v
stigma1 am 23.06.2009  –  Letzte Antwort am 24.06.2009  –  2 Beiträge
Pioneer VSX-d1011
misfits am 27.09.2010  –  Letzte Antwort am 12.10.2010  –  5 Beiträge
Pioneer VSX-329 Defekt? ;(
BlackGale44 am 31.03.2015  –  Letzte Antwort am 04.04.2015  –  2 Beiträge
Pioneer VSX-D811S Defekt
xtd_304 am 23.03.2013  –  Letzte Antwort am 25.03.2013  –  4 Beiträge
Pioneer VSX-916 defekt?
dec.fx am 03.10.2012  –  Letzte Antwort am 04.08.2018  –  18 Beiträge
Pioneer VSX-824-K
Def22Fire am 22.05.2016  –  Letzte Antwort am 24.05.2016  –  3 Beiträge
Fernbedienung Pioneer VSX-409
hanswolf am 28.05.2020  –  Letzte Antwort am 31.05.2020  –  3 Beiträge
  • Registrierte Mitglieder928.910 ( Heute: 1 )
  • Neuestes MitgliedDaisy_L.
  • Gesamtzahl an Themen1.559.251
  • Gesamtzahl an Beiträgen21.721.442
